Question about Sharp Televison & Video
Can thee cable connection that's inside the TV be reconnected?
    Sergeant:
  • 295 Answers
How do you know it's disconnected now?
Posted on Dec 08, 2014
PSP wil not connect to television at all.
Disconnect the battery, reconnect and switch it on whilst holding down both top two corner clear buttons. It should restart in recovery mode. Toggle down and select RECOVERY folder, then select. If this folder is corrupted you will have to get a copy off of the internet and replace it using the usb connector. This usually does the trick, if it will not start in recovery mode, it's a SONY job...
Good luck
Aug 18, 2012 | Sony PSP-3000 Black Console
Our tv, model 42hp25bat, has been running on our cable input for the past year. All of a sudden the tv input setting says "no signal". The tv works for our DVD player on HDMI setting. We...
the signal input on the cable connection to to your tv (inside your tv) is broken, and possibly needs to be replaced. Possibly few capasitors or other parts might need to be replaced. or the whole signal board.
Apr 17, 2008 | Televison & Video
I can't get my laptop to work on my tv
Is your graphics card compatible with your model of tv? or have you purchased the correct lead for it?
Aug 01, 2012 | Acer Aspire 7520-5185 Laptop
Audio out locations on back of tv
Hello
You want to connect your TV with an external audio device, and want to hear sound from it, I assuses, and posts this solution.
There is audio out sockets at the back side of the TV, very near to S-Video socket. Marked audio "L" & "R". These two sockets are audio out socketsfrom TV to connect any external audio amp. Just use an audio cable to connect these sockets, to 'Audio IN' of the amp socket. Switch ON both the devices. You can hear the audio of your TV programmes by the amp you conneccted with.
The picture of the AV cable is given here. Take red and White colourd connections to connect the TV with amp. Left the Yello coloured pins free. It is meant for video. 2_11_2012_3_19_43_pm.jpg
Feb 11, 2012 | Element Electronics FLX3210 32 in. LCD TV
How can i get more volume on my onstage monitors thru my mackie 2404 vlz3 mixer or what is the proper way to connect the monitors
Without more information of your speakers and amps we can't really help you. The Mackie board puts out line-level signals and that should drive any connected amp or powered speaker to the full capability. Make sure you are using BALANCED interconnect lines either XLR or TRS cables. Use of TS unbalanced cables costs you 6 DB and also noise pickup. Make sure ALL your gear, amps, speakers etc are powered from a SINGLE receptacle or power conditioning module. Normally you will use the AUX outputs of the mixer by way of TRS cables or balanced lines in a snake to power amplifiers onstage which then connect to the stage monitors. If you have powered monitors the returns of the aux to the stage go to the powered monitors. A heavy duty extension cord brings power back from thee stage power to the mixer.
Sep 06, 2011 | Mackie 2404-VLZ3 Mixer
My car's battery works but when it trys to stay on it won't it looks like theres a frayed connection of wires the copper is showing how to fix
disconnect frayed cable from battery,cut frayed part of cable off,strip insulation off end of cable attach ring connector to end of cable &reconnect to battery.
May 12, 2011 | Volkswagen Passat Cars & Trucks
Movie has no red color only green and yellow
Remove & re-seat the component video cables at both the TV and the DVD player.
If the problem continues, disconnect BOTH ends of the BLUE cable and the RED cable. Connect the BLUE cable to the RED jack at both the DVD and TV, and connect the RED cable to the BLUE jack ob both the TV and DVD. If the RED color comes back and the BLUE is missing, then replace the RED cable (the red cable is broken and will not pass the signal that it is connected to).
If all works, reconnect the colored cables to the corresponding colored jacks at both the TV and DVD player.
If the RED color still won't display, isolate the trouble to either the DVD player or TV by connecting the DVD to another TV w/ component jacks. If the RED is still missing, it is a problem inside the DVD player - if the RED displays, it is a problem with the TV.
Sep 30, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
How to connect the back connections to TV.
yellow is video
red is right sound
white is left sound
Jun 01, 2009 | Sony DVP-NC600 Multi-disc DVD Player
Televison & Video Logo
27 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
