Question about Whirlpool Washing Machines
How do I replace the wire in seal - Whirlpool Washing Machines
  • 32 Answers
What wire in what seal need more information
Posted on Dec 17, 2014
LG HE Waher model WM2010c, rubber door seal slid and distorted the seal edge, on a spin cycle with a towel in it, how do I fix this?
If seal/boot is not torn, then remove front spring/wire clamp, reposition the seal/boot, reinstall the spring/wire clamp. Check out repair videos at appliancepartspros.com or repairclinic.com.
Feb 01, 2017 | LG Washing Machines
How to replace rear window 2003 gmc envoy
NEED TWO PEOPLE, USE PIANO WIRE GUITAR STRING OR SIMULER WIRE, FROM OUT SIDE PUSH WIRE THROUGH WINDOW SEAL TO INSIDE EACH PERSON PULL WIRE AROUND WINDOW CUTTING SEAL, THEN LIFT OUT WINDOW, SCRAPE OUT OLD SEAL , REPLACE WITH NEW SEAL AND INSTALL WINDOW!
Sep 09, 2011 | 2003 GMC Envoy
HOW TO REMOVE RUBBER SEAL
ok if you look around the front of the rubber seal you will see a wire holding it in place on the wire there is a spring if you pull the spring off with a pair of pliers the door seal will just pull off the cabinet then take off the lid and you will see the wire that goes around the door seal where its held onto the drum some have a screw on it and some just pull off then give the seal a good pull from the front of the machine it will pull off quite easy then just push the new seal into place and replace the wire thankyou
Jan 23, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Vacum works heatseal does not seal can i replace seal
Sealing always tends to be the problem with FoodSaver because during the course of normal wear and tear, the sealing strip and wire will naturally need to be replaced.
You can get replacement heating wires and strips at www.elementandteflon.com
We started out selling just replacement parts for heat impulse sealers but we kept on getting customer requests for FoodSaver parts so we've added that section to our website.
Dec 14, 2010 | Tilia Foodsaver V835 Vacuum Sealer
How to fix a front leaky oil seal in a 1995 Toyota Camry LE
Three seals to check. easiest is the valve cover seal. Number and remove the 4 wires going into your spark plugs. remove 4 nuts holding the cover and replace seal.
Next easiest is the distributor O-ring. Remove air filter assembly remove the distributor cap, then the distributor. With the valve cover still off, loosen the 2 bolts that clamp the distributor down. Remove the 2 terminal leads going into the distributor (4 wire terminal/2 wire terminal) Mark the case of the distributor and the case of the head with one line so you can line it back up on reinstallation. remove the 3 bolts holding the distributor down. Replace O-ring. replace distributor, align, tighten the 2 bolts, then tighten the 3 bolts. replace terminal wiring and cap. replace air filter assembly. Replace valve cover with new gasket. Place spark plug wires back into their proper places. The last one is the oil pan gasket. Drain all oil and remove all blots holding the pan. drop the pan and replace the gasket. Put it all back into place. Do not over tighten the pan bolts as this will cause the gasket to deform, making it leak again.
Nov 22, 2010 | 1995 Toyota Camry
Replace door seal
its not to easy to do but,,,
look at the bottom of the washer were the door closes the seal is held on with a spring wire,,unhook this wire and fold the seal inside the washer,,look for the inner drum there is another spring wire holding the inner part of the seal to the inner drum undo this as well,, pull old seal out through the door hole,,,now fold new seal so that the inner wire can be fitted round the new seal first to the inner drum,,then pull the new seal through the door hole and fit the outer wire to seal,,,
and then job a good un?,,, not easy a,,well i did tell you this!
Jul 12, 2010 | Frigidaire ATF6000ES Front Load Washer
Wire was sticking out and seal is loose how is it attached
Electric wire? Replace seal there is no adjustment for seal on door. Make sure door is not bent
Mar 09, 2010 | GE Energy Star WCVH6260F Front Load Washer
OVEN USED WITH BROKEN DOOR SEAL, OVEN HEAT HAS GONE INTO OVEN BODY AND MELTED SOME WIRING, STOPPED WORKING NOW. Have bought and fitted a new door seal, what do I do next, can I buy individual wiring parts...
hello sir/mam
good you have changed the door seal but you cant do the wiring because if the wires are fully burnt it is difficult to notyfy which wire is connected to which part of the oven so please call the engineer he will do it.
Oct 04, 2009 | Smeg SUK61MFX Gas Kitchen Range
Replacing a rubber door seal on washer machine
1. Remove door (2 screws).
2. remove top (2 screws at back, sharp slap to front to dislodge).
3. Remove 2 screws holding powder dispenser to inlet valve.
4. Remove 2 screws at front corners securing fascia.
5. Remove fascia and powder dispenser as a unit - note plastic locating pegs on underside and plastic clips locating bottom onto front panel. Take care not to drop one of the rubber seals from valve/powder dispenser joint. Do not disconnect the wiring, just lay the complete assembly on top of the machine.
6. At some point, you will need to release the retaining wire securing the seal to the front panel. This is a thin spring loaded wire. Look after it, you will need it again.
7. Remove two screws at front securing front panel.
8. Remove kick panel - this allows access to two more screws securing bottom of front panel - take these out as well.
9. unclip the wire connector to the door switch.
The front panel may now be lifted from its plastic retainers.
10. The second wire clip can now be removed. The clever clip will need to be released to allow refitting.
11. Thoroughly clean and disinfect the seating for the new seal - you don't want the same gunk growing into the new one straight away.
12. On the drum, you will notice a protruding moulding at about 5 o'clock. There is a matching flange on the seal to help you locate it accurately - start here and fit the seal.
13. Fit the wire retainer - you will need a good pair of long-nose pliers to retension the wire.
14. Reassemble the machine in the reverse order - take care not to mix up the screws! remember to fit the seal to the front panel before refitting the door. Do not release the spring from the wire, carefully stretch it into place.
Aug 27, 2008 | Ariston Technologies AWD120 13 lb. Washer...
Door seal replacement
This video will show you how to change a door seal on this Bosch classics 1200 WFL 2463GB/12 FD
Jul 24, 2008 | Washing Machines
Washing Machines Logo
Sal De
Gerry Harvey
Gerry Harvey
