Question about Sony CyberShot 16.2 Megapixel Black Digital Camera - DSC-TX20/B
My sound when recording videos has become very jumpy--is there a fix for this? Likewise in general my picture is more jumpy and takes a while to focus in when recording videos--these are mostly in lo
I looked at the user manual but couldn't find anything. I checked all the setting re: video--they are set to the highest quality.
SOURCE: Blank Screen and faulty shutter blades
I found out the hard way that you should never use alkaline batteries in a Digital Camera. I thought my camera had a fundamental flaw (power kept going off whenever I tried to take a photo or record a video and the shutter blades half closed) even though it was only 2 months old. I nearly wrote it off but all along the problem was that I was using alkaline batteries, which incidentally were enclosed with the camera in the box!! Once I switched to NiMH (Nickel) batteries the camera worked fine and the fault completely vanished! These NiMH batteries are avaiable in most electrical shops i.e currys/comet in the UK. They must be charged before use. They are more expensive than alkaline batteries (£8-£9 for 4) but as they are rechargable they last a long time.
Posted on Nov 22, 2006
Arpi
  • 326 Answers
SOURCE: Camara won't take pictures, screen shots look black and white blurry
Hello, please try to reset the camera and check your settings according the user manual. If you need more info please advice. Arpi
Posted on Jun 14, 2007
  • 3 Answers
SOURCE: pictures coming out all white?
Check out my posting: http://www.fixya.com/support/t154300-intermittent_green_tinted_pictures_both I think we've got the same problem, and here's the best response that I've gotten so far: Hey...I am having the same problem and I found this link, apparently there is a recall for this problem basically call 1-866-703-7669 http://www.imaging-resource.com/badccds.html Comment by nichole24, posted on Aug 25, 2007 Wanted to add that I called the # and Sony emailed me a Prepaid shipping label to UPS the camera to them and said they will have it fixed and returned to me within 7 business days. I know you posted this problem in June..but I wanted to post this in case anyone else reads this b/c they're experiencing the samething!
Posted on Aug 27, 2007
yjoshi
  • 3 Answers
SOURCE: DSC T70 has no sound on the video playback
Yes... there is a facility to reduce the volume (and to make it mute when the volume is zero.)
On your camera, there is menu button along with 4 buttons. (up, down, left, right). In the video play-back, the up and down keys work as volume control and left and right work as rewind/forward.
Hope this helps.
Posted on Jul 28, 2008
SOURCE: 640(Fine) is not available - Video Recording
i had the exact same problem!! like when u turned it to the video section, it said 640(Fine) rightt?
all i had to do was restart my camera with the chip in it.. for me it went back to normal! hope this helps
Posted on Mar 17, 2009
How do [ clear the hard disk error from my camcorder jvc everio hybrid
in the main menu you can format the HDD, if not possible take out the HDD connect with a dock to your computer, format it.
Nov 27, 2015 | JVC Everio Gz-mg130 30gb Hdd Camcorder...
Why am getting jumpy pictures when I record from the tv and video.
I had the same problem, the only fix I could find was to press later when you dock the archos to the docking station so you view from the archos not the tv.
hope this solves the problem
Apr 07, 2011 | Archos Android 5 MP3 Player
Dazzle DVD Recorder lags when it records, so video comes out really laggy and jumpy, help?
Disconnect your dazzle and reconnect it at the back of your computer. Click on Start>Control panel>system>hardware>device manager>sound and video games controller> right click on video capture device and uninstall it. Restart your computer. Open your IDVDR and then try to check if the same things again.
Jul 05, 2009 | Pinnacle Dazzle DVD Recorder
Rolling of picture
You camera is PAL and you are attaching with Ntsc TV or VCR. Both Pal and Ntsc are different systems and incompatible to each other.
If you want to see correct playback of your Camera, it requires Pal or Multi-System color TV.
Need further info, please let me know.
Oct 04, 2008 | Sony Handycam CCD-TRV68 Camcorder
Black horizontal bars and jumpy picture.
Yes . Some of these caps are in the secondary of the power supply and some are on the signal board around 5v and 7v supply lines on the signal board . The 5 & 7 are mounted on heat sinks and the caps are right around there .Generally either 2.2uf or 4.7uf or the 47uf . Good luck
Dec 19, 2007 | Mitsubishi VS-50705 50" Rear Projection...
No picture when recording,
yoke,Open up the side where the Tape Goes in youll see a Tape Guide,It will have a silver Cap on it with a Straight slot,take you finger and see if it turns easy,the cap I just talked about,What happenn in those cameras is this The set screw will become loose allowing the Tape path to Mis align and the tape does not track properly,It is alignable but it takes Time Hope this he;ps ttech
Jul 20, 2007 | Sony Handycam CCD-TRV328 Camcorder
Video Jumps on Screen
Sounds like the cleaning job wasn't good enough to get all the dirt. Try a Panasonic cleaning tape; if that doesn't work, find a local repair shop to do a good hand cleaning.
Jun 22, 2007 | Panasonic AG-DVC7 MiniDV Proline Camcorder
Picture is jumpy and expands
Right now it should not be expensive to repair but dont use it anymore or it might become worst,sound like loose conections in the horizontal circuit ,seek assistance it should not be expensive to correct.
Oct 01, 2006 | Panasonic PT-61G54 61" Rear Projection...
Timer hops around on playback and No sound!!!
Hello brother Frist of all clean battery contacts and then run a good head cleaning cassette for 5 sec. only. I think this will solve your problem All the best Uday
Aug 30, 2006 | Panasonic NV-DS29B Mini DV Digital...
Sony CyberShot 16.2 Megapixel Black Digital Camera - DSC-TX20/B Logo
91 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
