Question about Yamaha Yst-r7 Receiver
How to change channels without the remote - Yamaha Yst-r7 Receiver
How do I change from channel 4 to channel 3 without a remote control?
Why not purchase an inexpensive universal remote and use it to operate your Emerson TV?
Jul 30, 2015 | Emerson Televison & Video
How to change the channel on a pANASONIC pvdf 2704 without a remote?
Without remote control, there is no option to change channels.
Aug 18, 2013 | Televison & Video
My toshiba 27a45 tv says video lock when i change it to channel three how do i unlock it without the remote
To get more details about how to unlock Toshiba TVs, visit this site ,Electro-help'.
Jun 08, 2012 | Toshiba 27A45 27" TV
How can you change to channel 3 without remote?
U only can now used those buttons like channels + - for channels,it will alway skip channel 3.U can't get channel 3 if channel 3 is not in ur tv save memory.Try website like Remotes.com to buy the tv original remote to used.
Jun 30, 2011 | Daewoo DVQ13H1FC 13 in. Combo
Changing from line to channel without remote
Usually there are buttons on the set, these are used to do all the remote can do... You usually have a menu, button and the others scroll you through, up or down, setting by repeated presses,and there is also an "OK" button too...
Feb 25, 2010 | Daewoo DVQ13H1FC 13 in. Combo
Need to change tv to channel 3 without remote!
go to menu and see if you have channel selection on go down thaT way. you should be able to program it in.
Feb 16, 2010 | Televison & Video
When using remote to adjust sound or to change channels sound continues to go to extreme low or high and when changing channels they keep changing in sequence without using remote
This may be because of your personal preferences settings for channels. Try to adjust the personal preferences of each channel according to your wish. Most remotes have the options to set personal preferences.
Feb 06, 2010 | Vizio Televison & Video
Getting a specific channel on the TV without using a remote
Usually if you go into the setup menu, there is an option to allow you to either "scan" for a channel, or "input" a channel. In this case, select "input" and see if the TV will allow you to press the up and down channel buttons and go to a specific channel. If so, when you get to channel 4, press the "add this channel" option (or whatever the menu option says) and you should then be able to go to channel 4 using the buttons on the front without skipping over it.
Jan 24, 2010 | Televison & Video
Child lock is on lg tv and have lost the remote
My child lost the tv remote and we have the child lock on so we can;t change the channel or the volume. Do you know how to turn it off without the remote?
Apr 10, 2009 | Televison & Video
Change channel without remote
Hi , there is a button on your tv set near the channel button. that will set your tv to video.
Dec 31, 2008 | Sanyo DS27930 27" TV
Yamaha Yst-r7 Receiver Logo
85 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
