Question about Pittman Products Air Mattress Pittman Products PPI-102 Air Mattress
I have a pittman queen bed with built in pump when it is inflated and II turn the pump of the air just come right back out the valve. what can be done to fix that? its only a couple years old.
Electric air pump model HT-628 intertek 3135568
Air leaking from cap on Ozark air mattress
There should be an internal one-way inflation valve that prevents leakage. The valve may be failing to close completely.
Aug 24, 2016 | Ozark Trail Velour Top Airbed Kit Queen
What do i do when my intex inflatable mattress makes a popping noise and gets bigger on one side?
Sounds like one of the inner chambers is broke, If that's the case you will have to replace the mattress.
Jun 17, 2014 | Intex Comfort Queen Air Mattress - Raised...
I got a Swiss gear queen size bed ans it's got a hole right on t he top of the bed on a seam, the patch that came with it is not working in sealing the hole, what else can I use?
You could try some seam weald glue.
But when these leak from a join, it can be very very hard to reseal them.
You could try a hot soldering iron, carefully try to reseal.
But to be honest it may be easier to purchase new.
May 12, 2014 | Swiss Gear SwissGear Queen Raised Double...
Inflatable beds
It's blown an internal weld in a bladdrr. Nothin g you can do but take it back
Jan 22, 2014 | Computers & Internet
Top of bed has a small hole
use Bubble gum or a ready made puncture for i t
Dec 10, 2013 | Intex Ultra Plush Queen Air Mattress Bed...
What is an air bed?
An air bed, also known as air mattress, is aninflatable mattress (usually by hand). These beds are mainly used at home forguests and come in standard s (queen, king)
Jul 30, 2012 | Furniture
It leaks throu the pump
i've never heard of an inflatable bed that you leave the pump hooked up to. I would suggest pumping it up removing the pump and put the plastic plug back into where the pump was attached
Jul 14, 2012 | Intex Rising Comfort Queen Inflatable Bed...
Our bottom dish drawer won't open...Help!
the air gasket is still inflated. There is a small air pump that inflates the seal, and another valve that opens to relase the air. if you can pull the machine out, there is an acess door on the back that you can get to the release valve. disconnect the small hose and it should deflate. the valve and air pump come a a two piece replacement kit
Jul 10, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Pittman Products Air Mattress Pittman Products PPI-102 Air Mattress Logo
1,154 people viewed this question
Top Pittman Products Air Mattress Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Pittman Products Air Mattress Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
