Question about Building Materials
Have i/3hp motor runs but door won't open think it's off the track, how do I get it back on track
Nothing I think that the track is off but I don't know how to fix it
    Sergeant:
  • 192 Answers
It may be that your torsion spring is broken. Look at the spring about the door opening. It is horizontal, and should be in one piece about 30" long. Sometimes 6" breaks off and then the spring will not counterbalance the door and the motor will not be able to move it. If the spring is ok, then release the emergency pull rope, red handle. Now move the door up and down by hand and see if it is jamming somewhere. Be careful not to stand directly under the door with the emergency cord released.
Posted on Dec 22, 2014
I got a 2000 Pontiac trans am and every time I turn the car on the driver side window will roll down and it won't roll back up. But the passenger side window works fine. And when the stereo works the...
How about when the radio is on & the key is off or
in your hand,if you open either front door does the radio go off
& do you lose the delayed window feature assuming you have that
If so you problem is a delayed accy relay
Next would be the front door switches
I will give you credit for what you tried
but fail to see why you would switch motor
from door to door,they work powered directly or they don't
I would think your battery would have gone dead by now
if the relay failed to time out or go to sleep
Jul 27, 2013 | Cars & Trucks
Power window won't go down but you can here the motor running in the door
You can remove the door handles and power window switches and the screws in the door pad and push up on the pad and it will come out of the track and then you can see the motor and replace the part yourself. Hope this helps.
May 05, 2017 | Chevrolet Camaro Cars & Trucks
Motor won't stay running
This maybe the Run capacitor. If not handy, remove and bring to a motor shop as some capictors are internal!
Mar 07, 2013 | Delta X5 3Hp Left Titl Unisaw with...
Garage door won't go down all the way and then reverses to open
Check that the wheels and bearings are turning freely and that the door is not cocking to one side when closing. If the wheels are catching because of bad bearings, because the tracks are out of true or because the door is not staying straight in the tracks, the motor thinks that the door is hitting a car or a person and reverses. One thing to try: disengage the motor and try moving the door through the full traverse. Most automatic doors have a pull-cord that disengages the door from the motor. CAUTION: You may need a friend to help with the door, because it could be surprisingly heavy,.
May 01, 2017 | Chamberlain 3/4-HP Whisper Drive Plus...
Sears Craftsman 1/3HP garage door opener problem
If motor continues to run but no chain action check for missing chain tooth or cam gear worn.
Sep 22, 2017 | Sears Craftsman LiftMaster Chamberlain...
Passenger door window not on track
There are no tracks on windows
On the verticle sides you have window guides
Inside the door is a window regulator & motor assy
that puts the glass up or down
Have to remove inner door panel to see what needs
replacing
Do not just put it back together it won't work a day
Some have cables some have a sizzor type mech
Nov 19, 2012 | 2000 Dodge Caravan
Dishwasher won't run. keypad buttons light when pushed, and I've locked and unlocked the keypad, which seems to be otherwise functioning normally. It has been working fine until now. I push...
Hello, welcome to FixYa. If you can provide the model number (usually on inside of door frame or tub frame around door opening) and make/brand name, I'll see what I can find for you. It does sound like a door switch, but I'll need to clarify the make & model before moving forward. Regards, Macmarkus :)
Jun 04, 2011 | Dishwashers
Building Materials Logo
46 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
