Question about Candy Refrigerators
How do I fIt the integrated door to candy cru160ek? Does it need to attach to the carcass?
Can't seem to work out how to fit to fridge
3 Suggested Answers
SOURCE: fitting an integrated fridge freezer!
Hi Gareth. I fitted a door to my Hotpoint hsz2321L today. I used self tapping screws through the brackets into the fridge door sides. Looking at the old fridge that came out showed that this was the method used previously. No seal is broken and so the fridge is working perfectly. I do have an issue re-fitting the door onto the new fridge though. The pivot hinge on my fridge doesnt give enough clearance and so it catches on the unit at the side of it. The old fridge (a Bosch) cad cabinet hinges that would sort of concertina out to give clearence. Anyway, good luck.
Posted on Aug 01, 2009
  • 64 Answers
SOURCE: How do I get the dimensions for a fridge freezer?
Looks like they are the same outer dimensions.
Old:
New:
  • Width of cavity: 560 mm
  • Height of cavity: 1772-1776 mm
  • Depth of cavity: 550 mm
http://www.appliancesdirect.co.uk/p/ckbc3150euk/candy-ckbc3150euk-integrated-fridge-freezer#maindesc
Posted on Oct 06, 2014
Old:
New:
Oct 06, 2014 | Refrigerators
New door fitted on Larder integrated fridge but door alarm sounds inspire of door being closed.Digital display indicates door open.
The old door had a hidden trigger that signaled when the door was closed.
You need to retrieve the trigger from the old door and fit to the new door.
Mar 31, 2011 | Electrolux Refrigerators
Hotpoint fridge freezer / howdens kitchen - no instructions!!
Luckily the hotpoint helpdesk admitted that the instructions for hanging the kitchen doors does not come as part of the standard instructions. There should be a seperate piece of paper with these instructions.
After some to'ing and fro'ing they managed to email me the required diagram.
Feb 05, 2009 | Refrigerators
Fitting an integrated fridge freezer!
Nov 23, 2008 | GE Profile GCG1700LII 15" Built-In Trash...
Ice is building up on the back wall of fridge
Option 1 defrost fridge manually by switching off power for 24 hours, allowing built up ice & frost to melt.
Option 2 Switch off mains power and using a hair drier blow hot air into the freezer supply vents. This shuold shift the ice in a couple of hours
Nov 12, 2008 | Candy CPCA240FFK Bottom Freezer...
Lights out & fridge freezing after switching off and moving it
a servicing expert told me when bulb goes can cause a failure on control board. others confirmed control board failure occurs often and the only other part that goes is the compressor (and thats really expensive to repair!). control boards can be fitted yourself - mine cost about £50.
Mar 04, 2008 | Candy CPCA240FFK Bottom Freezer...
Candy fridge freezer
check that the correct thermostat is installed and that the element wire is connected.check door rubber and door hinges.check if it has independant defrost timmers and if it is working.oh and see if the element is drawing current if fitted with one.
Nov 05, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Refrigerators Logo
95 people viewed this question
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Cesar Quant
Cesar Quant
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
