Question about Logitech UE Smart Radio
I cannot hear one Radio Station Radio 702 all others o.k.
Tried everything. What Shows up on the Screen is 401 not Authorised
I have a 2006 Mercury Mountaineer I recently had my transmission rebuilt Now my radio's touch screen does not work Only shows Mercury Symbol. hear it but can't change station. Now no sound .Help
You need to input the radio security code because the battery was disconnected. If you don't have it see the Ford dealer (about $100.00 charge) or go here www.radio-code.com
Dec 31, 2016 | 2006 Mercury Mountaineer
Radio stations
There is a radio option to recalibrate your touch screen. Please press the following three hard keys simultaneously RADIO/MEDIA, SEEK UP, NAV (AUDIO on REN). Once you begin to recalibrate the touch screen you must finish. Audio confirmation prompts are provided for each of the three points of calibration, one beep for the first, two for the second and three for the third. The calibration needs to be precise as possible and a PDA stylus would be recommended. The MyGIG radio requires the user to repress each calibration point to confirm the calibration process. A green crosshair indicates proper calibration.You must not start with the "+" but with the "+1", then goto "+2" and last to "+". Repeat this until all crosses are green and exit with pushing the menue or any other key. Done
Jul 20, 2012 | 2008 Dodge Grand Caravan
Radio works on one station all other controls apart from volume seem frozen wont search for other stations,x-bass wont work and screen shows t>je:xw can anyone help.tried switching on and off tried...
you may have a bad switch. sometimes if a switch does not close completely, the microprocessor thinks it is getting a command and will not respond to anything else, locking it up.
Mar 02, 2011 | Blaupunkt San Remo CD32 CD Player
What staion do i put my car radio on
You need to manually tune your radio on FM to whatever frequency you have chosen on the tune cast.
Feb 28, 2011 | Belkin F8Z209 TuneCast Auto and Dock...
How do i program the radio
Click below for the manual.
manual
1 Select the radio band and tune in a desired radio
station you wish to store in the preset memory.
2 Press (PRESET).
The Preset screen is displayed.
3 Rotate the Double Action encoder to select the
preset number.
4 Press and hold /ENTER for at least 2 seconds.
The selected station is stored.
The display shows the band, preset number and station
frequency memorized.
A total of 18 stations can be stored in the preset memory (6 stations
for each band; FM1, FM2 and AM).
If you store a station in a preset memory which already has a station,
the current station will be cleared and replaced with the new station.
Press in the outer ring and rotate the Double Action encoder to the
left or right on the Preset screen, you can switch the Preset screen of
another band.
FM-1 FM-2 AM FM-1
You can also change the desired radio band by pressing BAND.
Hope this helps.
Zeppelinx12
Feb 25, 2011 | Alpine iDAX305 MP3USB Car Radio Car CD...
I accidently did something the display for the clock/radio ??!!! the display previously show time display & now it shows the radio station name RE: the radio station I listen to is 105.7 (KHCB) and ...
continually press/release the center of the tuning know until you have the preferred display you want and then press and hold the same button until the system beeps (1-2 seconds). It will now save your preferred default screen (clock in your case)
Jan 14, 2011 | 2006 Pontiac G6
How do i get the radio to work
Besides playing your favorite songs and custom playlists, you can also listen to your favorite DJs and talk shows on your iPod Nano by using it as a radio.
The iPod Radio Remote is a small and convenient accessory that lets you tune in to live radio when you're on the go, and also allows you to remotely control your iPod. Here is how you can easily setup Radio Remote on your iPod Nano and start using it as a radio.
  1. Connect the ipod Radio Remote to your iPod Nano by plugging it into the dock connector. Plug your headphones into the port at the top of the Radio Remote, next to the hold switch.
  2. Once the Radio Remote is connected, select "Music" and then "Radio" on your iPod. The Radio Remote will automatically tune in to the first available station it finds. The iPod screen will show the radio station and any other available information or data.
  3. Press the center button on the iPod. Use your iPod click wheel to find other stations. Once you have found your favorite station, hold the "Center" button down until a triangle appears on the radio dialer on your iPod screen.
  4. Once you have set up all of your favorite radio stations, use the "Next/Fast-Forward" or "Previous/Rewind" buttons to navigate between them.
Good luck.
Apr 28, 2010 | Apple iPod nano
Uniden Phone 5.8 Ghz- I hear a spanish radio station
depening on your location if you have no interuption from other freqency from other leaking environment you r hanset may have a manufacture sorftware or hardware problems if you try another hand set wiht same problem posible a decfive ..
Oct 01, 2007 | Uniden TRU8885 Cordless Phone
Logitech UE Smart Radio Logo
46 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
