Question about Jeep 2004 Grand Cherokee Limited 4WD
Cam shaft timing marks
Put marks wrong
    New Friend:
  • 25 Answers
The cam shaft timing marks should line up this is the process to doing a tune up . if you do not have the proper tools or knowledge, they will not line up , get a professional to do this , if you knock out your timing your car will not run, and then that would be the beginning of your troubles.
Posted on Dec 07, 2014
PLEASE HELP!! I have a 2002 Pontiac Grand Am 2.2L & I installed the new timing chain as follows. I installed crank key @ 12'o clock, timing mark on cam at 5 o' clock, inatke cam shaft @ 2 o'clock,
All of the shafts have a specific relationship to each other its controls ware the pistons and valves are when the engine fires TIMING .
You need to find T.D.C top dead center on #1 cylinder so its at the top of its stroke in compression stroke then redo what you have just done and it will work .
Apr 05, 2018 | 2002 Pontiac Grand Am
I got codes but put new one in and still say the same thing. Codes p0012 p0022
The codes your getting say your mechanical timing is wrong! Your cam shafts are out of position, (over retarded). Get the mechanical timing checked as the timing marks might be set wrong. Get the electrical timing checked as well as that might be affected.
Mar 25, 2018 | Cars & Trucks
How do I retime my engine
The cam shaft should be keyed so the gear cannot be wrong. Look for a mark on the gear and one on the head. Line those up. On the crank shaft use the timing mark and guide and line up to TDC or 0 and put the chain back on.
Dec 08, 2014 | 2000 Mazda MPV
How do i set timing chian marks
The marks are on the crank and cam gears. They either have a mark on the head that coincides with the mark on the cam gear AND you set that AND then bring the crank shaft gear to TDC on the timing marks OR you have both marks on the gears and you line them up with each other using a straight edge through the center of the shafts, then you put the chain on.
Jun 03, 2014 | 1997 Nissan Maxima
Wrong cam shaft crank shaft timing
hmmm check cam and crank pulleys for stamped dot and use straight edge to line up and have # 1 cyl TDC and and both valves closed on #1.............
Mar 18, 2014 | 1952 Bentley R
Timing chain marks needed for Audi A4 B9 1.8tfsi 2009 model. Engine was taken out and settings not marked. This is extremelyurgent. Please help
diagrams I have show a twin cam set up with 2 balancing shafts. The marks on the cam shaft point to (left cam shaft 11 oclock the mark on the right point to the 1 oclock position. The chain will have 3 black links-- the top black links will be at the timing marks on the shafts with the 3rd black link directly at 6 oclock facing a mark on the gear. The balancer marks both point to the 1 oclock position with black links on each and the 3rd black link will be facing a mark to the 7 oclock position on the crankahaft gear. Everything is done with the piston at TDC no 1 cylinder so get it there before you put the cam shafts in position or you will bend valves. Crank shaft gear is not keyed to the crank shaft. there are dots on the right hand balancer shaft gears and these dots will be as the 2 dots on adjacent teeth either side of a dot on the meshing gear. I suppose that is all as clear as mud but if you got this far then you will see the marks and marked links on the chains
Dec 22, 2013 | Cars & Trucks
How to set timing when you relesh tensioner and it changes the alignment postion of pullies 2000 ford ranger 2.5 l
Here is the trick. Align marks. Put the timing belt on the crank shaft pulley first, and after on the overhead cam pulley. Release tensioner and rotate the crank shaft till the timing belt makes two full circles. Try to align marks, you will be at least one tooth off. Align the crank shaft on the mark, and find out how many teeth you are off at the cam shaft pulley. Count the teeth. Remove the timing belt from cam shaft pulley only. Move cam shaft pulley in reverse according to the number of teeth you counted. Make sure the crank shaft pulley is on the mark. Mount the belt at cam shaft pulley.Rotate the belt two circles and check the marks. Repeate this procedure til after releasing the tensioner, and rotating the timing belt two full circles, the mars will be align.
Nov 22, 2010 | 2000 Ford Ranger SuperCab
How do i time my Golf 1 correctly? it consumes a lot
its tricky enough if your not sure what your doing but ill run you through it. 1. remove top rocker cover and timing belt cover. 2 make up the position of the pully on the cam shaft at the top and the drive shaft at the bottom, this marks are you fail safe incase you cant time the engine. 3 remove the timing belt and pully tentioner, note if your going this far you are as well to replace the timing belt,tentioner and water pump. 4 On the cam shaft at the top if you force them to turn you will see a small indicator mark on the shaft this mark has to line up with the other indicator mark on the housing between the cam shaft and the cam shaft pully, once they line up your top end is timed, mark up the pully incase it moves. 5 on the drive shaft pully there is also markings that have to line up but you can also feel the position of the pully as you turn it, you will feel the piston been forced up and it is timed at top dead centre on cylinder one, which means the the piston has to be at the top just before the point of returning back down, using your feeling as a guide and the markings lined up you will have timing. also mark up this pully, your new marking should be very very close to the fail safe markings you put on at the start. when you have your marking replace the timing belt with the longest distance between pully contact going on first, try not disturb your timing or your hard work will have been for nothing, make sure the tentioner on the belt is tight but not to tight to the point where you ll stretch the belt or snap it, put everything back as you found it and crank the engine, job done, best of luck. hope this helps( rate me on my answer thanks )
Aug 27, 2010 | 2000 Volkswagen Golf
Timing alignment for 2200
put it on tdc
and go from there
tdc top dead center
May 09, 2010 | 2001 Chevrolet Cavalier
1996 Diamante will not crank after changing water pump
I aligned the crank shaft,,water pump pulley. and the cam shaft marks up and recheck the origninal marks I made to save time....one of the cam shafts had slipped enough to cause it to be "off time" and the computer could not correct for it...realignment of the marks and making sure nouthing changes was the solution..
Jun 03, 2009 | 1997 Mitsubishi Diamante
Jeep 2004 Grand Cherokee Limited 4WD Logo
69 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Oloyede Monsuru
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
