Tried clesning bannanna plug
What did you clean them with ? water?, bad move. you should only clean your electronics with acceptable electronic cleaning solutions,
or Rubbing Alcohol on a lint free wipe very lightly saturated then swing the cloth around in the air for a few second to make sure its not dripping wet, but very lightly damp. then make sure all units are off with no current flowing through. also make sure that you DO NOT turn them on straight after let them dry completely. ( when applied to items should see a streaking not an overall wetness.(if overall wet, you've used to much) drying time is based on wetness.) Use hair dryer if necessary.
Good Luck, try the dryer on the headphones. including the tablet plug in area. you might have gotten water in it.too!
