Question about Refrigerators
I have a roper refrigerator model # rs22aoxmo01 and the water dispenser just started to leak water out as if the button was pushed in what could be wrong
SOURCE: GE Refrigerator model #gss25sgress Water dispenser problem
What you describe was a common problem with this model and one that still pops up. Your refrig *might* qualify for an upgrade under terms of a program GE initiated a few years ago. Call 800-432-2737 first it might save you a service call
Posted on Jan 06, 2008
aasc
  • 1606 Answers
SOURCE: After 3 years we have ice but no water from the dispenser
Remove the bottom kickplate and the hose at the bottom of the door goes underneath the refrig about 3 inches , to a hose connector . Push in on the end of the connector and pull out the hose . Close the freezer door and press water . If water comes sprays out from hose under frig , then your door is frozen internally .If no water sprays out of hose , then your watervalve is bad . One coil is for ice and the other is for water but they come togather as one.
Posted on Jul 19, 2009
  • 36 Answers
SOURCE: Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Posted on Jul 24, 2009
arikrom
  • 528 Answers
SOURCE: ge model 20, 22, 25 side by side refrigerator. A
there is a mother board in the back that go bad the clicking to hear is the micro switch on the board try to cick in but when they go down you need to replace the whole board :(
Posted on Jan 02, 2010
Testimonial: "This was very helpful. I have scheduled repair. Thanks a bunch!!!!!!!!!!!!!!!"
SOURCE: My maytag MSD2556ae side by side refrigerator water/ice dispenser
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
Posted on Mar 11, 2010
Does my roper fridge have a water filter? model rs22aqxmq01 serial st26598
Not all fridges with water dispensers have integral filters. Several have an external in line filter fitted to the supply pipe.
Jul 13, 2014 | Roper RS22AQXKQ Side by Side Refrigerator
Water dispenser leaks
Refrigerator Water Dispenser Leaks?
Refrigerator Water Dispenser Leaks show that the refrigerator's water system has a problem. To fix this problem, open the filter compartment and pull out the filter and push it back in so that it is secure in place. Push compartment cover until it clicks.
try to check this video.
May 13, 2014 | KitchenAid Superba Architect KSCS25INSS...
Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
Jul 11, 2012 | Whirlpool Refrigerators
I push the water dispenser and no water comes out but comes out at the bottom?
The hose to the water dispenser up front cannot be connected and it is spilling the water onto the floor when the solenoid is activated.
Jul 13, 2017 | LG LSC26905TT Side by Side Refrigerator
How do I replace the water dispenser tube for a Kenmore Coldspot model # 106.53769201. The end of the line disintegrated at the spot where you put your glass under the dispenser.
Ice makers and water dispensers are convenient to have on your refrigerator, but can also cause a lot of aggravation if they are not functioning properly.
If your water valves are not defective and you are still experiencing water or ice delays, you may have a clog in your refrigerator hose line.
Instructions and material needed to fix it up.
  • Towel,Flathead screwdriver,New water hose
  1. Turn off the water supply to the refrigerator and place a towel under the line to soak up any residual water that leaks from the hose when you remove it. Unplug the refrigerator.
  2. Disconnect the hose from the back of the refrigerator by pushing in on the collar while pulling the water tube out. If you have a model with an ice and water dispenser, you will need to disassemble the dispenser on the front of the freezer in order to completely remove the water hose.
  3. Remove the water drip tray from beneath the ice/water dispenser and locate the screws at the bottom of the cover (if any). Remove screws and pop off the panel that houses the dispenser. If the unit does not have screws, you will need to pry the cover off with a flat-nosed screwdriver.
  4. Once the cover is removed, you should be able to see the screws that hold the dispenser unit in place. Remove these screws and reposition the unit so you can free the water hose, by pulling it through the dispenser.
  5. Thread the new water line through the freezer door and reassemble dispenser unit. Push the new water hose into the fitting on the back panel, making sure it is properly seated. Turn on water supply and check for any leaks before moving the refrigerator unit back against the wall.
Good Luck and thanks for using fixya.
Jan 16, 2011 | Kenmore 57029 Side by Side Refrigerator
Water dispenser won't stop. It started automatically and water keeps being dispensed even though we tried pushing the ice button and the lock button. It stopped when I opened the freezer door but would...
I take it this is a G E refrig ? Model number would have helped . If you still hear a hum with door closed , the microswitch behind the dispensor board is bad . Not a computer problem but a simple fix .
Aug 12, 2009 | GE Profile¿ Arctica® Energy...
My maytag MSD2556ae side by side refrigerator water/ice dispenser may be locked. Is there a method or code to unlock. The water dispenser started shooting water out with no warning and the dispenser light...
Jun 10, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Water is leaking in side the freeze
It's the pump for the icemaker/water dispenser. When it goes bad, it just starts pumping water into your icemaker until it overflows into your freezer. You simply have to replace the pump. It's happened to mine twice.
You can very easily replace the pump yourself in about 3 to 5 minutes, and the pump only costs about 48 dollars.
Here's a link to the cheapest place to buy the pump: http://www.easyapplianceparts.com/MultiModels.aspx?ModelNum=RS22AQXKQ&searchTerm=&RefineSearch=0
The first time I had this repaired, the repairman charged me over 300 dollars. I did it myself the last time. All I used was a pair of pliers.
Jan 03, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
I think I would think about getting a new one. It would cost more to fix it and then you may not get it back together so it wouldn't leak.
Dec 21, 2007 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
