We have a marco df 41d fireplace. The manual says it can be converted to gas with the installation of a gas line and gas logs. We don't have a non combustible hearth, do we need to add one?
4 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: Marco gas fireplace shuts off
This an easy fix. What you must do is remove the dust from the pilot safety. I use rust buster from ace hardware to gently flush the hole. If ther is no hole just shoot a tiny drop or 2 into the pilot burner where the flame comes out. Blow it out (I use a piece of tubing). The problem is the dust drops the pilot flame to a point where it won't heat the thermocouple hot enough to jold the magnet and after 30 minutes she quits. THIS is a picture of where to clean the ODS pilots in your rig.
Posted on Feb 09, 2009
  • 2522 Answers
SOURCE: How change a Marco Fireplace from wood burning to gas logs
HI best get as gas fitter in to look at this and see if it can be done safer bet
Posted on Feb 25, 2010
occdoc7
SOURCE: bought house with MarGas Custom 36 Firesplace Stock #794015, Model MGC36SPNGCF and the previous owner tookk the log set. I need a new log set but the company Marco Mfg is out of business. Please tel
Dan Webster's pilot fix worked. Pilot now is blue and stays lit. Main burner still does not fire, so next step is new thermocouple.
Posted on Nov 25, 2012
Need manual for marco fireplace model MH 9245
This company is out of business due to massive government recall. I could not find a manual online for you.
CPSC Marco Alert Consumers to Gas Fireplace Recall Due to Fire Hazard
Nov 17, 2016 | Heating & Cooling
Where is the thermocuple on my marco gas fireplace
Fireplace Pilot Light Tutorial - YouTube
? 5:06
https://www.youtube.com/watch?v=Moa7eGlKCr4
Nov 12, 2012 - Uploaded by FogoFox
This video walks you through the process of turning on the gas to your fireplace, lighting ... Lighting a Gas ...
The thermocouple compared to the thermopile. - YouTube
? 6:01
https://www.youtube.com/watch?v=dRjX5m0zHUU
Oct 16, 2013 - Uploaded by grayfurnaceman
I got an 1980 gas fireplace, I just see the pilot and something that look more ... My land lord purchased a ...
Marco Natural Gas Fireplace (Model B36CFI) won't turn on ...
Download MARCO GAS FIREPLACE MANUAL PDF ...
? 0:16
https://www.youtube.com/watch?v=lJyHdPywr0M
Jul 31, 2015 - Uploaded by Roscoe Sikes
Download MARCO GAS FIREPLACE MANUAL PDF ... How to Safely Light Your Pilot on Your Gas Fireplace ...
Dec 07, 2015 | Heating & Cooling
I have a gaz fireplace Marco DWF36CF-3 vented and would like to know if i can burn wood in it
My name is mike. YOU DO NOT want to attempt to burn wood in a gas fireplace. The reason for it, is the venting is not designed for the fumes and high heat the wood produces. Only way you can safely burn wood, in a gas fireplace is have to make sure the piping and venting is set up correct to burn wood. Your problem is not most likely your stove or fireplace for the safety, it would be your venting. Thanks Mike
Oct 22, 2011 | Heating & Cooling
In cleaning my gas-fired Marco fireplace, unsure original base configuration, mine has only burned out mineral wool pieces. The metal flat base has a row of small ports along the front. A single row of...
Unfortunately, you didn't list the model number of your fireplace and whether it's vented or vent-free. However, I suspect it's vented, as MARCO (now out of business) manufactured very few vent-free models. Restoration is going to depend on the condition of the burners, as well as the gas control valve and the condition of the firebox. The small ports you mentioned, are for the Rock Wool (Glowing Embers), which are divided into small pieces (dime size) and fluffed, then placed over the small ports. MARCO did not make a vented fireplace where silica sand was used on top of the burners. Normally, you only see that on vented gas log set, that is installed in a solid fuel burning (masonry) fireplace and operated with the damper fully open.
As far as restoration parts are concerned, I seriously doubt there are any available. MARCO, as such, has been out of business for almost 10 years. Today's burners are not designed for the same configuration that you have. It wouldn't be wise to try to change the configuration, as the firebox was tested and approved for only what's in there now.
Wish I had better news for you. But, my 15 years in the hearth and home business, tells me it would difficult and costly to do.
Apr 23, 2011 | Heating & Cooling
We have a Marco fireplace and the damper does not shut. I push the leaver inwards but nothing catches to keep it closed. We purchased this house and the fireplace was replaced with Gas Logs but still...
when the gas logs were installed the vent damper should have disabled. it sounds like this was done.it is unsafe to close the damper with gas piped into the fire place. sometimes a "u" block will be placed over the damper blade. if the gas has been removed and not piped into the firebox anymore it would be safe to remove this
Jan 27, 2011 | Leisure HOMEPRIDE Electric Fireplace...
Marco fireplace Model#792775D Instruction manual
Ok, I have a Marco Model 792775D. I am renting the house and there is no manual for it. How would I use it. Is it supposed to be fake logs or is it for real logs. The land lord said he didnt know if it works. I need a manual for it. PLEASE HELP!!!
Oct 23, 2010 | Heating & Cooling
I recently bought a house w/ a Marco gas fireplace and there is no owners manual. I have never used a gas fireplace, so I have no experience with this. I would really like to get an owners manual, but...
www.macro-fireplace.net is the manufacture's website where you can request a manual for free.
I haven't located any others but I will keep you posted if and when I find one.
Nov 08, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Dec 14, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Marco fireplace log placement
To help you out:
you can go to www.marco-fireplace.com
They will either have it online or refer you to a contact person.
Fireplacegirl
Mar 20, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Marco gas firplace
I have a Model 792864B. Before you attempt to light the pilot light - make sure that any wall control switch or remote control for the fireplace is in the off position. Locate the gas supply line. There should be a gas supply valve to turn on the gas supply. The valve is usually painted a different color than the supply line like blue, green or yellow. Open the valve by pivoting the handle to be parallel to the gas line, usually counter-clockwise. When it is closed it is at a 90 degree angle from the supply line. Locate the pilot light assembly - this is the pilot light. There should also be a red or black ignitor button and a black or green valve control knob with the words "on" "off" and "pilot" on it. It may be located inside a black box, mine is marked heatolator, that has a lift off top. Lift off the top of the box. Push in the valve control knob and turn it until the word "pilot" is in line with the arrow (my arrow is red) or indicator line. While pressing and holding in the valve control knob - it presses in about 1/4", press the red or black ignitor button repeatedly (once per second) until the pilot ignites. Once the pilot is lit, continue to hold the valve knob in for about 30 seconds and then slowly release. The pilot should remain lit. If it remains lit, press in and turn the valve control knob to the "on" position. The on/off wall or remote control switch should now light your fireplace. If the pilot doesn't ignite, turn off gas supply valve, wait about 5 minutes and try it again.
Nov 20, 2007 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
70 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
