Question about Air Tools & Compressors
Need the assembly schematics for Campbell-hausfeld compressor model no.WL600700AJ
Relay switch that controls the compressor kicking on and off quit working i got a new one and i need the schematics to put the new switch back on right
  • 8 Answers
SOURCE: Campbell Hausfeld Air Compressor auto shut off switch not working
i have the same one and mine was broken by my kids , i had to replace the entire component, DONT RUN COMPRESSOR with out the regulator working IT CAN EXPLODE IF OVERFILLED,a must fix situation i believe i got mine from sears , a great unit ive used it painting and with many air tools over many years now , well worth fixing mine is a little loud but dependable good luck.
Posted on Mar 15, 2009
  • 234 Answers
SOURCE: air compressor not working
If your motor is running and not the pump, the malfunction is either in the pump or the coupling between the motor and the pump.
Some of these compressors are manufactured so cheap now that there can be just a set screw that is loose and the motor shaft is spinning free inside of the crankshaft.
If you drain the oil out of the pump and take off the pump crankcase cover, you should be able to see the problem.
Posted on Apr 15, 2009
  • 10 Answers
SOURCE: i need to get an operators manual on campbell
It's a "6" series
http://www.chpower.com/webapp/wcs/stores/servlet/XItemDocuments?storeId=10051&langId=-1&catalogId=10001&findModel=WL6515
Posted on Oct 16, 2009
SOURCE: Need a copy of a manual for an air compressor
Go to Campbell web site,then call them
Posted on Jun 01, 2010
  • 3 Answers
SOURCE: Replace AC charger for Campbell Hausfeld CC2300 Cordless Compress
After opening the unit up, this info I found out about the rechargeable battery.
*GS Rechargeable Lead-acid Battery (Portalac) PE12V7A (12v 7Ah) - sealed lead battery*
I hope that info help you, or someone, if you got a 12v 7AMP tip positive DC wall adapter, that thearadacly(sp?) will charge the battery, but I'm doing guess work since I don't know much about the AMP in voltage stuff.
I tried my best.
Posted on Oct 31, 2010
Model hg30000. Why is it getting "stuck"?
many times when things sit unused the switches corrode and need either cleaned or replaced
Oct 08, 2015 | Campbell Hausfeld Air Tools & Compressors
Hot WL611200 air compressor
Campbell Hausfeld WL611200 Oilless Air Compressor This is an oil less compressor. Yes compressors do get quit hot. That's normal. Just keep the fins clear.
This
May 21, 2014 | Campbell Hausfeld FP2028 1 Gallon Air...
Does not on after when disired air pressure is depleated
thats the main problem with campbell 8gal compressor. its the control box. the black box on the top of the tank. theres a solenoid in there that the air pressure kicks off and on. they are known to short out. you can go to campbell website and order a new one.
Jul 08, 2011 | Campbell Hausfeld 8GAL Air Compressor
Could I have blown a fuse on my Campbell Hausfeld compressor
your compressor does not have a fuse, look on the side just under the plastic cover.there should be a small c/b switch, just push it in. should work.
Jan 03, 2009 | Campbell Hausfeld 26 - Gallon Air...
Air Tools & Compressors Logo
52 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
