Question about Stoves Ovens
The knobs have come off and they will not fit back on. It look like they have broken. How can I trace replacements.
Rang Stoves but they say it is am obsolete model
  • 24 Answers
What Make and Model is the Oven?
Posted on Dec 07, 2014
Testimonial: "Thank you for getting back so quickly. It is Stoves 700DFa Model no. 059056800"
  • 1 more comment
  • James Feragola
    James Feragola Dec 09, 2014
    http://www.gas-spares.co.uk/Catalogue/ST...
  • James Feragola
    Spare knobs can be found on that site, just make sure there is not a notch that has to line up with the stem in order to press it back on.
  • Jacqueline Hatton
    Jacqueline Hatton Dec 09, 2014
    Thanks again James, I will check out the site.
Grill knob doesnt want to turn on without wiggling then clunks on,top oven(same knob different direction turn)is ok.
The last time I asked, espares could provide a replacement which is what you need to do. If you can't find it listed, there is a section on it where you can ask for a quote.
Sep 14, 2011 | Stoves 720EF Electric Double Oven
The glass panel behind the control knobs has shattered can I replace this model is stoves 720ef
The best bet is STOVES for a replacement - if they have one. It is relatively straightforward to replace. With all the buttons and knobs removed, there should be two screws underneath the panel , i.e. pointing upwards at either end of the panel,. The panel will also have two lugs along the top edge that locate into the top off the oven. The panels lugs should be first located into the oven before the screws are inserted. It may be a bit of a struggle but can be done.
Sep 11, 2011 | Stoves 720EF Electric Double Oven
I have a Simpson electric oven with stove top elements, and one of the burners will only cook at the highest level, I cant figure out how to change it, any suggestions?
You need to change the "Simmerstat", take the model number to your local electrical parts supplier/parts counter at your local stove retail shop that sells Simpson stoves and ask for one for that model, make sure you get the right one for the position as some control a single element and some control dual elements.
*** TURN OFF THE WALL SWITCH AND ENSURE NO POWER IS APPLIED TO THE STOVE BEFORE PROCEEDING ****
Remove the upper back panel of the stove. Swap wire for wire of the old simmerstat to the new one, remove the knob from the old Simmerstat, undo the nut securing the simmerstat in the oven control panel and discard, fit new one, secure, fit knob, fit back panel, turn on wall switch and test.
Some countrys/states require registered electricians perform this task on electrical appliances so you must ensure you can do this legally before you start and take the relevant safety precautions and don't electrocute yourself.
Apr 13, 2011 | Ovens
How do I fit a new switch to the grill of my Soves electroc oven model no. 059040414 Type 720EF? Have you a manual?
First, a handbook is available, but I will need an email address to send it to you.
TURN THE POWER OFF.
To replace the switch, you have to take the whole oven out of its kitchen furniture housing and then take the top off. ) It is held in place by normal wood screwes) All the knobs on the front panel are pull off/push on and you have to remove them. Once you have the knobs off you have to remove the glass control knob panel. On the lower edge of it at either end you will see two cross head screws going upwards. Remove these. Now the only thing holding this in place are I think three lugs on the top of the glass panel that go up and in to the top of the cooker. With a bit of fiddling, the panel should now come off, leaving you free to access the switch for replacement.
I think you will find that the thermostat pipe will link into the top back of the top oven so this has to be very carefully replaced as well, which additionally may require the back of the oven to be unscrewed.
Best of luck!
Nov 06, 2010 | Stoves 720EF Electric Double Oven
Fitted new mainoven thermostat to Stoves Newhome built-in oven & grill Model No. 444445062 Serial No.41209452 other data on plate EFa900h need a wiring diagram,couple wires can adrift. Every thing...
I can only speak for the 720. If you want a circuit/wiring diagram for this one, then I need an email address. I will then register this on my BT Digital Vault and you can the download the whole manual.
Looking at the diagrams, the neon for the main oven has white and black wires.
The white wire from the main oven neon goes onto the same connector on the thermostat block as the white wire to the oven element. The black wire from the neon goes to a common terminal on the top oven neon, which then goes onto P6 of the top oven switch (still black wire).
If you need any more info, then let me know.
Apr 01, 2010 | Stoves 720EF Electric Double Oven
Cooling fan not going round
I assume you are referring to the external cooling fan.
You need to determine that you are gettinjg power to it, if you are, then try spraying the bearings with WD40, if it still does not work, then you are going to have to replace it.
If no power, then you are going to have to trace the feed back to the control switch, and work from there .
Hope this helps.
Dec 29, 2009 | Stoves Ovens
KNOB ON GRILL BROKEN CAN I BUY PART. LITTLE METAL PART ON INSIDE OF KNOB MISSING.
Try ESPARES. If the website does not show it, send them a mail asking for a quote.
Apr 13, 2009 | Stoves 720EF Electric Double Oven
BROKEN GLASS ON OUTSIDE OVEN DOOR STOVES S5 600MF
You can normally replace the outer door glass independently of any other parts.
Try-----www.espares.co.uk
Plz rate my solution.
Thanks.
Jan 18, 2009 | Stoves Premier 600EMa Electric Single Oven
Cant work oven!
I have the Stoves 720EF manual stored on the BT Digital Vault which might help. If you want a copy of it, supply an email address and I will give it access.
Also someone else has said that if you speak to Stoves nicely they may be able to send an electronic version of the manual instead of the paper copy.
Nov 27, 2008 | Stoves 720EF Electric Double Oven
Ovens Logo
55 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
