Question about Boating
How do I install the Reverse Hook Assembly on a 2004 Mercury 25 hp?
2 Suggested Answers
  • 5537 Answers
SOURCE: 2001 mercury 25 hp will not go in reverse
Disconnect your shift and throttle cables, they may be reversed. See if the engine will shift now by hand. If it does not, then the problem was created when the shop benched the gear box and reinstalled it. Take it back even if it was last season. This kind of problem usually does not happen by itself.
Posted on Jun 25, 2009
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
Grinding noise front wheel
1st have the brake pads checked, then if the pads are OK you likely have a defective wheel bearing/hub assembly
Mar 24, 2014 | Mercury Sable Cars & Trucks
I have put a ford refurbished tranny in and rebuilt the shifter assembly twice - 2004 mountaineer. Why am I still getting hesitation going into gear? intermittant problem, most going from park to reverse.
The transmission many to relearn shift points which can take several miles of driving is some cases. drive the car for a while, the hesitation in shifting continues have your dealer flash the ecu
Dec 15, 2010 | 2004 Mercury Mountaineer
Drivers side wheel bearing what do i need to do to replace it myself
Front - Remove tire, then remove brake caliper and caliper braket, remove brake rotor, some times will have little clips, remove clips, if they break ok, won't used them again, if 4X4 remove center axle nut, disconnect ABS harness, on back side of bearing, there will be three bolt's that hold hub bearing assembly, remove bolts, bearing should slide out, some time with a little help from a hammer, and your done , reverse to install new hub bearing assembly, just make sure that ABS harness is in same location that old one was when putting bearing in.
Jul 21, 2010 | 2004 Mercury Mountaineer
How to change headlight on 2004 Mercury
When you open the hood you will see a cover where the hood latch is. Some covers have individual doors on each side of the hood latch. If you have that type just pop the release on the cover and reach down to the headlamp bulb. It comes out with a twist with the socket and then pull the bulb free. Use a kleenex or gloves to install new bulb and reverse the process.
If the whole panel is one piece there are some plastic button holders to remove to lift the cover. Your headlights are underneath. In some cases the passengers side headlight may require removing the battery to access. Then just twist the socket and remove the bulb afterwards, then reverse process.
Mar 18, 2010 | 2004 Mercury Grand Marquis
Changing tailight bulb
First open the rear hatch. Look just inside the door next to the rear lens assembly. There should be 2 screws that need to be removed. This should loosen up the assembly. Next gently pull the assembly back and out to you.Do not pull to hard or to far, you are still connected with wire. Next, squeeze the retainer and twist the bulb assembly ccw. You are there. Reverse it to put it back. Good luck.
Aug 26, 2008 | 2006 Mercury Mountaineer
Boating Logo
50 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
