Question about GE 15119 Plug-In 24 Hour Mechanical Timer - Polarized Outlet 043180151193
How to set it up
Pushing in buttons lifting up buttons to desired time
Ford focus cruise control
Once you have turned your cruise control on accelerate to desired speed press SET button on right hand side of steering wheel before lifting foot from accelerator, then remove foot from accelerator. pushing RESUME button will deactivate cruise control without turning it off. Then when clear of traffic push resume again to activate cruise control. It will automatically resume to previous set speed.
Apr 30, 2013 | 2006 Ford Focus
How can you set the Caixing CX-2158 to 12 hr time instead of the military time?
for clock settings
Clock buttons from the left.
[1] Set
[2] Shift
[3] Modify
[4] Alarm
[5] End
[6] Reset - (use paperclip to push button in hole.)
Light indicators
[A] A.M.
[C] P.M.
[B] Alarm(s) active.
[D] Hour Notice
To set time and date
1.Push SET, push SHIFT to transfer from YEAR to MONTH to DAY to HOUR to MINUTE
2. Push MODIFY to change to desired value in every field (blinking)
3. Press SET or END to save.
To change from 24 - 12 hour format
1. Press MODIFY continously for about 3 to 5 seconds
NOTE: in 24-hour format, both the A.M and P.M light is OFF
TO SET ALARM
1. Push ALARM, and alarm setting number 1 will show, push ALARM again to show alarms up to 8 or 9 (depending on model)
2. When desired alarm number is chosen, Press SET
3. Push SHIFT to transfer from HOUR to MINUTE
4. Push MODIFY to change desired value in every field( blinking)
5. Push END to save, (Please note Red ALARM light will lit)
TO CANCEL ALARM
1. Push ALARM until the desired alarm to cancel is shown.
2. Press MODIFY ( the dispaly will show --:--)
3. Press END (NOTE: Alarm light would only turn off only if all alarm is cancelled)
TO SET HOURLY NOTIFICATION OFF AND ON
1. Push MODIFY button once (hour notice light would lit) - hourly notice is turned ON
2. Push MODIFY button again (hour notice light is off) - hourly notice is OFF
Oct 01, 2011 | Vacuums
Cannot set time on 45/7012
Hold the reset button (upper left button) until the seconds start to blink. To go to the hours, push the mode button (lower left button). To set the hour, push the ST/STP button (upper right button) to the desired hour. To go to the minutes, push the mode button again, set the minutes with ST/STP button. To go to the date, push the mode button, set with the ST/STP button. Once done, simply hit the reset button to complete. Hope this helps!
Mar 13, 2011 | Armitron Watches
Set clock
Turn on the keys to 'Acc'. If your Legacy has a CD player, press down and hold on the 'disp' button for one seconds; if not, omit this step.
Push down and hold the 'disp' and 'H' buttons; this helps you to adjust the hour entry. The hours will be incremented by one hour; leave the button when the desired hour entry is set.
Push down and hold the 'disp' and 'M' buttons to adjust the minute entry. Hold down till the desired minutes entry is set and release it.
Turn off the keys to save the set time.
Jan 06, 2011 | 1997 Subaru Legacy
I have a westclox 70034 and I need to know how to set the alarms
Push the alm1 alm2 button until your desired alarm number shows. Then hold the alm1 alm2 button for approx 3 seconds. The alarm time will flash. push the ADJ button until you reach the time hour you want. Then push the alm1 alm2 button to set the minutes. push ADL until you find the desired minutes. The push alm1 alm2 button and alrm will stop flashing. Your alarm is now set...... I to lost the manual and had to figure it out myself.
Dec 14, 2010 | Vacuums
Digital control reads REM off and we connot seem to reset the control. What should we do?
Press and hold the "temp up, temp down and mode" buttons at the same time for 5-7 seconds...The display should show REMon or REMoff... You have REMon probably. Toggle with the up/down buttons to show REMoff... This should default back to original display. If not, push the mode button....
Aug 18, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
How do you set the clock and program to brew at a specific time?
To program the Auto On
1. Set the desired Brew-Start time.
a. Turn the FUNCTION KNOB to “Prog”.
b. Set the time you want coffee to begin
brewing by using the minute and hour
push-buttons. Follow the same instructions
you used to set the time of day, in
the To set the time section above.
2. Turn the FUNCTION knob to the “Auto On”
position. LCD will display the current time.
3. Lift and release the FLIP SWITCH. The
green indicator light will come on to remind
you that the programming function is in use.
At the programmed time, the red light will
come on as well, indicating that the brew
cycle is starting. Both lights will go off when
keep warm cycle ends.
NOTE: To reactivate the auto-on feature to
start brew cycle at the same time another day,
simply lift and release the FLIP SWITCH. The
green “auto-on” light will illuminate.
Aug 16, 2010 | Cuisinart DCC-1200 Coffee Maker
Setting time & alarm on Sharp Chronograph wristwatch.
Instructions for Sharp Alarm Chrono (Digital)
Push "Mode" button until the mode is shown that you want to reset, do this even if the mode you want to reset is all ready showing.
Push "Reset", continue pushes until the desired Parameter (Minute, Hour, or Second) is flashing.
Use "Start" button to advance the digits to the desired setting.
Push "Mode" Button to finish.
Jan 12, 2008 | Watches
Operating instructions for timex t311t radio/alarm clock
You can acces a PDF file of the manual at the following site: http://timexaudio.com/media/uploads/product/files/T311IB57574_35.pdf
May 20, 2007 | Timex T311T Clock Radio
GE 15119 Plug-In 24 Hour Mechanical Timer - Polarized Outlet 043180151193 Logo
381 people viewed this question
Top GE Home Experts
Douglas Dinnebeil
Douglas Dinnebeil
Gene Haynes
Tom Chichester
Are you a GE Home Expert? Answer questions, earn points and help others
