Question about Home
How do I silence and turn on chimes on an emperor clock?
  • 277 Answers
Not all Emperor clocks have a silent chime feature.
Main Page
How do I silence and turn on chimes on an emperor  - 25311594-lz5u2n1tb0lfc25js3l0tbaw-1-0.png
Posted on Sep 20, 2016
Put new movement in grandfather clock. its keeping time but wont chime
You probably already checked this, but look at the chime silencer switch, usually just a little shitch on the face near the 9 o'clock position.
Jun 23, 2017 | Chime Home
How to fix emperor grand mother clock chimes hour chime one half hour
Try to carefully remove the minute hand entirely from the clock then put it back in the "proper" place. for example, when it strikes at the six, remove the minute hand and put it back on pointing at the 12. Then re-set the time for half-past (or maybe quarter-till the hour by now! lol)
Mar 29, 2017 | Chime Home
How can I completely silence the chimes of the Seiko Westminster Whittingham wall clock?
I looked this up, not sure if yours runs on batteries, but here's a step by step to the chimes.
http://blog.princetonwatches.com/how-to-setseiko-chiming-clocks/
Nov 14, 2015 | Home
How do I get the westminster chimes to work
look in the back of the clock. sometimes there is a mechanical arm that silences the chimes. just remove/swivel it.
Mar 16, 2015 | Home
How do I set the Chimes on the Ergo Westminster Clock
The controls on the back of the Ergo brand Wall Chime Clock are different than that of the Seiko. I'm not sure who makes the movement - probably Chinese or Asian. Anyway, always take the pendulum off the hook before moving the clock about as it can damage the mechanism. On the back, there is a dial for adjusting the time setting of the clock hands, which is awkward to use, but does work, easiest to leave it alone and use the minute hand, NEVER the hour hand. There is a dial for volume. There is a switch for type of chime - Westminster or Wittington. There is the night-time shut off or volume reduction. Some models have a switch for chiming every quarter hour. My advice is make sure you have fresh batteries, and set the switches on the back for the settings you want. Hang the clock, grasp the pendulum arm and re-hang the pendulum, making sure it's hooked in properly. Now, whatever the hands say the time is, ignore it for now, and gently move the minute hand backwards, slowly, to about 5 minutes before the top of the hour, then forwards to a couple of minutes past the top of the hour. This will cause the chimes to start. Let the melody play, then listen for how many "clangs" you get. That will tell you what the clock thinks the time is. For example, if it "dongs" 5 times, and you've set it to run silent at night, the clock thinks it's 5 p.m. If it's actually only 3:15 p.m., then gently run the minute hand backwards til the hands indicate about 10 minutes behind the correct time (it'll take you several minutes to complete the process) then gently move the minute hand back to about 5 minutes before the top of the hour, then forward to a few minutes past, and the chime will start to play the melody. If you let it, it will play out the full melody, then it will "clang" one more time than your previous test. Each time you move the minute hand back to 5 minutes before the hour, it advances the chimes by one hour. Here's a tip - you don't have to let the melody and "clangs" play fully, each time, once you know how it works. If you have it set to run silent at night (pre-programmed to silence after 10 p.m. to 6 p.m.), keep moving the minute hand back to 5 minutes before the hour, keeping track of how many times you've done it until you reach 10 p.m., or not, until you get to the point where you move the minute hand back and there's silence. At that point, the auto-silence mechanism is active, and the clock thinks it 11 p.m. So, from that point, keep repeating the process of gently moving the minute hand back and forth, from about 5 minutes to the hour, to a few minutes past, keeping track of how many times you've done it. After 8 sequences, you hear it start to chime again, at 6 a.m. So, at that point, go through the back-up and advancing of the minute hand sequence 9 more times, and on the 9th time, let the melody play, and let in "clang" to determine that you're indeed at 3 p.m., which you should be. Then simply gently advance the minute hand to the correct time, 3:10, 3:12, whatever, and you're done. You'll know for certain soon enough.
Apr 02, 2012 | Watches
Need setting instructions for clock movement
Howard Miller offers this feature: This is how it works.
Automatic Night-Time Silencing Option
Grandfather Clocks will offer a night time shutoff option. There are 3 options on this lever.
1) "Night On" - This will keep the chime striking 24 hours
2) "Night Off" - This position will turn off the chiming between 10:15PM and 7:00AM
3) "Strike" - This position will allow the movement to strike the hour without the Westminster melody if the other Westminster melody lever is turned to Silent.
Hope this helps.
R/David
Apr 05, 2009 | Oregon Scientific Lwb0997110113004...
Elgin grandfather clock chimes not working
I'm not positive about this, but I seem to recall that these type of clocks have two "silence levers" on the movement. These levers are located at the upper left and upper right corners of the movement as you face the movement from the back. The movement back panel has to be removed if it has one.
If the levers are pushed toward the chime rods, they will silence the hour or musical chime, depending on which one it is. I believe the silence levers are supposed to be moved away from the chime rods so the rods can retract and then strike the chime bars.
Mar 29, 2009 | Elgin 0518709FA
Home Logo
201 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
