WHEN MY NAVIEN COMBI BOILER GOES TO DOMESTIC USE THE AIR HANDLER DONT SHUT OFF UNTIL IT GOES BACK INTO HEAT MODE DONT KNOW WITCH 2 WIRES TO BRING TO THE NAVIEN WITCH HAS A SPOT NEXT TO TT SAYS A/H
My stat runs to air handler white and green. a/h 2 purples run to tt on combi .not sure what I should change around to make that darn fan go off during hot water use.
I don't see the above problems being of help because it's not a heat pump or a issue about a fan switch. This is a stat and system wiring issue.
Here's a link to a proper wiring diagram.
https://www.dropbox.com/s/808zsozmkxce7fu/CH_NCB%20AHU%20Wiring.pdf
WHEN MY NAVIEN COMBI BOILER GOES TO DOMESTIC USE T - /uploads/images/when-navien-combi-boiler-goes-domestic-34752482-3-1.jpg
Posted on Dec 08, 2014
4 Suggested Answers
shastalaker7
  • 1515 Answers
SOURCE: t stat wiring in air handler
Hi, normally they don' t have 2-toned striped wires in a thermostat cable. They must have used some other 18 gauge wire. If this is a gas fired indoor unit, the wires are Red to R, Yellow to Y, G to to green, and white to W. If its a heat-pump, no gas, you will have Red to R, W to W-1 if you have heat strips for second stage heat, G to fan, green, B is blue for the reversing valve, 0 will not be used on a Ruud. You may need to go to the control panel on the outdoor unit to see how they have wired the condenser, as you never no what colors they have picked to use, what ever suits them. You may have a black or brown for common if used, or for emergency heat. Gas air handlers are much easier to wire at the stat then a heat pump, so you will need to check what they used at the outdoor unit. They didn't use regular stat wire as it does not have stripes on it.Please do this and draw your self a diagram so you will know. Most all heat-pumps wire differently, at the stat depending on the kind, and at the condenser. I hope I have been of help to you on this as it is important to get it right, and it sound as tough you are familar with wiring. Please rate me on this and be kind as I know you will. Please keep me posted on the outcome or if you need more help.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
PS You may not need any of the striped wires as all wires are not used. You will need to look at the outdoor and indoor control board.
Posted on Jul 17, 2010
  • 27 Answers
SOURCE: Air handler fan runs nonstop in heat mode
is this a new problem? the fan speeds can be adjusted by changing wiring connections. If it is a new problem on an existing system then it could be the t-stat or a problem with the curcuit control board. the switch on the t-stat for FAN is set to auto not ON. if set to on the switch to auto - problem solved.
Posted on Nov 26, 2008
matthew_lipp
  • 52 Answers
SOURCE: I need a wiring diagram for a luxaire air handler ahr36b3xh21a and auxilary hot water coil?
red to R and white to BR
Posted on Oct 08, 2012
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Recently we.had to have the motor replaced on our 3 year old Navien Combi boiler/tankless water heater because it made a squealing noise periodically. The technician who worked on it told us to let him...
This could actually be a manufacturer issue with the brand of pump. Based on your description it is unclear if this is a circulator pump, fuel pump, zone valve motor or other motor on your appliance. As a 30 plus year technician of heating appliance I have seen many parts factory defective, especially when purchased at the same supply house. Inventory is typically shipped to supply houses with manufactured parts from the same factory lot numbers, and when this happens, the technician keeps replacing a part with parts from the same bad lot!
Also, not knowing the true details of this situation, the installation set up, piping sizes, component brands, what means of air venting system was used in the hydronic side of this system, if any? With that said giving you a more specific answer is really impossible, based on the little knowledge I have to go on to help you out.
My recommendation would be to contact another company and have them come out to look at the problem, if you find the previous company charged you for parts that were not needed or the system was installed incorrectly, contact your local plumbing inspector for what to do in your area.
Dec 11, 2014 | Water Heaters
Navien combi boiler
call in a plumber. it sounds like it is malfunctioning.
Mar 18, 2014 | Taco SR503-4 3 Zone Switching Relay
In heat mode but heat strips don't come on and the air handler fan dose not turn off
Maybe a bad sequencer.unplugged wire from sequencer and see it unit shut off .Sequencer is typically a relay
Feb 23, 2018 | Goodman GMS90703BXA Heater
Heat pump goes str8 to heating strips compressor does not run in heat mode pump was manufactured in 03 installed in 07 and has sat dormant till now could it be wired wrong it is a ruud split unit with...
I think that you have the right idea. The wiring is probably wrong. If you can trace the low voltage wires to the air handler. make sure that the Y1 wire on the t-stat is going to Y1 on the hair handler and then to the condenser. The Y2 wire should be going to Y2 on the air handler and probably does not continue out to the condenser. The Y2 should be going to the contacor that brings on your backup heat. It seems like Y1 and Y2 are reversed somewhere.
Nov 14, 2009 | Heating & Cooling
Heating circuit getting hot when hot water is running
Check to see if diverter valve is in domestic mode or heating mode.
Jul 04, 2009 | Water Heaters
No hot water from combi boiler
i have a combie bolier when i turn the hot water taps on only cold water comes out central heating working fine can any one give some advise ?and can i fix it myself.
Jan 03, 2009 | Combi Centre DX - Mango
Combi cutting out and overheating
is this a baxi 105? chances are you diaphragm has gone on your diverter valve. Or your diverter valve.
Do you will initially get a liitle hot water if your heating is on?
Dec 22, 2008 | Water Heaters
Vaillant Ecotec combi boiler - radiators working but no hot water flow to taps
David,
The fact that you're getting a little burst of domestic hot water suggests that the boiler is capable of circulating hot primary loop water through the heat exchanger, but doesn't necessarily do so when it needs to.
What seems to be lacking is a recognition that domestic hot water is now being drawn off, and that the boiler needs to fire up and divert the primary flow through the heat exchanger.
A good place to start might be the flow switch (usually in the bottom of the boiler, where the cold water supply comes in) or the electrical connections to it.
A.
Oct 05, 2008 | Heating & Cooling
Heating & Cooling Logo
83 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
