Question about Peavey Xr 8600 Xr8600 Powered Mixer Proaudiostar
Thank you but i do have the manual .i need the schematics for the xr 8600, or the site to download from
I tried the amp on another set of working speakers,no sound. I then tried the pair of speakers on a working amp and there's no sound from the woofers except that there was sound from the tweeter's . I was told that the shorted woofer's damaged the powered mixer.What possibly would i have to replace in this amp.
    New Friend:
    Problem Solver:
  • 11 Answers
Internal fuse. Or fuse near the speaker connections.
Remove power. Remove back cover look for
125v clear or ceramic fuse.
125V 5x20mm Fast-Acting Glass Fuse
Posted on Dec 07, 2014
Is there a fuse inside the xr 8600 power mixer?
I see 2 on the schematic..... F100 & F101 - could be board mounted? I don't have a unit to compare :-) Good Luck!
Dec 18, 2016 | The Music
Hi , i need a service manual for the peavey xr 8600 powered mixer . Not the xr 8600D . THANKS
http://music.manualsonline.com/manuals/mfg/peavey_electronics/powered_mixers_model_xr_8300_xr_8600.html
Dec 07, 2014 | Peavey Audio Players & Recorders
How can you tell if a fuse is blown on a XR 8600 power amp by peavey?
The fuse is probably placed near the power cable entrance in the power amp.
Pick it up from it's placing dock and look for the wire inside. If the wire is whole, the fuze is fine, however, if the wire inside the fuze is missing or burned, the fuze needs to be replaced.
Jan 27, 2013 | Peavey Xr 8600 8 Channel Powered Mixer
Why does the 1.6amp fuse blow when the amplifier is switched on?
The owners manual shows a AC fuse for the 8300 as 8amp / 250 volts but doesn't show an external fuse holder for the 8600d. It's unlikely that the 8300 would use a 8amp and your 8600 a 1.6 amp. Double check your original fuse values.
http://www.peavey.com/products/index.cfm/item/701/117405/XR%26nbsp%3B8600D
Oct 25, 2012 | Peavey Xr 8600 8 Channel Powered Mixer
A Clarion DB365USB: I want to connect the input of the amp for a sub woofer to the clarion. There are 3 pairs of RCA jacks on the back of the clarion. Top pair are input, the second and third i think...
There should not be a constant voltage present on the output RCA's. They will only put out voltage when there is something playing and it will be a very small and constantly varying amount. If you plug it in and it is still not working you may need to adjust the menu settings on the head unit or the input sensitivity of the amplifier. For example if you plug the RCA's into the Rear outputs of the head unit and the Fader setting is all the way forward, you will not get any sound. Same goes for the amp settings, if you turn it on and the input sensitivity is set way down then you won't get any sound then either. Cheers, Dan
Apr 28, 2011 | Car Audio & Video
There is not a subwoofer input jack on the back of this subwoofer. There are a set of input (negative and positive) terminals and a set of output (negative positive) terminals like would hook speaker wires...
On the back of the sub woofer you have two sets of binding post / some have spring clip terminals ( red & black ) labeled Speaker In ( sometimes High Level In ) and Speaker out.
Take 2 pairs of speaker cables and connect one end to the speaker out socket of your amplifier ( left & right ) . The other end of the cable should be connected to the sub woofer's Speaker In socket , Red to red and black to black. Now on the Speaker Out socket of the sub woofer connect your existing pair of speakers using another pair of speaker cables. If your sub woofer has a Hi Pass filter built in , you may not hear bass coming from your existing speakers with this kind of connection. Good if you have small satellite speakers.
Mar 12, 2011 | Audio Players & Recorders
I use my Peavey XR 8600 with an acoustic duo that I'm in. At my last show, an audience member grabbed and dropped a vocal microphone that sent a sharp sound through the Peavey and shut it down. When I...
Chances are one of the power amps has shorted. Replacing the fuse probably fried additional components. Unless you are electronically adept this is NOT a DIY repair.
Expect that this is going to be an expensive repair as often quite a few transistors and other components fry when one goes in these power amps.
Mar 09, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
I have the peavey xr 8600 and i wanna know how to connect an additional non powerd mixer to it ( i wanna use the peavey as an amp??
That's easily done. Simply connect the left(or right) output of your mixer to one of the channels on the peavey. Use any line input. Since the peavey is a mono system, there's no need sending a stereo mix to it.
Mar 08, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
Peavey Xr 8600 Xr8600 Powered Mixer Proaudiostar Logo
450 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Michial Gueffroy
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
