Question about World Heating & Cooling
Recently received a Kozy World 20-6030 thermostatic controlled blower for my Natural Gas Bainbridge, vent free gas stove, GSD 3033. I installed but does not turn on. Installed as per instructions and
See above
    Champion:
  • 305 Answers
Did you receive a heat disk along with the blower?
once the combustion chamber heats up enough, the heat sensor will then close, allowing the fan to come on
Posted on Dec 31, 2014
Testimonial: "Received a second blower from distributor and that one had a wire that had not been soldered (attached) properly. Didn't notice into installed and turned on. Immediate flash from gas heater. Waiting for refund."
SOURCE: Need Instructions to use Fireplace Gas Logs
There should be a set of metal cards attached inside the fireplace.
First you should read everything there.
I know you have to first light the pilot light.
And then there should be a wall switch.
The problem I have currently is that it won't stay lit when the artificial logs are there.
Posted on Nov 23, 2008
  • 139 Answers
SOURCE: My vent free Desa natural log will run for a short
it is likely you have dirty O2sensor, it is incorporated into pilot assembly.turn unit off,use compressed air in a can and blow into spot where pilot flames comes from.this will fix it in most cases.in a small % of time entire pilot assembly needs to be taken apart and cleaned
Posted on Jun 25, 2009
hardrocko
  • 1476 Answers
SOURCE: my vent free gas fireplace blower will not turn
If the blower will not turn off it could be several things. Certainly the thermostat would be one but it could also be a relay on the fireplace which powers the blower. My guess is the manufacturer did not run all the power necessary for the blower through the thermostat. More likely there is a relay or a tempreture switch on your unit which turns the power on or off to the motor using the thermostat as a reference. I would say that the relay or switch has stuck or burned shut and will not open. You will have to do some checking to make sure which part you need. A simple DMM will tell you if the thermostat is bad. Remove the leads from the thermostat and check continuity. Turn the thermostat up and down the DMM should go from infinity to a short if it is working. If it checks ok check the relay/switch in the fireplace next. I'm guessing that is where you will find the problem. Let me know how you make out and if you need anymore help.
hardrocko
Thanks for using FixYa
Posted on Feb 14, 2010
SOURCE: The kozy wold heating stove flame has irruglar
kozy world KW112, 1 burner is dim flame 2nd flame is bright red. What is the problem?
Posted on Sep 10, 2010
SOURCE: Comfort Glow Vent-free Gas Heater
I have a comfort glow gas heater that the pilot lights and when I start the heater it works for about 30 seconds then the whole thing shuts down.
Posted on Nov 05, 2010
New kozy world natural gas heater. Pilot light wont stay lit snd heater flame wont stay lit.
Are you holding down the pilot light button long enough for the heat sensor probe to get hot and turn on the gas valve? It takes up to 3 minutes
Nov 20, 2016 | World Heating & Cooling
First off i have checked for gas leaks when i light my heater it lights just fine but after i set the temp and wait a few sec. flame engulfs the heater thatis when i shut off the gas so what is it
Is it possible that the heater is set up to use LP gas and you are using Natural gas? There is a large pressure difference between the two. Some units are not convertible, while others have a replaceable orifice that allows you to reduce the pressure when using Natural Gas.
Dec 24, 2014 | World Marketing Kozy-World 5 Plaque...
After installing my kozy world heater and lit the pilot the heater came on. all three plaques. this happened while the knob was still in the pilot position. the heater wont shut off.
I actually have three of these and what I found was the gas valve was stuck in the open position you may need to replace it or possibly remove it and try to clean it of any residue but be very careful if you don't know exactly what your doing then you need to get a pro. Remember that your dealing with propane and it could ignite and cause serious damage to you and your home. Please be very careful and you might want to call the manufacturer and talk to them about it. Because it is a gas appliance they have a responsibility to you if anything should happen then they may be liable.
Nov 25, 2014 | World Marketing Kozy World KWP196 3-Plaque...
The pilot ignites without a problem. It will stay lit. However, when you try to kick the flame on, it will burn for about 15-20 seconds then the whole unit kicks off.
Sounds like a over heating or a thermostat problem. Is there a safety (high limit) thermo in that unit? Replace it or jumper it temporarily to see waht happens.
Before you do that, make sure the air flow is in no way restricted causing over heating in the unit and for the thermo to open, shutting down the unit.
Oct 26, 2013 | Kozy World World Marketing GWD208 20,000...
How to convert kozy world propain heater to gas
Sorry, it can not be converted. At least not safely. It's a Vent-free Gas Supplemental Heating Appliance, that is manufactured for one specific gas type, either Natural Gas or LP Gas. There are NO conversion kits for these units or any Vent-free gas appliances for that matter.
Feb 06, 2011 | Heating & Cooling
My pilot light on my five burner kozy world heater comes on and burns full and blue but itermittently sputters and shuts down when burners kick on.
From what you have described there appears to be dust, dirt or pet hair in the pilot or the pilot tubing, as well as the Oxygen Depletion Sensor (ODS). OR your heater may be the wrong gas type. In other words, you have Propane Gas and the heater is a Natural Gas heater (or vise versa). Look for the manufacturers tag on the side or back of the heater. It will tell you the model number, serial number and gas type. Even with this, on rare occasions, the manufacturer's plate may be incorrect. The only way to be sure is to remove the front cover of the heater and look at the control valve. It should be marked LPG or NG.
Jan 28, 2011 | The Companion Group Kozy World Portable...
Thermostat problem
I WOULD JUST DOUBLE CHECK THE WIRING TO THE THERMOSTAT AND THE HEATER, , WOULD BE MY GUESS, IF IT WORKED FINE BE FOR, THERMOSTATS DO GO BAD, BUT I WOULD CHECH WIRES, ALSO YOU MAY BE ABLE TO CROSS THE TWO WIRES AT THE THERMOSTAT TO CREATE A DEMAND FOR HEAT, BY PASSING THE THEMOSTAT YOU WILL KNOW IF THE PROBLEM IS AT THE THERMOSTAT OR HEATER GOODLUCK
Jan 24, 2010 | The Companion Group Kozy World Portable...
Heating & Cooling Logo
65 people viewed this question
Top World Heating & Cooling Experts
MightyMikeJr
Andrew Taylor
Andrew Taylor
Are you a World Heating and Cooling Expert? Answer questions, earn points and help others
