Question about Broderbund PrintMaster Gold 11 for PC
Install print master gold 11 on windows 8 ? - Broderbund PrintMaster Gold 11 for PC
5 Suggested Answers
  • 187 Answers
SOURCE: I am running windows 7 , however I cannot get my
Check out whether you are running 32 or 64 bits.If you are running Windows at 64 bits, you may not have enough memory to actually manage it. 4 gigs of RAM is the norm for 64 bit installations. This is more likely if you upgraded and didn't buy your computer with 7 preloaded, but you should have gotten a caution message during installation if that was the case.
Go to start, computer, and then system properties. Then look at whether you are running X64 edition. If you are running x64 and don't have enough memory or a fast enough chip, that can create problems. That usually takes the form of crashes during games and other graphic intensive programs. If that is the case, you might have to change your Windows installation.
Make sure that you go to Microsoft update advisor and Broderbund's printmaster updates to make sure you have the latest drivers. Usually, if you go to help in the program menu there is a way to update automatically. It may be under about or something like that. Printmaster was designed to work at 32 bits, but most programs will run on 64.
Hope this helps, leave comments if you have more questions.
Posted on Dec 19, 2009
proartya8765
  • 581 Answers
SOURCE: Print Master Gold 16 compatible with Windows 7?
Compatibility Wizard
1. Open the Program Compatibility Wizard by clicking the Start button , clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
2. Follow the instructions in the wizard.
If you cannot install a program, insert the installation disc for the program and, using the wizard, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The wizard is not designed to work on programs that have an .msi file name extension.
To change compatibility settings manually for a program, right-click the icon for the program, click Properties, and then click the Compatibility tab.
Posted on Jan 04, 2010
  • 5 Answers
SOURCE: problem loading Print Master gold 10 on windows
As I just posted on http://www.fixya.com/support/t2129564-printmaster_platinum_10_version_will_not I was able to get PrintMaster Platinum 10 to install on Windows Vista by right clicking on E:Setupis_Setup.Exe->Properties->Compatibility->Run this program in compatibility mode for Windows XP (Service Pack 2) and then running E:Setup>is_Setup.Exe FullSetup.ini from the command prompt.
Posted on Apr 04, 2010
  • 27 Answers
SOURCE: I have the print master
All you need to do is download & install Windows XP Mode for Windows 7
http://www.microsoft.com/windows/virtual-pc/download.aspx
Once installed you will be able to run all your favorite old programs , if you run into any compatibility issues , right click on the .exe file & select "properties" , compatibility mode , & select the settings your program is known to work with .
After all this if you still can't run the program , try using " virtualbox " or " vmware virtual machine " & install a copy of windows xp as a virtual machine .
Posted on Apr 16, 2011
I have the print master gold deluxe software and I'm not able to use it with window 7. please help
Apr 16, 2011 | Broderbund PrintMaster Gold 16 for PC
Since changing to Foxfire from IE I can not open my Print Master Gold 12
Try re-installing the Print-Master Gold so the istallation can "detect" your new browser. Be sure to back up your data files / folders related to PrintMaster.
Dec 31, 2010 | Broderbund PrintMaster Gold 12 for PC
I have an old print master gold 16 program. Can I some how download it and make it work on my Windows 7 program
you can buy virtual machine program and use older stuff with windows 7. it will require u to install that os also to run it. please vote
Dec 21, 2010 | Computers & Internet
Can I add a watermark to a flyer using Printmaster Gold 18?
I am trying to install a watermark to a document with print master gold 18. I'm having absolutely no success whatsoever. Anyone withany suggestions
May 20, 2010 | Broderbund PrintMaster Gold Version 18
Jan 03, 2010 | Broderbund Print Master Silver 16.0 for PC
I am running windows 7 , however I cannot get my print master gold 11 to run with this operating system . It seems to have something to do with the 64 bit
Dec 19, 2009 | Broderbund PrintMaster Gold 11 for PC
How to install Print Master Gold 15 into Dell computer?
FineReader can scan documents and save it as jpg.
Download it from here
Hope it helps.
Apr 27, 2009 | Microsoft Windows? Vista Home Premium...
Problem loading Print Master gold 10 on windows vista
Mar 24, 2009 | Broderbund PrintMaster Platinum 16
Is there any way I can print out the instruction manual for my Print Master Gold version 18?
first try to right click and select the text and "print selected", if that does not work, try printing a screen shot using "alt+print screen" for the app. window, or just "print screen" for the whole screen.
Dec 29, 2008 | Broderbund PrintMaster Gold Version 18
Colors not printing correctly
OK, Canon will hate me for this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Jul 04, 2008 | Canon Office Equipment & Supplies
Broderbund PrintMaster Gold 11 for PC Logo
Top Broderbund Computers & Internet Experts
Martin Murray
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
