Question about Jenn-Air Kitchen Ranges
How can dirt between the oven window panes, be cleaned?
Model JES8850. How to access between the oven door window panes? Dust and debris has collected on the inside of the window.
    Top Expert:
  • Jenn-Air Master
  • 46,307 Answers
It can but is it hurting anything but looks . as they say beauty is only skin deep
Posted on Feb 20, 2015
TampaNative
  • 778 Answers
SOURCE: FOOD AND DUST BETWEEN THE GLASS
Hello MotoMom,
I have disassembled an insulated door with laminated glass to clean between the layers of glass once and will never do it again (as it took far too much effort and time).
I will suggest trying to get a fair flat rate (not hourly) for completing the task to your satisfaction, guaranteed for at least 1 year. I would also check with other appliance repair shops/technicians (other than just the GE authorized repair), unless it will void any warranty the oven may have.
I hope this helps you, and good luck.
Posted on Mar 18, 2008
SOURCE: Oven window
SAME PROBLEM WITH STAINING BETWEN DOOR GLASS
Posted on Mar 21, 2008
  • 1314 Answers
SOURCE: Clean Oven Door Glass
To remove oven door:
1. The oven door is held to the oven door hinges by two
screws. (One in each hinge.)
2. To remove the oven door remove the two screws.
Two screws
3. Close the door to the broil stop position and lift up.
then remove the door handle and take out all the screws around the edges of the door and pull the out side cover from the inner but a word of caution there are about three or 4 pieces of glass they are tempered and about 100 bucks a piece and most times they wont get real clean and will get messy again
Posted on May 24, 2008
Using a long stick/tool, attach a cloth to the end. Remove the drawer and look up at the oven door. There are 2- 3 openings that are big enough for you to reach the mess. Make sure that whatever you are using to clean the glass will not stay stuck inside, so make sure its attached securely. I used the end of back scratcher with a thin cloth attached to it. After a few attempts, I was able to completely remove the stain that was caught between the two panels. AND... I didn't need to remove any screws or dismantle the door. This could void your warranty.
Posted on Feb 17, 2009
  • 291 Answers
SOURCE: spill between glass panes on oven door
The only way to clean this is to dismantle the door. Most brands you can remove the door and set it on a counter to dismantle. This can be very complicated, depending on the brand and model. Leaving the gravy inside the door won't hurt the range, and self cleaning usually will not clean this completely. It usually just bakes it on harder. Good Luck Appliance Specialists
Posted on Dec 31, 2009
Stuck on "open/close door". How do I unstick it?
3 drops count oil or any cooking oil in door end
Jan 18, 2016 | Microwave Ovens
How to clean the glass door (between the glass) of my frigidaire professional series wall oven
Hello Friend, that's a great question!
May I have your model number please? You can normally find the serial tag on the front of the oven, on the left side, as you open the door. With this material I can provide the correct instructions to you. Thank you! - Z
Jul 13, 2014 | Frigidaire Washing Machines
My Riccar Upright leave lines of debris when I use it. Can you help?
Inspect the filter.Open the secondary filter on the base of the vacuum to ensure that dirt and debris have not collected on the filter, as this will limit motor performance. Remove the filter from the dust compartment and rinse with water to clean. Allow it to dry completely and return to the dust compartment.--------
Also check if dust bag is got over full and that is causing the problem.Open the dust compartment, take the old dust bag out of the bag holder and discard. Open the end of a new dust bag and attach to the dust bag holder. Close the dust compartment and tighten the dust cover.Also check properly that dust compartment is not got loose. Open cleaning attachment and check the hoses and nozzles on the frequently to ensure that they are free of dirt, obstruction or hair.Also inspect the brushes, if there is already dirt got stuck in the brushes and that is causing the problem.Clean the brushed.---------- This will help, to confirm where the problem is and to resolve the dirt /debris issue.----- Thanks.Helpmech.
Sep 06, 2011 | Vacuums
Cleaning between oven glass
You must unscrewed inner door,there is screws around edge door inside,try it.
Feb 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Dyson collecting debris/hair, ect on top of hepa filter?
Called Dyson today about the cyclone canister clogging in my DC17 Animal. Turns out it's a problem with the black rubber gasket in the bottom of the canister. This also causes the HEPA filter to get lots of dirt and debris on top of it. They are sending me a new Cyclone canister with the corrected gasket. This will prevent anything but small particles of dust from entering the top of the cyclone and the HEPA filter should no longer collect all that stuff. Hope so!
Feb 09, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Cleaning the vent
One trick is to put a Pyrex bowl of water and let that boil for a few minutes or so. This gives the water vapors a chance to collect and exhaust dirt and dust from the vent passage way.
Worldvet
May 25, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Oven window
Dec 07, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
88 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
