Recently received a 20-6030 thermostatic controlled blower for my GSD 3033. I installed but does not turn on.
Installed as per instructions and plugged in cord to 110v-115v receptacle. No power to blower, unable to turn on with switch supplied-manual-off-auto. any ideas and if not who to contact at Amazon/World Marketing/DrillSpot(shipper) for replacement? Box not opened or damaged before receipt.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 78 Answers
Not a computer question.
Posted on Jan 07, 2015
  • 1019 Answers
SOURCE: Accidentally plugged the 110V to a 220V
you,ll have blown the PSU.
there maybe an internal fuse, located in the PSU. but if smoke was bellowing out, i,d say it went straight past the fuse.
New PSUs the best bet.
Mike @ Compurepair.
Posted on Feb 22, 2008
  • 12 Answers
SOURCE: compaq presario sr1115cl wont power up
Remove the power supply after everything is unplugged and take it to your nearest electronics store. They should have a tester there. This is probably the problem.
Posted on Jul 01, 2008
13thLegion
  • 8 Answers
SOURCE: HP Desktop power up problem
Bad ram probably, units do that all the time at my job. Most of the time, it is the power supply that does not have enough power to invest into all hardware that makes your pc. even if you had a 400watts power supply, the next time you are buying a power supply you should do some kind of upgrade. 600 watts or more. If you have a high end graphics card then you are indeed in need of a new power supply. also check your cpu, its fan, check if it still seated properly, if there still paste on top of it to hel cooling it down, and protect it from statics. if you added new hardware, remove them and keep checking if it is working. To do manual diags, you need to take the unit apart. I would start by removing rams first, and check ram one by one, then hdd, then disconnect other components until i find the actual part. I am sure it is your powersupply, worst case scenario is you mobo is gone.(but it powers up and shutdown after all so let us hope you don't have a dead motherboard." and remove the dust please, dusty units do not run properly. Neim Le Legionaire.
Posted on Oct 19, 2008
  • 916 Answers
Try this troubleshooting guide it has worked for me in the past 99% of the time http://arstechnica.com/guides/tweaks/troubleshooting.ars
Posted on Jan 07, 2009
  • 1015 Answers
SOURCE: Will not power up
try re-setting the BIOS by using the clear CMOS jumper on the motherboard. If that does not work then remove the memory dimms, cd-rom drive, hard drive, floppy drive and any PCI components. After that try the computer and see if you at least get a post-up screen. If you do then re-connect each component until the post up screen stops again and that is your problem component. If not then your motherboard is bad.
Posted on Sep 23, 2009
Installed per instructions but no power to thermostat
You need to go to the source of power for thermostat to troubleshoot. Did you hook it up properly? One of the lines going to unit should show a voltage of about 25.
If this was installed to replace a malfunctioning unit then something has to be messed up with the wiring.
Nov 16, 2015 | Heating & Cooling
Recently received a Kozy World 20-6030 thermostatic controlled blower for my Natural Gas Bainbridge, vent free gas stove, GSD 3033. I installed but does not turn on. Installed as per instructions and
did you receive a heat disk along with the blower?
once the combustion chamber heats up enough, the heat sensor will then close, allowing the fan to come on
Dec 07, 2014 | World Heating & Cooling
Blower runs continously....
Hi Kathi,
I think its thermostat or ,thermo sensor is out of order and if it is controlled by electronic circuit it can be faulty.
another thing sometimes output contact relay for motor is faulty it want turn off itself when the circuit energize the coil.
please call electrician who can handle.
regards,
nuwan.
Jan 10, 2014 | Honeywell Programmable Thermostat Heater
Honeywell programmable thermostat - was installed per instructions in manual and now the furnace runs non-stop unless I move switch to "off." The old (round mercury switch) thermostat was wired red t
If you are unsure about which wire goes where, that may be the source of your problem. The color coding can be confusing when changing from old to new. I pulled the instructions for my Honeywell CT3400A thermostat and found you can call Honeywell Consumer Services at 1-800-468-1502 M-F 7:30 am to 5 pm CT
Mar 11, 2013 | Heating & Cooling
How to programme a nova 4 button remote on a gemini gate motor
It's important to know that the Nova remote controls are not compatible with the Gemini gate motor. In order to get these remote controls to work with your Gemini gate motor, you'll need to install a Centurion receiver first (see http://www.centsys.co.za/upload/product_link_files/CS37_Nova_Receiver_Instructions_1031.D.05.0012_4.pdf). Once the Centurion receiver has been installed on your Gemini gate motor, follow the programming instructions as per the leaflet that accompanied your brand new Nova remote control, or download the instructions from http://www.centsys.co.za/upload/product_link_files/English_Transmitter_InsertCS37_1031.D.02.0027_1_Nova.pdf
Feb 22, 2012 | Televison & Video
Furnace cycles too frequently. Installed new wall thermostat,didn't stop problem. Furnace is installed horizontal in rafter space.
Systems are designed for a maximum of 6 cycles per hour. If you are experiencing more than that, you have leakage in your duct work or poor insulation or the system is too small for the area you are trying to heat. Some newer thermostats have an adjustment on them to allow you to set how many cycles per hour you want. Look in the instruction manual and adjust the DIP switches to your preference.
Mar 30, 2011 | Emerson Heating & Cooling
I changed the thermostat and then the ac stopped working
if this is a split system, go to the furnace or air handler. Shut off the power, remove blower door and find where thermostat wires go to control module.
Remove thermostat wires writing down where each one goes. Make a jumper wire and install it between r and y or r and y1.Put everything back together and turn on power. IF blower motor and ac start, you have
a low voltage wiring or thermostat problem.
If nothing happens then you either have no power to furnace, transformer
could be bad or you have blown a little 3amp automotive fuse that is
installed on the control board.
Jun 30, 2010 | Carrier 38CKC042 Air Conditioner
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
