Question about Bertazzoni KG36CONX Designer Series 36" Wall Mount Chimney Range Hood
When I turn it off, the #1 bottom(on and off)keeps flashing. Just started doing that. When I turn it on, the light become solid. But when I turn it off the 1 keeps flashing. How do I stop it?
I turned off the breaker the whole night and turned it back on but the #1 bottom keeps flashing.
How do I stop the door lock from flashing on my self cleaning oven
Hello Brian Pelletier, thanks for your inquiry!
I understand that you are having issues with your door not locking upon using the self-clean feature. It sounds like a possible issue with your EOC (Electronic Oven Control) or dock latch assembly. I would suggest unplugging your range if possible or flipping you breaker for ten minutes to perform reset. If the light continues to flash you may want to seek assistance from a professional for proper diagnosis and repair. -Matt
Oct 13, 2014 | Frigidaire 30 in. Electric Self-Clean Coil...
Induction cooktop-flashing keypad
Refer to user manual or company support, the keypad is giving you a error message of some sort, and it is dependent on the make and model on what that error message means so by referring to the manual or posting it would further help you in figuring out what the issues
Jan 27, 2012 | Cooktops
Eurokera hob - lights flashing, buttons not working
hi i have a eurokers ceramic hob and it has not worked in about a yr. it is touch screen and only 1 mth old when problem happend it was like it over heated and now when you turn it on it flashes on the dial i cnat make out it and the hob wont come on. pls help it is brand new and dont want to throw it out.HELP PLS
Dec 26, 2009 | Cooktops
My Neff induction hob has prgressiely getting worse. All the lights start flashing and only hob will work. But after 10 mins the other hobs start working. The flasing gets worse if you try to start with...
Hi, if you take off the magnetic knob & let it flash a little longer, then switch off & on again it will work. Ours is doing the same. The book says it needs cleaning, as do the customer services people but I've cleaned & cleaned it & I assure you it's spotless. You don't have to wait 10 minutes though to start cooking, just 1 after switching off. It is very annoying though & I think we will be getting an engineer out to look at it.
Nov 29, 2009 | Neff 23 in. T1443 Electric Cooktop
One burner will not light
IF YOU HAVE THE TYPE THAT IF YOU TURN ONE BURNER UN ALL FOR WILL SPARK, WHICH I BELIEVE YOU DYOU JUST HAVE A BAD CONNECTION TO THAT IGNITER. LIFT THE RANGE TOP A LITTLE AND YOU AHOULD SEE A WIRE GOING TO EACH BURNER CHECK AND MAKE SURE ALL WIRES ARE CONNECTED. AVER TIME THE CONNECTIONS BECOME BAD JUST LIGHTLY TWIST THE WIRE END TO THE LITTLE TAB TO THE BURNER BASE AND THIS SHOULD FIX THE PROBLEM. ALSO IF YOUR BURNERS ARE REMOVEABLE LAY THEM BOTTOM DOWN ON A PIECE OF SAND PAPER AND LIGHTLY SCUFF THE BOTTOM OF THE BURNER
WHERE THE BURNER SITS YOU SHOULD SEE A LITTLE ROUND METAL PART THAT THE BURNER SITS ON TO MAKE IT SPARK SAND THIS ALSO FOOD AND GREASE BUILD UP WILL HAMPER THE SPARK. THIS SHOULD FIX THE PROBLEM
Aug 12, 2009 | Cooktops
Hob says 'L' when turned on, tried solution but still not work
i called up AEG customer service, and they said: Press the '-' and bottom right '+' sign and this should take off the childlock. So it looks like there manual was correct. It seems like in some cases you need to do this, or the method suggested in the other post
Jun 25, 2009 | AEG 23 in. 6410KF-N Electric Cooktop
Left hand side not working
OK. I know whats wrong. On your terminal I guess you only connected the Large Brown wire to the number 2 terminal ( Live ) What you have to do is bridge terminal 1 and 2 together. You may need to peel back the heavy copper brown so you can split it evenly and ensure it can reach to terminal 1 and 2 . So what you have then is one cable feeding to both 1 and 2 terminal. If you have the smaller live brown wire just connect that to terminal 2 also. That should fix your problem. I will check back to see if you have any more problems..
Sep 16, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Electrical hookup
no its 220 red to one 110 line blk to the other 110 line white to neutral should be a solid metel wire to take that to ground
Jan 26, 2008 | Jenn-Air JED8430 Electric Cooktop
Ignitor on burner #2 keeps clicking even after burner #1 lights
Jenn Air uses a reignition system on their gas cooktops.It is very important that you have a well grounded recepticle. Please check that and please get back to me.
Sep 11, 2007 | Jenn-Air JGC8536 Gas Cooktop
Bertazzoni KG36CONX Designer Series 36" Wall Mount Chimney Range Hood Logo
78 people viewed this question
Top Bertazzoni Cooktops Experts
Paul Carew
Are you a Bertazzoni Cooktop Expert? Answer questions, earn points and help others
