Question about Bodum Bistro Electric Coffee Grinder - Lime Green BOD-10903-565US
Something rattling when I grind.
Something hard went thru & it shut itself down. Now when I grind it rattles like something is loose inside. Can't figure out how to disassemble to see the motor. The top ring sits loose. It's like the parts are out of sync with each other. The is nothing at all on the net about this machine.
  • bluegirl64 Dec 09, 2014
    I figured out how to get inside. There are 2 evident screws at the bottom and 2 more hidden under the rubber feet. Took it appart and found some of the teeth broken off of the smaller wheel. I imagine it will be impossible to get this new part so I reassembled it until I can no longer put up with the noise. It still functions properly at least. Good luck all. I do like the grinder but from what I read on the net repairs are impossible.
Top refrigerator rattling inside the refrigerator when first starts to run then stops rattling
There is something loose, when first starting the compressor because of its initial load vibrates shakes etc then settles down as the system stabilizes. Move things around inside and see if this helps. If not remove everything and try again, if the rattle is still there it is part of the cabinet, if not it was something inside.
Jan 31, 2016 | Kenmore Refrigerators
I just noticed a rattle when I shut off car...could it be a loose exhaust?
Might be Exhaust, but if Exhaust is loose , you usualy here a rattle when you are also driving the car on the road. Best to take Car to local Repairer , put Car on ramp , and take a look , as it could be something else that Rattles.
Mar 02, 2015 | 2002 Nissan Maxima
Toshiba 3tb Canvio has no power.
Heard something rattling inside huh?....might wanna have ur hard drive closer opened carefully sounds like something is damaged inside if it's not getting power
Jan 09, 2014 | Toshiba 3tb Canvio Desktop External Hd
Qsc hpr153i rattle
Please specify a bit more, does the rattle is physical(Enclosure structure) or electronically hear thru speaker(Power Amp Common Issue)? I have the solution for the amp issue, let me know.
Mar 20, 2013 | QSC Audio Products QSC HPR153I 12 SPEAKER
Rattling, crackling type noise just started and is constant when microwave is running.
A couple of months ago my microwave started making crackling, rattling and grinding sounds everytime i used it and i thought it was going to break down. It turned out one of my children must have spillled or overflowed something with a clear liquid because the micro did not look dirty but there was a crunchy substance under the wheels of the turntable. Once i cleaned this up totally the noises all went away.
Jan 19, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Power comes on, no view thru viewfinder. something rattles inside
Hello, it got the famouse Russian rattle, something has broken loose. For a Night Owl Optics NOCX3 monoculars that is about 5+ years. It is cost prohibitive to have it fix. Aution it on eBay.
You can try to fix it, just remember to draw diagrams of the printed circuit board, show were the wire are attached. Used wire markers to mark the wires because they are all the same color.
It might be just a broken wire. I can fix it, but you'll need to send to me. If you feel that you can't handle this job. Just send me attachment to this message and we will see what we can do. GB...stewbison
Dec 03, 2010 | Night Owl Optics Explorer NOCX3 Monocular
Loud rattle coming from the bottom of engine. mostly heard after letting off the gas, starting and shutting off the vehicle.
Very hard to know without actually hearing the vehicle but,,,With what you describe,the cat/converter 'may' be making the sound.With the car off and engine cool,get under and give the cat/con a really give shove or hit.The insides of them do corrode and the internals make a very loud rattle.If this isn't the problem it will let you see if there is a loose exhaust mount that may also make a rattle.(The cat/con sound is like there is a very loose metal plate hitting something)Its actually the internals of the cat. that have broken loose and rattling inside it.Hope this helps
Apr 09, 2010 | 1996 Jeep Cherokee Country
Loud rattleing sound
If this AC is a thru walled, since it is new it is better to inquire to the people where you buy this unit, for this type of problem. They must have some authorized repair man/shop or, use its product warranty.
The problem could be also uneven placement of its base. This could maybe hitting the fan guard, some loose connection or some foreign object left that's hitting something inside.
Jul 31, 2009 | Kenmore 75085 Air Conditioner
Rattle steering wheel
Sounds like your intermediate steering shaft. Its the slip shaft that runs thru the firewall. They have a slip-stick condition that makes a horrible rattle that you can feel in the wheel. Its a pretty easy repair. Just make sure the steering wheel dosen't spin while you are changing it.
Good Luck
Aug 24, 2008 | 2004 Chevrolet Tahoe
Bodum Bistro Electric Coffee Grinder - Lime Green BOD-10903-565US Logo
Top Bodum Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Peter Meixler
Peter Meixler
Level 1 Expert
ray gallant
Are you a Bodum Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
