Question about Kenwood Food Processors
Ou je peux trouver les pieces de rechange pour reparer mon hachoir a viande sur mon KM201
Partout ou on vendait des pieces je cherche une vis sans fin pour mon hachoir
  • Kenwood Master
  • 1,231 Answers
Www.4Kenwood.co.uk montrent qu'ils ont un attachement de hachoir complete. Vous pourriez peut-etre en savoir davantage la pour les pieces dont vous avez besoin. Vous pouvez egalement attendre que peut-etre les pieces sont desormais obsoletes.
Posted on Dec 14, 2014
Krups xl6 combi blender leaking
Broken fin may not cause the leak because it has no contact with the content. Bad gasket can cause leak. The are available at houseware stores.
Feb 09, 2014 | Krups XL6 Power Combi Food Processor
Tip
Refrigerators and Freezers
IF YOU TRY ANY OF THIS PLEASE UNPLUG YOUR UNIT AND TURN THE WATER SUPPLY OFF FIRST. thank you.
Freezers/fridges remove moisture from the air inside them while they work. At least in my unit the fridge and freezer compartments are connected by a couple little trap doors. One near the top works automatically. I assume it regulates the temp of the fridge part by using freezer air. The other is vented into the meat drawer at the bottom.
Moisture flows to the coldest part of the inside, much like humid air settles droplets on the outside of a cold glass in the summer. The coldest part is the coil assembly which would be behind a panel at the back of most freezers. Below this assembly and hopefully not covered by a panel is a drain hole. It needs to be clear for things to work properly. See if you can find it in the back bottom of the freezer.
If there is ice plugging it you need to clear it. Don't pick at it because the inside of a freezer doesn't like scratches and scrapes. Those create opportunities for rust if the unit lasts long enough. Put a few towels in the bottom of the freezer to catch overflow. Then pour the hottest tap water you can get slowly over the ice. Once it is clear the drain lets the water go into a pan underneath the unit and eventually evaporates. You will hear it when it clears.
Under normal operations this drain collects the water that freezes all over the cooling coils in the very back of the freezer. It is normally very little water. If it is blocked by ice this can point to a slightly bigger problem. You may want to see if you can remove the back panel of the freezer and check the coils for ice. This can a)take a while and b)have you removing a lot of assemblies just to get to one panel screw. So be prepared and don't start it when you have a freezer full of food. If you attempt it and find white fluffy looking ice all over your coils you will need to look below this stuff for an assembly that houses a heater. Mine looked like a long thin tube bulb, much like a halogen lamp. It's called the heater element and replacing it may just fix your problem. I got mine for about $50.
You might also want to make sure your fan and radiator assembly are clean. Inspect the air venting grill on the back. If that is gunked up or you can see that the radiator inside is gunked up, you should carefully remove the panel and vacuum as much as you can. This was a major problem for me because at one time because of indoor pets. If checked regularly it doesn't become an issue.
on Dec 06, 2011 | Food Processors
Where can I find a replacement part for a ge 4-speed food processor model # 10GG22F?
This is what I found on GE website - If you have a warranty claim or need spare parts or accessories, please call our Customer Assistance number. Mon - Fri 7am/7pm cst.
1-877-207-0923 (U.S.) or 1-877-556-0973 (Canada)
Oct 10, 2010 | GE 106622F Food Processor
A sealing ring for my Tefal Sensor; SA SEB 2.7L INOX . Type 3210. Cannot get help on this towards a replacement, after a year of trying. Rose Dennis
IF Your Lucky... Try On kijiji.com it a Sale & Trade Web Pages You fin juste about anything Kitchen accesory, Electronic's Car's House, Anything Try it Never No... good luck
Oct 01, 2010 | Tefal Food Processors
My old mother has bought the Magimix 3200 but is not strong enough to open the lid once it is shut, actually most of the time I'm not strong enough. Can this be fixed?
Cuisinart Elite Food Processors don't require the twist action but the lid clips on, they are very easy to use with a number of great features including seal tight interlocking bowls, blade lock so the blade doesn't fall out when you're pouring out the results a pouring spout, plus a storage box for all of the blades:
http://www.cuisinart.co.uk/products-detail.php?ProductID=53&ProductCategoryID=0&ProductGroupID=1&DiscontinuedOnly=N
http://www.cuisinart.com/products/food_processors/fp-14dc.html
Sep 28, 2010 | Magimix 3200 Food Processor
What des error cde F1 mean on a Jenn-Air D156 drp-in range
JENN-AIR
'Newer Style' Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Power to element relay energized during time of day display Wiring harness shorted or change power relay board (PRB)
Note: for double ovens, change second oven board
JENN AIR
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad)
Mar 22, 2010 | Food Processors
I need a user manual for a Sunbeam food processor
Which model do you have there friend. there is a bunch . I would go here and get what you need. ok. http://www.retrevo.com/samples/Sunbeam-manuals.html
I went there you will surly find it there or one close to it. just download .put file in my Documents and read with Adobi. there you have it good luck. DFD please rate me TK U
Apr 11, 2009 | Sunbeam Food Processors
Rival Mfg. Co Food Slicer 1101E/7 - replacement screws
1101E part number for thumb nut 994-572, threaded shaft 995-254, blade 993-386, idler gear 348-077, washer 854-023, these are the Rival part numbers from the orginal owners manuel
Dec 09, 2008 | Food Processors
I need parts
go to www.estore.fox-international.com
look for Black and Decker products
or call 1-800-738-0245 mon-fri 8:30am-8:00pm E.T.
ordered a slicing blade for model FP1200
very easy
Sep 30, 2008 | Black & Decker FP1300 Quick N Easy Food...
Food Processors Logo
89 people viewed this question
Top Kenwood Food Processors Experts
tfelton3
 Mikey
Mikey
Are you a Kenwood Food Processor Expert? Answer questions, earn points and help others
