Question about Cycling
I have a bycycle frame it's a rare 20 in bike frame I would like to know more about it serialnumber is SNFSD10L26901
    Master:
  • 706 Answers
And I would like to help you but serial number alone Is not enough to identify a bike or frame. The first thing that
s needed is the manufacturer, usually from the headbadge. If its missing there is no real way to identify a bike.
Posted on Dec 08, 2014
I have an old frame cannot identify serial or model C55829
Not usually possible to ID a bike by serial number alone. Only a few brands have serial number that are unique enough to tell what brand they are, and even if you know the brand the serial number will rarely tell you the model, only the year. If there's no head badge (name plate on front of frame) or model decal then it does not matter at all what brand it is. Value is minimal.
Sep 29, 2017 | Cycling
What year is my panama jack bycycle serial number SNHEJ10F69272
Year is not very important, and not possible from that serial number. It's a dept. store bike made by Huffy, so not valuable and uses generic parts used by many other brands.
See my tip:
How to determine the year value etc of your bicycle
Dec 17, 2016 | Cycling
Heighten seat on alollo bycycle how do I do this
Contact local bike shop for assistance
Jul 11, 2014 | Cycling
The frame of my bike is cracked where the seat post goes into the frame.
You'll need to take it to a welding shop to have it properly repaired. Look at how much a similar "used" aluminum bike frame cost, then use that as a gauge to set a cost limit. Say for example a similar used bike frame cost $100 from a bike shop. If the welder charges $80 or more, then you might as well spend the extra $20 and replace the cracked bike frame instead of getting it welded. Of course, you'll need to take the parts off the cracked bike frame and transfer them to the used bike frame, assuming you know how to do it yourself. If you need to pay a bike shop to do the job, then having the welder repair the crack is cheaper.
Nov 28, 2013 | Mongoose Cycling
Have a 1972 tf. 125cc need piston and rings carnt seem to find any so would a newer model tf engine fit in the 1972 frame. If so what year model tf engine would fit best thanks
The cost of the engine would probably cost you almost as much as you would have to pay for a replacement bike. You are talking about a 42 year-old motorcycle. Parts are extremely rare, even used. Plus, if you have to replace the piston and rings, you should really have the cylinder taken to a shop that does boring work to have the cylinder walls checked for elongation and uneven wear, These are measures in thousandths of an inch, so you cannot be sure checking "by Mark I eyeball", You cannot know for sure unless unless you are using a bore gauge of the proper size an a micrometer to calibrate the dial gauge of the bore gauge. I am 65, so I remember when those bikes were new. The tf models were changed quite a bit over their production runs, and unless you happen to run across a mechanic who has done engine swaps on that particular model with another model year you are going to have to experiment, and that might become expensive. You might have to try several different models before you got one that fit, You are obviously not a collector, because an older bike become instantly non-collectable after that kind of engine swap. If you are not a collector of antique motorcycles, give it a decent disposal, and spring for something newer. As I said, the engine is the most valuable part of the bike. If you absolutely need to keep that frame, you will probably have to buy the complete bike, because you will probably have to grind off some motor mounts and weld on those from the newer bike, whose frame you would have to cut apart to be able to grind the remaining frame off the new motor mounts. You are talking about many months and much money to find a suitable donor bike, and then about another month or so to first measure the exact height in the frame your old engine fit, then cannibalize two or three bikes to get the right assortment of mounts to fit another motor. Then you will need to get inventive about the exhaust system, because the exhaust port and the frame mount for the exhaust may not match. More experimenting and measuring. You will need to know quite a bit about pressure waves and sound reflection before you adapt bits and pieces together to make a new exhaust system. Sorry to run on and on, but that is what will happen if you try to play mix and match with any Japanese motorcycle. They made so many changes from year to year that the factory could not even tell you what model engine would fit, not with certainty. Even if the people who worked on that motorcycle were all between 20 and 30, they would be 62 to 72 years old by now. I would suggest you just either give it up as a lost cause, or store it properly (disassembled, parts cleaned and then coated liberally with clean grease) and hope you run across a 1972 tf 125 with a good motor and a bet frame. Stranger things have happened. But not many. I know how hard it is to let an old warhorse go, but I think you will have to. Sorry, but I am retired too, and it even happens to motorcycles.
Oct 30, 2013 | Suzuki Motorcycles
Hi all I've got an earth issue don't know much about bikes I've got a kmx 125 b12 I know their rare thats what it says on the logbook, all I want to know is where abouts is the earth that goes in the frame...
Most systems are the same the negative of the battery is connected to the frame by a heavy 60amp cable,
quite close to the battery, the engine is bolted to the frame 'so that gets an earth', then earths are connected to the frame or engine as required, earth wires are generally grouped to earth points to frame, ie: under tank near head stock, under seat near back light cluster. Hope this helps
Oct 29, 2013 | Motorcycles
Unable to remove seat stem from frame - any sugguetions
Web search it "remove seat stem from frame ". Many postings.
Sep 05, 2011 | Mongoose Maneuver Mountain Bike
Replacing occ stingray front end
As long as the neck of the fork that goes into the frame is the same length and width (or circumferance) it should fit.
Feb 13, 2009 | Cycling
Cycling Logo
71 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
