Question about Food Mixers
Just recieved the kitchenaid artisan 5qt mixer and doesnt work.. took it out of the box plugged it in and nothing but a light humming noise. Never mixed or moved.
  • Food Mixers Master
  • 1,267 Answers
Don't mess about with it, excercise your rights and let them sort it out under guarantee. If you mess about with it that will be an excuse for warranty to be denied.
Posted on Dec 08, 2014
  • 12 Answers
SOURCE: KitchenAid Mixer Squeaking
I would first get some canned air. Spray out the area around the Shaft. This is to make sure no harden food is up there. After that is clean spray some cooking spray "PAM"in the Shaft area. This should help. Good Luck
Posted on Feb 11, 2008
  • 25 Answers
SOURCE: kitchenaid mixer mades a high pitch squeak when mixing
Take it to a local repair shop and they should be able to fix it in no time.
Posted on Mar 26, 2008
  • 145 Answers
SOURCE: KitchenAid wobbles when mixing
The "wobbling" sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Also, leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
Posted on Jul 08, 2009
  • 4 Answers
SOURCE: kitchenaid mixer makes a lot of noise. The beater
Hi - I've been searching for general info on KitchenAid stand mixers and ran across this so I'm throwing my $.02 in... Since KA stand mixer bases are essentially made of cast metal parts, there is a very slim chance that there is a lateral misalignment (side-side) unless it got dropped...eek! Sounds like a head height adjustment issue. Check out this from KitchenAid Conversations:
http://forum.kitchenaid.com/forums/topic.asp?TOPIC_ID=3032
Good luck.
DZII
Posted on Jan 03, 2010
Testimonial: "Thank you for your post. I will check out the suggestionsl"
SOURCE: KitchenAid Artisan KSM150BOB Stand Mixer won't start
It could be very easy. It maybe you have a the brush in the wrong way round or they have simply run out. They are on the sides under the black plastic caps. Although they will fit in the hole any one of 4 ways round, there is a key on one corner which means it will only go in one direction. Use a torch to look into the hole before you put it back in.
They shoud look like this : brush
Posted on Jan 24, 2010
My Kitchenaid mdl: KSM 155gbca is making a loud bumping noise with or without an attachment.
It is more than likely in the planetary or the fuse gear inside the gear box. Try it once you have the planetary off before you go looking inside the gear box. Easiest is planetary problem but far far more likely is the fuse gear.
Aug 08, 2014 | KitchenAid Artisan Series Tilt-Head Stand...
The Kitchenaid Artisan stand mixer is spinning too fast after a voltage fluctuation.
Replace the phase board, that's the small pcb under the back cover with 6 wires coming out of it.
Feb 13, 2014 | KitchenAid Stand mixer 5qt art red
Where can I get a manual for my K5M150PS 5Qt Artisan mixer. Do not have a manual. I purchased this mixer last Jan and just opened the box. Could I find out what speeds 2,4,6,8, and 10 are until I can...
Hi and welcome to FixYa, I am Kelly. You can download the 60 page manual here:
http://www.ambientedirect.com/skin/frontend/ambiente/default/media/2184.pdf
The pdf file is copy protected so I can not copy and paste the speed control page. You will have to download the manual. Rt click, save as.....
The speed control guide is on the printed page 15 (green page number bottom of the page)
The guide states you also can select speeds 3, 5, 7, and 9 by moving the selector in between 2, 4, 6, 8, and 10
Thanks for choosing FixYa,
Kelly
Dec 15, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Think I have blowon the motor on my American pruchased Kitchenaid
Perhaps you may be lucky to have blown a protection diode within the circuit seek pro advice
Apr 09, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid mixer makes a lot of noise. The beater
Good luck.
DZII
Jan 02, 2010 | KitchenAid KP2671 Professional 6 Series...
The pump doesnt seem to be working. No pressure for the water.
I'm sorry. Kitchenaid stand mixers do not have a pump in the motor, nor are they used for dispensing water.
Jul 06, 2009 | KitchenAid Artisan KSM150PSSM Stand Mixer
KitchenAid Artisan Stand Mixer missing plug/where is outlet?
I can only imagine you have a shop display machine and they took the plug off. Otherwise it should be obvious.
Mar 22, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Theres a loud squeaking noise when the mixer turned on
Hi. These mixers normaly make a lot of noise when in operation. Go to the shop that sold it to you, or any place that has these units on display and ask them to turn on the mixer for a demonstration. If their mixer does not make the same noise, then contact Kitchenaid Customer Service and ask for a replacement under warranty. If this solution assists you, please rate it. Good luck! ricardok45
Mar 05, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Food Mixers Logo
59 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
