Question about Samsung Dryers
Why won't the dryer run
Unplugging, unloaded the dryer, making sure door is shut good
  • Samsung Master
  • 744 Answers
Hello Karla;
My name is Peter. I am a retired field service appliance technician.
The are generally several components that will prevent your dryer from running.
1.) The door switch.
2.) The thermal fuse
3.) The thermostat
4.) And perhaps the motor drive pulley contact switch.
I am giving you a link. Type in the dryer model number and you will see where these components are located.
Water Filters Lawn Garden Appliance Parts
Posted on Dec 07, 2014
Replace fuse dryer model GEQ8821LLO
Hello;
You never explained what the problem was. Dryer not running? No heat? Dryer shutting down. It could be as simple as cleaning out your dryer hot air distribution manifold. A dryer will not run if you do not have good air flow due to lint blockage. A dryer will not run if you have a bad door switch. You can Ohm components out with a multi-meter, setting the meter to the lowest Ohms (Omega Symbol). You should get a reading of "0" if the component is good.
1.) Dryer Door Switch - This switch replaces your dryer door's switch.
  • You may need to remove your dryer's lint screen and lint screen housing before lifting its top panel to reach its existing switch.
  • Be sure your dryer is unplugged during installation.
This Dryer Door Switch part #3406107 Cost $20.00
Dryer Door Switch - Unplug the dryer before replacing the door switch.
This Dryer Door Switch part #279782 Cost: $22.00
Thermal Cut-Off- This component is located on your heating element housing,. you may be able to access it at your hot air distribution manifold in the back of your unit.
  • When replacing your dryer's fuse, replace its thermostat, too. The thermostat should have prevented the dryer's existing fuse from blowing. The high-limit thermostat is functional to 250 degrees (Fahrenheit) and the thermal cut-off fuse to 360 degrees (Fahrenheit).
  • Install the fuse in your dryer's heater element housing box. Be sure your dryer is unplugged during installation
  • Part #: 3977394 Cost: $33.00
    25432459-jpgjqed1aonpcy4b0i04xdgb-5-9.jpg Cost: $34.00
    The high-limit thermostat replaces your dryer's thermostat.
    • The thermostat is functional to 250 degrees (Fahrenheit).
    • Install the thermostat in your dryer's heater element housing box. Be sure your dryer is unplugged during installation.
    This High-Limit Thermostat part #3390291
    Hot Air Distribution Manifold:
    This is in the back of your dryer and easily unbolted. If you are plugged up with lint your unit will shut down. Remove this component and clean the lower discharge end.
    25432459-jpgjqed1aonpcy4b0i04xdgb-5-14.jpg So, tell me what the problem is, and I will tell you how to fix it.
    Peter,
    Glen Burnie, Maryland, USA
    Feb 15, 2015 | Whirlpool Dryers
    Frigidaire affinity Dryer wont turn on
    see this causes and fix it.God bless you
    Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
    Start Switch The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
    Door Switch The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
    Drive Motor The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
    Drive Belt On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
    Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
    Incoming Power Problem If the dryer won't start, check to certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
    Belt Switch If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
    Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
    Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
    Sep 28, 2012 | Frigidaire GLER642A Electric Dryer
    My Maytag Neptune electric Dryer will not stop unless it is unplugged or door is opened.
    check the door switch,when you open the door the dryer shouls stop,push in on the door switch and let it out,it should click when it pops out,if the switch broke pushed in it won't shut off.the part number is W10169313 and it's around 16 dollars,
    Jan 10, 2012 | Maytag Neptune MDE5500AY Electric Dryer
    My dryer ran fine with my last load of only 3 towels. I haven't had any problems with my dryer before. I went to "wrinkle release" my towels and nothing happened. No lights, no 18min. showed...
    There can be many reasons why your dryer will not start or turn...
    The most common causes are the belt breaking or jumping off, or the motor goingbad...
    Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
    Dryer Repair - The Dryer is not Turning
    Dryer Repair - The dryer will not start
    heatman101
    Aug 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
    It will not run, checked the wall outlet and it good, tried leaving it unplugged for a little while then tried again. Other problems were that when you would open the door in mid drying cycle the drum is...
    Hi cassandra838...
    ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
    Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
    Check your Wiring
    Often the main wiring connection from the house, at the dryer, burns and the connection breaks.
    If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
    Check the Door Switch
    If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame.
    Sometimes you need to raise or open the top or front of the dryer to reach the switch.
    Check for continuity you should have none with door open, and should have a reading when closed.
    If not replace the door switch.
    Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
    If the vent's clogged, that new element can burn out very quickly.
    For video and pictures on how to replace an element go to the following website:
    davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
    This is a FREE answer, Please rate me
    Apr 26, 2011 | Roper REX4634KQ Electric Dryer
    My dryer was workin yesterday i stopped to get a shirt out an shut the door then pushed start but nothin happened
    Try unplugging it and plugging it back in then starting it like a new load. My grandkids have opened the door while ours is running and that seems to help.
    Feb 13, 2011 | Kenmore Dryers
    Problems with GE DWXR483EBWW Electric Dryer. Dryer will not start (no spin,no heat, no attempt to start). Has Power because interior light works. About 6 mo ago start switch was replaced...does not appear...
    If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a broken door latch, a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
    Nov 11, 2009 | GE DWXR483EBCC Electric Dryer
    Suddenly stopped working will not start at all any setting
    assuming that the circuit breaker or fuse is not blown, this is most likely caused by the door switch. if the door is not closed, the dryer will not turn on, period. you will have to try to jump over the 'possibly bad' switch. first, shut off the breaker. second, wrap a putty knife with masking tape to prevent scratching up the dryer. then, use it to pop open the plastic catch on each front corner. take your time and look inside the small gap with a flashlight to help figure it out. after you have the top of the dryer safely tilted back, look for 2 wires running to the door. they will plug into a switch that is flipped when you close the door completely. you know what i mean, it probably used to click when you shut the door. unplug these wires from either side of the switch. use a piece of wire to connect them or just tape the metal ends together. this will bypass the door switch. make sure all metal parts of the wires are covered to prevent a short on the metal walls. be sure the now loose wires will not get caught on anything, like a rotating drum. close the lid most of the way. turn on the breaker and try to operate the dryer. if it now works, replace the door switch. be careful, opening the door will not shut off the dryer now. good luck
    Nov 02, 2009 | Kenmore 62802 Electric Dryer
    Dryer switch
    yeah but its unsafe specially with kids! it could stay running if the door was open and wont stop unless you turn the knob or unplug it. thats if it was bypassed.
    Apr 17, 2009 | Whirlpool LER4634J Electric Dryer
    Kenmore dryer
    IF THE DRYER COMES ON BY ITSELF WHEN THE TIMER IS SET AND THE DOOR IS CLOSED, THE PUSH TO START SWITCH IS SHORTED. THIS WILL CAUSE THE END OF CYCLE SIGNAL TO BUZZ WHEN THE TIMER IS IN THE OFF POSITION(END OF CYCLE).UNPLUG THE DRYER, REMOVE THE BACK PANEL OF THE CONSOLE, AND REMOVE ONE WIRE FROM THE PUSH TO START SWITCH. ISOLATE IT SO IT ISN'T TOUCHING ANYTHING AND PLUG THE DRYER BACK IN. SET THE TIMER AND CLOSE THE DOOR. IF IT DOESN'T START UP OR BUZZ, UNPLUG THE DRYER AND REATTACH THE WIRE. PLUG THE DRYER BACK IN AND SEE IF IT STARTS BY ITSELF. IF IT DOES, THE PUSH TO START SWITCH IS SHORTED AND WILL NEED REPLACED.
    Apr 01, 2008 | Kenmore 62602 Electric Dryer
    Dryers Logo
    78 people viewed this question
    Top Samsung Dryers Experts
    Tim Whalen
    Dan Webster
    Dan Webster
    Are you a Samsung Dryer Expert? Answer questions, earn points and help others
