Question about Hotpoint Refrigerators
After 20 yrs of perfect operation, my hotpoint side-by-side is leaking water outside the unit in front. noting is defrosting.
  • Hotpoint Master
  • 744 Answers
Hello;
My name is Peter. I am a retired field service refrigeration technician.
You have ice buildup on the bottom of your freezer. Two things will cause this:
1.) A frozen drain. This is common. You unit goes through a defrost cycle every 8-10 hours for 20-30 minutes. Everything shuts down except for the lights. You defrost heater is turned on. If your drain is frozen the condensate has no where to go except for the bottom of the freeze.
2.) A restriction in your refrigerant seal system capillary tube or you have a refrigerant leak. If you have a block of ice build up in the upper right hand corner of you freezer evaporator (Cooling) coil, then you have a major problem. You are probably looking a $450.00 + repair.
You will have to remove the freezer back wall cover to determine which situation you have.
Posted on Dec 07, 2014
Frost in freezer, fan in freezer sometimes changes speeds, low pitch or humming noise,manualy defrosted it 1 month ago seemed to be fine for two weeks, vegies freeze in drawer. hotpoint hss25gfta 5 yrs old
If the defrost thermostat is bad it will need to be replaced, otherwise you will have to continuously manually defrost the unit. The noise you hear is probably the fan hitting the ice. The defrost thermostat assists in melting that ice about every eight hours.
May 15, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
My side-by-side Frigidaire is 3 yrs. old. Yesterday it started leaking water around the outside of the ice/water dispenser. No leaking on the inside. can the front panel be removed? what would make it...
Hi, look for a small aperture inside compartment. thin stiff copper wire and clear blockage. Being firm yet gentle, you could damage tubing!
This hole is the defrost exit which usually exits into a tray were the heat of the motor evaporates the defrosted ice.
May 12, 2011 | Frigidaire Refrigerators
HOTPOINT AQUARIUS DISHWASHER...FRONT LEAK
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
870943q45
Jun 15, 2010 | Hotpoint 24 in. HDA3740G Built-in...
My ice machine works fine but I'm not getting any water to the outside button to receive water.
Hi .. ypur problem is likely that the tube running to the water dispenser is frozen .. you should defrost the unit and free the water tube of any ice or obstruction.
May 03, 2010 | Hotpoint HSS25GFP Side by Side...
New inverter reverse cycle leaking water out the front of the unit. Its 44 degress outside, could this be the problem?
Is it leaking out of the evaporator(inside unit) or condenser?
If it is leaking from the outside unit on defrost then it is normal, if it is leaking from the inside unit then you have a blocked condensate drain tube!
These units defrost from time to time and is normal, it is actually melting the ice that can form on the condenser when it is cold enough outside, it has to initiate a defrost cycle so that air can flow through the condenser again after the cycle is complete.
Then it will return to normal heat pump mode, this is assuming that you have a heat pump.
Jan 11, 2010 | Fujitsu Electronics - Others
Water leaking at rear
It is probably the hose washer or crimp thai is leaking.
I would suggest that you replace the hose to be on the safe side.
Jan 08, 2010 | Hotpoint Aquarius WD63 Front Load...
Hotpoint csx22d side by side has leak under freezer side @ door...coming from wiring harness that runs up into bottom of freezer maybe??????
This leak , is coming from the defrost drain , inside the freezer section , at the back . The defrost drain is clogged with ice . Remove the bottom freezer crisper , and use a hairdryer to defrost the ice . You will see a drain hole where the defrost water is supposed to drain thru . Hot water helps defrost this hole . Once defrosted , use a small hose inserted into the drain hole , to blow thru , to remove built up debris , inside the unseen drain line .
Sep 16, 2009 | Hotpoint HSS25GFP Side by Side...
Water starting to pool (two tablespoons) under front of frig under door, is there a pan in the bottom of this unit?
Most fridg's have a water pan below. Need to drain occationally, especially after defrost cycle.
Apr 30, 2009 | Refrigerators
Leaking water from front passenger side, under dashboard
It is either condensation water from the A/C unit that should go out a drain tube to the outside (only if A/C or Defrost is on) or a leaky heater core. If it is a heater core you can usually smell a coolant smell and the water will be warm and your windows will fog up inside. Heater core is more common. Joe ASE Master Tech
Feb 18, 2009 | 1999 Chevrolet S-10 Pickup
Refrigerators Logo
48 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
