Question about Dryers
Moffat Dryer, when I press the Start button, it works fine but if I release it does not run at all
I changed the Motor but it was not the Problem
    Master:
  • 474 Answers
The motor was the expensive part. I would have checked the switch first. If its on when you hold it buttndoesnt stat on when you let go then its most likely the switch that button engages is not staying seated and pops out instead of waiting for the signal at the end of the cycle. If its a newer and under warranty dryer then warranty it out but since I'm guessing its not, weigh the cost of a new one vs paying some company to fix it. You may be able to find a replacement switch online like eBay. This would not be to hard to change out.
Posted on Dec 08, 2014
Maytag performance dryer model PYE2300AYW won't stay running after releasing the start button
Maytag Dryer Won't Start - Testing the Start Button - YouTube
? 1:26
https://www.youtube.com/watch?v=gJwYV8HkTbk
Oct 7, 2013 - Uploaded by Bill Newberry
This video shows you how to test the start button on a MaytagDryer. ... dryer medc200xw0 will not keep running after releasing the start button.
GE Dryer won't stay on after turnin
Dryer won't continue running when start button released ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Jul 25, 2014 - 3 posts - ‎2 authors
When I push and hold the start button the dryer motor starts and heats. It will not continue to run when I release the button. All thermostats ... button released. Model Number: PYET344AYW Brand: Maytag Age: 5 - 10 years .... Check for 120vac on the purple wire at motor after releasing start button. If it goes ... GE Dryer will not stay running when start button released ...
Jul 26, 2014
Starts but won't stay running
Sep 12, 2013
Dryer won't stay running
Apr 23, 2011
Jan 11, 2011
More results from forum.appliancepartspros.com
Jan 01, 2016 | Maytag Dryers
Whirlpool dryer runs, hums, then quits
Sounds like the motor is on it's last legs. Replace it. But, before paying huge money for a motor and the labor to install it, I suggest that you price a new dryer and compare it to the repair costs. It may still be a little more for a new dryer, but....IT'S NEW!
Mar 20, 2017 | Whirlpool Dryers
I have a ge model# gtdx100emoww electric dryer that will only work if the start button is held in. Once released it stops.
Yep, it's the start/run switch at the motor, can get stuck with lint after a long time. It's actually not too difficult to change, make sure you note the location of every wire. Clean everything real good with a vacuum cleaner, get all the lint dust out of the motor, etc.
Cleaning may free the switch, and there should be a drawing showing how to put the belt back on, otherwise, make a drawing.
Nov 22, 2013 | Kenmore Elite HE4 Electric Dryer
My dryer will only run if i hold in the door switch button and turn the drum while i hit the start button.
That is a bad sign. If the buzzing starts when you press the start button and stops when you release its almost safe to say that the motor has a dead short or grounded out and causing that to happen. You can check the start switch by getting a multimeter and with the dryer unplugged take the wires off the switch, place a lead on each pin and press the start with meter set for continuity. If it shows continuity when presed and stops when released your motor is shot and needs to be replaced.
Now if you press the start button and the machine starts to hum and continues to hum its possible that something has gotten caught in the blower wheel and binding the motor up. Depending on the make and model the location and access to it vaaries.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 04, 2012 | Maytag Dryers
MOFFAT PLATINUM MOD# rwxr463etoww, SER#tm7o2962a DRYER WILL SHUT IS SELF OFF AFTER 10MIN. OF OPPERATION. LOUD NOISE FROM TURN ON SWITCH BEFORE UNIT STAYS ON FOR TEN MIN THEN SHUTS OFF. CHECKED...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Motor is burning up internally...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 11, 2010 | Dryers
Dryer runs about 5 seconds, buzzes and stops
Apr 19, 2010 | KitchenAid Dryers
Dryer won't run if start button released. Also
Sorry to say but the start switch on the motor has gone bad or may be coated with lint. Try cleaning lint of motor and motor start switch and see what happens. If still not working motor is bad.
Jan 27, 2010 | Dryers
Press start button and dryshuts off when start button is released
There is a switch assembly on the motor that activates when the motor is running. Centrifugal switch. It keeps it running when you release the switch. That is where to start. Eric
Jun 11, 2009 | Kenmore 74992 Gas Dryer
Maytag performa dryer won't run right
bad motor,,should have change it when you had it open,,thats the overload you hearn inside the motor,,when hot it clicks off and when itcool it will run a while than click off...again...need help changing ..
Dec 29, 2008 | Maytag PYE2300AY Electric Dryer
Maytag PYE2300AYW starts when I hold the button in, but will not stay started.
The motor will need to be replaced. There is a throw-out switch on the motor that keeps it running after you release the start button. These are generally easy to change, with the only hard part being taking the cover off and putting it back on. http://www.partstore.com/GetModel.aspx?MfgName=Maytag&BrandName=Maytag&ModelNumber=PYE2300ayw&PartCategoryName=&Keywords=motor Any of these motors listed will fit your unit.
Sep 17, 2007 | Maytag PYE2300AY Electric Dryer
Dryers Logo
57 people viewed this question
Top Dryers Experts
