The drum does not rotate and I hear a squealing noise
  • 88 Answers
If it is squealing, the belt is slipping. Check the belt, or the tensioner.
Posted on Dec 07, 2014
I have LG 6kg WP9032 machine. When i operate drier a peculiar sound is coming. Looks like something is stuck underneath the drier.How
Stuck under where ??? Between the drum and the housing inside ? Many times underwires from bras that come loose will get caught between the drum and make a squealing/squeaky noise.. look inside along the edges of the drum and see if you can see anything unusual sticking out..sometimes rotating the drum manually helps find it.
Jan 23, 2018 | LG Washing Machines
Really Bad Squeeky Noise
It could be a squeal from the dryer belt. It could be from a belt that has gotten loose, like you hear on a car sometimes when it first starts up, but usually they don't get loose. They just break. Maybe something has gotten jammed between the dryer drum and the interior of the dryer making it hard for the belt to turn the drum and so it is squealing. Does the drum turn by hand without too much force and without squealing?
Feb 10, 2014 | Siemens WTXD5300US Electric Dryer
Loud noise during rinse cycle
Hi
If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. Also check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 03, 2011 | Frigidaire Washing Machines
Dryer making a grinding noise when turned on. How do you get the top off to check the barrel motor?
Clanging Sound
1. If the noise coming from your dryer can be described as a clanging sound, the solution is probably well within your grasp. This common sound is typically the result of loose debris accidentally put in with the load of laundry. Change may be left in pockets of pants or other objects may be dropped in the laundry basket by children --- perhaps a toy car. The objects may not be noticed when put into the wash, and the water in the washer may have dampened the sound. Simply remove these items, and restart the dryer to resolve the issue.
Sometimes the clanging is from snaps or buttons that are actually part of the clothing. If you are drying a jacket with metal snaps or another garment with metal attached, you should expect this clanging sound as they tumble and strike the inside of the dryer tub.
Humming or Whistling
2. Many Roper dryer models are equipped with a safety feature known as a lint signal, which is usually a light that often accompanies a warning signal, telling the machine owner that the lint trap has become clogged. When the dryer cannot pull adequate air through the lint filter, it can overheat and become a fire hazard. The warning alarm may sound like a hum or whistle to get your attention. Look at the lint signal light, clean out the trap and the noise should stop.
Thumping or Grinding
3. If the noise you are hearing can be described as a thumping sound or a metal grinding sound, the device that turns the dryer drum, known as the drum rollers or glides, can be worn out. As the drum turns, there may be a constant and rhythmic thump each time the drum rotates. A severely worn or broken roller could cause the metal of the drum to rub against the metal housing of the machine, causing a louder grinding noise. The rollers will need to be replaced to remedy the problem.
Squeaking or Squealing
4. Most dryers work by using belts to turn the rollers, which in turn make the drum rotate and tumble the clothes dry. When these belts get loose, a worn belt or a malfunctioning tensioner spring may keep the belt tight. In either case, belt slippage may occur and will produce a squeaking or squealing sound that is easily recognized. The problem is likely to be the tension on the belt since most belts will break before wearing out to this degree.
Feb 24, 2011 | Whirlpool Dryers
My maytag dryer has a loud squeal. I replaced the belt, but the squeal persists
Check to see if the belt has landed in the groove instead of on the outside of the drum. One might assume that the groove is there for the belt, but inspection of the drum will show previous belt location about an inch beside it. To fix, rotate the drum counter clockwise while pulling the belt away from the groove on the bottom of the drum. Once it has rotated a complete revolution, it should be in alignment and the noise should disappear.
Jan 14, 2011 | Maytag MDE8000 Dryer
My maytag model no.mav4755aww makes a whinning sound at the beginning of the spin cycle
Hi
Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.Since you hear whining it means that the bearing is damaged and the seals on bearing are gone too so it rotates without lubricant. It might be possible to hear whining while you rotate empty drum manually...
Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. When the bearings have gone bad, the noise is constant the entire time the drum is spinning.
Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.Then replacing the bearing is suggested.
Let us know if you want something more else accept the solution.
Thanks for contacting fixya.com
May 22, 2010 | Washing Machines
My GE Profile Dryer is still operating but produces loud intermitent noise as the drum rotates. What can I do to eliminate the noise?
It sounds like you may have a bad bearing in the back of the drum. That model rotates on a sort of ball and socket type mechanism. You may be able to lubricate it if the noise is just squealing/squeaking. If it is more than that, you'll probably need to replace the bearing mechanism. If you lube it, use a heavy weight lube that is rated for high heat (I've used brake caliper grease.)
Jan 03, 2010 | GE Profile Prodigy DPSR513GA Dryer
Noisy bearing
1 Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
  • Step 2 Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
  • Step 3 Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
  • Step 4 Clear the water pumpmag-glass_10x10.gif from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
  • Step 5 Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
  • Step 6 Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
  • i think this will help you
  • Aug 03, 2009 | Washing Machines
    Squeal noise from the dryer
    check the belt tention. or you may need to lubricate the wheels the drum sits on.
    Jul 16, 2009 | Dryers
    The dryer just makes a humming noise when I turn it on, but won't turn all the way on
    When you say it won't turn all the way on, does that mean the drum isn't rotating?
    If yes, the belt from the motor that goes around the drum might have broken and you can hear the hum of the motor spinning but no longer rotating the drum.
    The other thing I can think of is that the motor itself has failed, possibly seized, and you can hear the motor trying to spin but it cannot. With the dryer unplugged and empty of clothes, try to rotate the drum. If it rotates extreamly easily, then the belt has broken. If you cannot rotate it at all by hand, then chances are the motor is seized. It should rotate with moderate effort.
    Mar 08, 2008 | Dryers
    Washing Machines Logo
    Top Washing Machines Experts
