Question about Chevrolet 2010 Chevrolet Express 1500 Work Van
How many freeze plugs are on a Chevy Express van 2001?
I found one in the front, but where are the others please?
SOURCE: 1996 chevy express van audio wiring diagram
go to www.the12volt.com
Posted on Aug 31, 2008
  • 10 Answers
SOURCE: Wiring/electrical schematic info for a 2000 chevy express van
Check www.autozone.com.
Posted on Jun 14, 2009
  • 14036 Answers
SOURCE: I need the serpentine belt diagram for a chevy Express Van
DRIVE BELT DECAL SHOULD BE UNDER THE HOOD.OR YOU CAN GO TO DEALERSHIP GET ONE AUTO ZONE OR ADVANCE AUTO PARTS CAN GET YOU ONE.OR YOU CAN BUY A HAYNES REPAIR MANUAL IT HAS BELT DIAGRAM.
Posted on Mar 10, 2010
goalie39
  • 469 Answers
SOURCE: how do I change front turn signal light on 2006
If you look at the gap between the fender and the grill on the outside edge of the grill at the level of the turn signal, you will see a grey tab, if you push on this tab while pulling out on the lamp assembly. The whole assembly should swing out and allow access to the bulbs.
Hope this is of some assistance.
Ed
Posted on Mar 29, 2010
  • 4 Answers
SOURCE: Reverse and interior lights out, chevy express van
Fuse block under the hood. Driver's side, under the brake master cylinder. Number 18. TCB#2. Replace the fuse.
There is an under-engineered ground in the reverse circuit. If you back up with the dome lights on, it could blow that fuse. There should be some extra fuses under the cover of the fuse block.
Posted on Aug 05, 2010
Chervorlet 1999 express van 1500
Ron, Check the rear A/C expansion valve for being plugged. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Diagnosing rear problems
Chevy explorer van rear fix
EXPRESS REAR EXPANSION VALVE or EVAPORATOR or FAN MOTOR REPLACEMENT...
Jul 10, 2016 | Air Conditioning Condenser 1999 Chevrolet...
Need advice or new ideas for our 2001 chevy express
Please contact Authorized Service Station. Forcing anything with such troubles may be Hazardous!
Apr 28, 2014 | 2001 Chevrolet Express
2001 chevy express van 1500, rear blower motor location
Inside the van, all the way to the rear, on the side, will have a nice looking panel over it, remove panel and you'll see blower motor, held on with about 6 small screw's.
Aug 05, 2010 | 1999 Chevrolet Express
Ac blows everywhere and cant change to heat or defrost this is a 2001 chevy express 2500 van and it just happened all of the sudden any help would be a great help
hte vacumn pipe from the inlet manifold ,renew it ,but you have to remove the inside engine cover to gain access,also observe the T pieces and the feeds to the other places ,easy job to do ,its just getting all the inside out
Aug 01, 2010 | 2001 Chevrolet Express
2001 chevy express van 3500 while driving security light comes on dash then engine shuts down , once pulled off the road it will start back up.. did this 3 times on hour drive.. feels like gas pedal just...
You need to get the codes from the theft deterrent module.Usually a B2960.This will help in the diagnosis of the problem.Hope this helps.Good luck.
Apr 07, 2010 | 2001 Chevrolet Express
2004 chevy 3500 express passenger van transmission
if ur replacing it remove front grill disconnect both lines and carefully remove retaining clips from radiator if replacement is original eguipt mount & reconnect --if its a universal follow instructions usually cut off fittings and use clamps and hose to hook up
Oct 27, 2009 | 2004 Chevrolet Express
I have a99 Express 12 pass. van i get backfire and lack of pickup until i get to about 40mph sometimes and then others times it just runs fine.
2002 Chevy Express Van>>>>with headlights off--the rear left taillight works, but no right. When the brakes are stepped on, both taillights don't work. Also, the little lights under the back doors are out. Also, some lights are dim>>rear only.
Nov 05, 2008 | 2001 Chevrolet Express
Chevrolet 2010 Chevrolet Express 1500 Work Van Logo
64 people viewed this question
Top Chevrolet Computers & Internet Experts
Richard Warren
Richard Warren
Devon trahan
Level 1 Expert
Jeff Armer
Are you a Chevrolet Computer and Internet Expert? Answer questions, earn points and help others
