Question about Canon Cameras
Canon PC 1586- Flash not working after camera was dropped. Is the camera done for a flash use? Crooked or broken arrow just flashes.
Canon PC 1586- Flash not working after camera was dropped. Crooked or broken arrow just flashes on screen when trying to use flash.
    Sergeant:
  • Canon Expert
  • 454 Answers
I don't think this is something you can fix yourself. Take it to the repair shop.
Posted on Dec 27, 2014
  • 188 Answers
SOURCE: flash not working
the flash bulb or tube does not go off suddenly. it gets weak after yers of usege or breaks only if the camera is dropped. most of the flash related problems occour for non charging of the flash. pls contact local repairer for this problem
Posted on Jun 21, 2006
SOURCE: Flash
Did you try to reinitialize? Setup menu go down to the third Setup#1 menu and make sure you click OK to reinitialize. That's what the manual said.
Posted on May 18, 2007
I had the same problem with my flash not working on any setting, but I found a way to fix it: hit the menu button, make sure the "rec mode" choice is set to normal instead of burst. I think the burst mode takes multiple shots in a row, so the flash isn't compatible with that setting?
Posted on Mar 30, 2008
  • 155 Answers
SOURCE: Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Posted on Apr 09, 2009
  • 919 Answers
SOURCE: flash Does not work. Can only take pictures in flash-off mode
The problem you are describing is a problem with the flash charging indicator switch inside the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $83 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Posted on Jun 03, 2009
How do I turn off the flash on my Cannon pouershopt SD1000?
Hello and Welcome to FixYa!
To turn off the flash follow the given steps:-
  • Turn on your Canon PowerShot SD1000 Digital Camera
  • Press the Flash Right Arrow button on the four-way control on the back of your camera to display flash options on the camera's LCD screen
  • Now push the Left Arrow or Right Arrow button to select the flash "OFF" icon. It's the third icon that display the flash symbol crossed out by a backslash symbol inside the circle.
I hope this solution helps you
For Further assistance, I am here to help
Thank you and Keep using FixYa!
Jun 02, 2011 | Canon PowerShot SD1000 Digital Camera
My flash is not working. the icon keeps flashing for a long time before taking the picture before it takes a picture. I've reset the settings and tried all the different modes and cannot get ii to...
I found this somewhere else and I was surprised that it worked. Reset to default settings. Press menu, arrow right to the tool menu. Arrow down to Reset All, arrow right to yes.
I had tried different batteries, even alkaline to get it to work thinking that my batteries were old and weren't charging the flash. I saw that someone had done the reset all to fix it. I did it and tried to take a picture, the icon flash twice and then the flash charged up and took the picture. I replaced the batteries to lithium and now it charges up right away. I hope that helps.
Dec 26, 2010 | Canon PowerShot A590 IS Digital Camera
How can I turn off auto flash in my canon sd 600 camera?
Press the flash button (right-arrow on the control panel, marked with a lightning bolt) repeatedly to cycle through the flash settings. To turn the flash off, select Off, marked by a lightning bolt in a circle with a slash through it.
Don't forget to turn it back on when you're done.
Jun 22, 2010 | Canon PowerShot SD600 Digital Camera
Flash Does not work. canon sd1000
This happened to my SD1000 and I followed the step by step instructions shown here:
http://www.ifixit.com/Guide/Replacing+Canon+PowerShot+SD1000+Broken+Flash+Unit/7778/1
and when I got to step 15, I found that the small plug that connects the flash to the camera body had been disconnected when the camera had been dropped. I simply pressed the connection back in tight and reassembled the camera - and it works. Maybe this happened to yours too??
Dec 10, 2009 | Canon PowerShot SD1000 Digital Camera
Camera dropped in water, flash broken
http://www.fixya.com/support/r3771170-phone_water_damage
Jan 01, 2009 | Canon PowerShot A70 Digital Camera
How do i get brighter pictures
There are only two options for adjusting the brightness of pictures in this camera, exposure and flash setting.
1. Flash Options: The flash is off by default. To turn it on you must press the button with the crooked down-arrow label between the DISP and MENU buttons, and the flash status will display in the top right-hand corner of the display screen. OFF displays the crooked down-arrow and a circle with a line through it. Press the button once for AUTO, displays the crooked down arrow with an "A" next to it. Press the button once more to force the flash, displays the crooked arrow only in the top right-hand display. Regardless of mode, the display will blink rapidly while the flash is charging and remain solid when it is charged and ready for use. Keep pressing the crooked down-arrow button to scroll continuously through the three OFF/AUTO/ON options.
2. Exposure setting: Press MENU, then the left arrow on the top right-hand four-way button on the camera until the COLOR menu is selected. Scroll down to EXPOSURE and press the MENU button again. You will see EV on the display. Use the up and down arrows to increase or decrease the exposure setting. 0.0 is default, you can go up to +1.5 or down to -1.5. Press MENU to exit when you're done. +1.5 would be the maximum brightness setting.
Oct 13, 2008 | VuPoint DC-M306AT-VP Digital Camera
Canon SD1000 flash not working
May 24, 2008 | Canon Cameras
Flash troubles- timing off or something?
this problem is fixable. set the camera under the fill-in flash mode. do the ff:
-click the flash button, (right button that has broken arrow on it)
-click it for many times until you see the icon of a big crooked arrow without something with it on the screen, that means your camera is nder the fill in flash.
when set under this mode, the flash will work in any instance you're in. because under the red eye function, flash is usually turned off.
Dec 23, 2007 | Samsung Digimax S500 Digital Camera
Canon SpeedLite 220EX
The two types of Camera refer to the SLR's. I doubt the G2 will support FP flash as it probobly does not have a focal plane shutter like a SLR.
Oct 07, 2007 | Canon Speedlite 220EX TTL Flash
Cameras Logo
75 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
