Question about LG Washing Machines
How can solve this problem
We try turning on the machine all we are getting is PE
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 60 Answers
Change the water pressure gauge
Posted on Jan 27, 2015
2 Suggested Answers
srbkr66
  • 11 Answers
SOURCE: why it is saying PE when it turns on
Generally your bios is set to ueif"' . I would try settling the bias to basic startup.Generally the bias on most is set to Sata not advanced startup.
Hope this helps. Let me know if you have further problems. This will at least get you to pre boot.
By the way the bias is generally set to delete or whatever the screen says on your machine.This is before the Windows boot.
Good luck.
Stan
Posted on Dec 07, 2014
How can we solve this problem lg model (wf-t1122tp)
You'll have to provide much more detail if you want an answer on this. How about a photo of the condition to start with? Do you have any manuals of the machine?
Dec 07, 2014 | LG Washing Machines
LG model (WF-T1122TP) we are trying to wash all we getting PE what that means
The PE error or fault code indicates that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch.
Why it is saying PE when it turns on
Good luck.
Stan
How to fix whirlpool whitemagic pro 700 s pe error?
This was answered previously here. Hopefully it works for you.
http://www.fixya.com/support/t13889252-whirlpool_washing_machine_giving_pe
May 24, 2014 | Washing Machines
Mfc240 c gives unable to print see troubleshooting guide 51 I have tried all I know to do
The message Paper Jam may appear on the display if the Brother machine is not feeding paper correctly, paper scraps have become stuck in the print head path, the paper is not loaded properly in the paper tray, the jam clear cover located in the back of the machine, is not installed properly or the PE Actuator is missing or damaged.
To solve this problem, please follow the steps listed below:
Note : images shown below are from the representative product and may differ from your Brother machine.
  1. Disconnect the machine from the power supply.
  2. Turn the unit around and remove the Jam Clear Cover from the back of the machine by grasping it at the Center and pulling it straight away from the rear of the machine.
    Caution DO NOT place the jam clear cover face down as shown in the illustration. You may damage the cover and cause paper jam.
  3. Look for any paper scraps, jammed paper or foreign objects in the rear of the unit. If anything is found, remove it.
    Be careful not to touch the feed roller.
  4. Remove the Paper Tray from the machine.
  5. Remove any remaining or jammed paper from the front of the machine.
  6. Look inside the machine, where the paper tray was installed and locate the white PE Actuator.
Caution Do not stand the machine on end. Ink may leak from the machine.
The PE Actuator looks like a 2 prong fork or tuning fork and is located near the rear center of the machine where the paper tray slides in. It is located between the 2 gray rollers.
  • If the White PE Actuator is in place, continue to Step 7.
  • If the White PE Actuator is missing, please contact Brother Customer Service from "Contact Us".
Using both hands, use the plastic tabs on both sides of machine to lift the flat-bed scanner until it locks securely into the open position.
  • Carefully examine areas 1 and 2 at the left and right hand ends of the platen area for paper scraps.
  • These scraps may have become saturated with ink and be difficult to see.
  • Use a flashlight if necessary to check thoroughly.
Aug 13, 2011 | Brother Office Equipment & Supplies
I have whirlpool 650d, Its a new one. I am seeing PE error in the display, quite often. Due to this one hour washing takes, 2 hours, 3hours. How do we get over this error. Voltage in my area usually...
Phase error does mean low current only a current rectifirer will solve this will keep voltage regulated dipending on the load of machine it could be expensive to buy a proper voltage regulator for it
Sep 17, 2017 | Whirlpool Washing Machines
When i try a wash i am getting this "PE" error
that is a water level sensor is bad,. turn off water and unplug unit and call in a service tech.
Apr 26, 2009 | LG WM2487H Front Load Washer
PE - LG Washing Machine WFT7012EN
I am finding a PE error as I try to use my washing machine this morning. Is there any quick fix for this?
Apr 28, 2008 | Washing Machines
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
