Question about LG Washing Machines
Why it is saying PE when it turns on
Turning the machine all we getting is PE
    New Friend:
    Problem Solver:
  • 11 Answers
Generally your bios is set to ueif"' . I would try settling the bias to basic startup.Generally the bias on most is set to Sata not advanced startup.
Hope this helps. Let me know if you have further problems. This will at least get you to pre boot.
By the way the bias is generally set to delete or whatever the screen says on your machine.This is before the Windows boot.
Good luck.
Stan
Posted on Dec 07, 2014
  • Stan Baker
    Stan Baker Dec 07, 2014
    Good luck.
    Stan
What does it mean when it says PE on my lg wm0642hw washing machine
The PE error or fault code indicates that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch.
Jul 29, 2016 | LG 4.0 cu. ft. Front Load Washer, White -...
How do I correct an erroneous "raise presser foot lever" message?
I would say it time to have the computer or sensors of the machine checked
Jun 04, 2015 | Brother PE-770 Embroidery Machine
My lg fuzzy logic shows PE
The PE or pressure sensor error or fault code indicates that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch.
May 30, 2015 | LG Washing Machines
LG model (WF-T1122TP) we are trying to wash all we getting PE what that means
Dec 07, 2014 | LG Washing Machines
My card not reading in my machine
it would be a good idea to have the machine checked.
Nov 09, 2014 | Brother Disney PE-180D Computerized Sewing...
How to fix whirlpool whitemagic pro 700 s pe error?
This was answered previously here. Hopefully it works for you.
http://www.fixya.com/support/t13889252-whirlpool_washing_machine_giving_pe
May 24, 2014 | Washing Machines
Why won't my Bernina Activa 230 P.E. start when I turn it on?
it sounds like a computer problem. I suggest taking the machine to some other repair shop and see what they say.
May 05, 2014 | Bernina Sewing Machines
When i try a wash i am getting this "PE" error
that is a water level sensor is bad,. turn off water and unplug unit and call in a service tech.
Apr 26, 2009 | LG WM2487H Front Load Washer
Washing Machines Logo
46 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
