Question about Line 6 Music
On my previous question, help for biasing the output tubes, this is a Line 6 Spider Valve HD 100 Mk1 Bogner guitar amp. There are no potentiometers for this in the Mk1.
Online search for information, or schematics. There is plenty of information for the MK2, even youtube videos, but nothing for the Mk1.
CRTN
  • 716 Answers
SOURCE: Line 6 Spider 2x12 100w combo - Input jack issue
Its a 1/4" mono Panel-Mount Audio Jack
and can be bought at
Radio Shack, Best Buy, Any Music Store
Click Here
Average price about $3.00
Posted on Mar 10, 2009
danforddan1
  • 192 Answers
SOURCE: amp turns on but no sound even with diff guitars and cords
Hi Dan
I wish I could just say what to fix, but you can not do this at home. Line 6 is a great amp and worth the time taking it down to the music shop , to be looked at an give you a repair estimate. good luck keep on rocking in the free world. DFD
Posted on Apr 13, 2009
paulm10
  • 73 Answers
SOURCE: line 6 spider III 15 watt sound problems
Hi there. Sounds like the power amp IC is shorted. Must replace.
Paul
Posted on Jul 09, 2009
Kree8iv
  • 192 Answers
SOURCE: Not getting enough distortion(esp ltd ax-260)
It's not your pickups. It would be nearly impossible to loosen a wire inside of your guitar by having even heavier than your amp head drop on it. It is most likely your volume pot. The post, if hit hard enough, can virtually distroy your pots. Another possibility could be your jack, al though considering where it's located on your guitar, it would be very hard to damage it by having something drop onto it.
There is little else that could be the problem. Hopefully you didn't damage your guitar too badly. If the guitar was in front of me, it would be a relatively easy diagnosis.
Fortunately, volume and tone pots are inexpensive, and if you're handy with a soldering iron (or you have a friend that is) it is an easy install with four to six solder points, depending on your configuration. I don't want to assume it's a stock setup, but when you take off the rear electronics cover, you will immediately see what configuration you have.
If you have possibly damaged the pickup bobbins (assuming you have the stock humbuckers in your guitar), you would be able to see the damage, It would either look damaged,or work correctly. As you know bobbuns are simply wound wire, and that's not easy to damage. Plus your strings provide a minimal amount of protection, unless your amp head slammed it very hard. Start by replacing the volume pot. Cheapest parts first. There is no way to test the pot with anything like a potentiometer, because there is virtually no voltage that passes through the pot. Additionally, unless you have active pickups, your pickups cannot be either. If you do have to replace your electronics, you can find a large variety and even upgrade your parts by searching eBay. The good thing is that you havce a guitar, and guitar parts are abundant, relatively cheap, and most people change out electronics just to achieve a different sound.
If you are so inclined, most good guitar shops will diagnose your problem for cheap and apply the cost of the diagnosis to the cost of the repair. Good luck, and I hope I have given you some information to work with.
Thank you for using FixYa
Posted on Jul 19, 2009
  • 140 Answers
SOURCE: Got a Line 6 Spider III HD 75 at the flea market.
The unit has internal fuses. You have to take it apart. If the fuse is blown you more than likley need some service. You can call Pro Line Music 215-736-8055
Posted on Dec 11, 2009
Find a wiring schematic for a hofner bass knock off?
It should still be close to a real Hofner bass
a common wiring configuration is
two pickups volume for each pickup, pickup selector switch,
bass on/off switch, and treb on/off switch
there are quite a few schematics available online...
http://www.hofner-guitars.com/information-service/vintage-wiring-schematics.html?___store=guitar_store_en&___from_store=guitar_store_de
Mar 06, 2015 | Bass Music
Where can I get the schematic for a behringer DI100?
There are a few images and some info online, although nothing very conclusive? I would try contacting the company, I do amplifier repair and deal with company's daily, most of the time they are more than helpful...
http://www.behringer.com/EN/Support/index.aspx
Mar 03, 2015 | Behringer Music
How can i get to music on youtube.com?
http://www.stagepass.com/midi/browse_items.hperl?instrument=guitar&cat=1683&rank=261
Oct 28, 2014 | Hal Leonard ESPa?a - Selected Spanish...
Mackie srm450 no output
Probably the internal fuse or the amp blown. If these are the MK1 they are notoriously unreliable and you can't even change the fuse without stripping the thing down. Sound OK when working but don't expect them to keep working if you want to drive them hard. I know of some people who have changed them to passive and put a crossover in them (I suppose it at least means you have a speaker but defeats the object of active) There are plenty of independents who fix these as they are so problematic but if you can get a pair of decent speakers. The MKII is supposed to be much better but still has some issues with reliability.
Jun 30, 2014 | Mackie SRM450 PA Speaker
SUNDOWN amp15r has some conecters to plug it in one off them is a 100 watt conveter and i did not use it and on light came on for a second went off then nomatter what it did,nt go on so i,m thinkin its a...
I have done a lot of searches for any information on this unit and cannot even find a user manual to get information to help you. A 100 watt convertor sounds like it is too large and may not be the right one. A light coming on for a second and going off could be just the discharging of the power supply capacitors. I am sure others are searching for information and this is a poor company to not have even a manual available online. Do remember this only has a 6.5 inch speaker so don't expect it to be as loud as a larger guitar amp. If you can get photos of the connectors I might be able to help you, but with no manuals or other info the experts here will not be able to find any information. These amps are only $60 new. If a fuse went, there is another failure causing it. I will try a few more times to find at least a manual.
Jul 15, 2011 | Orange Amps Orange Sundown Rover 15 Watt...
How do i setup my mackie 1202
Please view videos on YouTube. Search for "mixer setup". There are a bunch, and the information and techniqes are the same for almost any of the analog mixers. You might refine the search to Mackie mixers.
Mar 17, 2011 | Mackie Music
B string flat up to 4th fret
You need to set the intonation. There are videos on Youtube on how to setup a guitar. Avoid doing anything to the truss rod. Search YouTube for "guitar setup". If it will not setup, you might need to replace the string.
Jan 31, 2011 | Epiphone Les Paul Special II Guitar...
Hi, why is it when I have finished mastering a song and record it on to the cd burner on my tascam 2488 mk2 it playsback so much lower that it sounds out of my monitors?
This is a common problem and I would recommend searching the forums on VSPLANET.com where they have all sorts of info and discussions about recording.
May 27, 2010 | Tascam 2488mkii 24 Track Recording...
Schematics service manual hammond grandee 11100
Older Hammond schematics are often available online at Captain Foldbacks site.
Search Google for "Hammond schematics"
Jan 22, 2010 | Music
Music Logo
27 people viewed this question
Top Line 6 Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Larry Stiles
Larry Stiles
Are you a Line 6 Music Expert? Answer questions, earn points and help others
