Question about Hoover Vacuums
My hand hoover is not sucking up - Hoover Vacuums
    Problem Solver:
  • 4 Answers
This is something I actually did with my Electrolux canister "SWEEPER HOSE" and yes, I know it sounds weird, but it worked. First of all, check for obstructions in the hose. If the hose is clear, then detach the HOSE from the sweeper and run water through it and see if there are any leaks. (If a hose has an "air" leak it will not be able to "suck" as well). Drain out the water and let it completely dry (inside and out) before reattaching it to the sweeper. Tape over the leak with duck tape or Gaffer's tape. My Electrolux sweeper hose had to be completely wrapped with tape (from one end to the other), but wow it really worked. The sucking capacity was increased tremendously. I hope this helps.
Posted on Dec 08, 2014
    Master:
  • Hoover Master
  • 708 Answers
HI, it's Jim from Crucial Vacuum!
Your Hand Hoover may be losing suction for a number of reasons. Here are a few things to check to help out with your hand held vacuums overall performance and to ensure a steady pickup of debris.
After every use, make sure to empty your unit's dust cup. Allowing for fine dust and debris to rest in your unit's dust cup for a long period may cause your unit to become clogged, which leads to poor or even no suction.
It is recommended to wash and clean your unit's filter weekly. To do so, empty your filter screen outdoors to take off any excess debris and then clean under running water until the water comes out clean. Allow the filter screen to fully dry before inserting it back into the unit. This may take up to several hours. Be sure to allow it to FULLY dry.
General maintenance will help improve your hand held vacuums suction and overall performance.The same applies for your general household vacuum as well.
You can purchase replacement parts direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Help! My boyfriend took apart my hoover platinum carpet cleaner
That sucks! Um, if you do not have the manual, here it is
http://hoover.com/file/622/
If that does not help. you can contact Hoover
https://hoover.com/contact/
Flick the boyfriend
May 08, 2015 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover not sucking
Remove all filters and try the suction on your hand, NOT THE FLOOR!
Filters are vital to keeping the motor working.
Most vacuum sucking probs are a result of a clogged filter or filters. Sometimes, hoses also. Or a full bag.
Remove all filters, clean them thoroughly, check hose for obstruction.
Use another vacuum to remove dust/dirt (or an air compressor) from the dirty filters.
That's first step.
Feb 26, 2015 | Hoover Vacuums
Hoover wind tunnel hand wand does not suck
Sounds like a blockage. Push a broom handle through it that will unblock it.
Oct 18, 2014 | Vacuums
Hoover dm6200 blowing air
check your suction hose again, follow it to where it goes into the body of the machine. I assume this will be near where the bagless cannister is. Remove the bagless cannister and look up inside to where the attachment hose should come into the cannister. I believe you are still blocked up there. using a butter knife or something along those lines should free up the blockage.
Also, if that is all clear, try re-adjusting the dirt cannister as it may not be on properly to create your suction flow through the hose.
Good luck and let me know if I can help further.
Jan 24, 2012 | Hoover Vacuums
Hoover carpet cleaner blowing not sucking
While the blower has different source that the sucking of water, the passage for the sucking of water needs to be cleaned to eliminate any blockage within the passage.
Apr 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Blowing insteading of sucking
Go online to HOOVER.com and locate your nearest repair facility. Take receipt with you to show it's a new purchase.
Feb 05, 2010 | Vacuums
The brushes move freely by hand but wont spin
It could be the clutch that causing your problems. What you should do is take it to a repair shop and have it looked at and see if that's the problem.
Aug 23, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hoover doesn't suck well
Did you check the inlet from the bottom? Take the bottom plate off, make sure that the tube(inlet)is free of any clogs. Also if the belt is stretched, then it won't drive the brush roll like it should, replace it part #38528033.
Feb 04, 2008 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
It is not sucking up all the water
I've had this happen to my SteamVac V2 and usually find that it's because I don't have the dirty water tank locked down well or I haven't pushed the hand attachment flap in tight or its gotten clogged up down in the suction area. I have a black lab and that area accumulates dog hair quickly. I use a Zip-it available at Lowe's or on the web to clean that out.
Sep 18, 2007 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
Vacuums Logo
78 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
