Question about Exercise & Fitness
How do I lubricate the walking belt ? - Exercise & Fitness
  • 914 Answers
Video about How to Lubricate a Treadmill using Liquid Lube
  • This video will demonstrate how to properly lubricate your treadmill belt and deck. This demonstration is for the application of liquid lube.
  • To begin, clean the deck and belt by loosening the rear roller bolts 10 turns as seen in the video. It is best to loosen each side five turns and then repeat the process.
  • Now that the belt is loose you can take an old towel and place it under the belt as shown in the video. Move the towel up and down the deck, then using your hands pull the belt around half way to ensure you have completely cleaned the back of the belt. Then remove the towel.
  • Open your lube packet and use half of the package to make a half circle on the deck, from the front outer portion of the deck toward the center and then back to the outer edge. Use about half the package for this arc. Now repeat the process on the opposite side. Be sure to wipe up any excess oil as it is very slick!
  • Use your hand to move the belt around some more to begin spreading the lubricant out.
  • Now tighten the rear roller bolts back to the exact amount of turns they were loosened previously.
  • Power on and start the machine; let it run slowly for a few seconds to make sure the belt is staying aligned in the center of the deck area. If it is not centered correctly, make minor adjustments to correct the issue. Tighten the left bolt to move the belt to the right and tighten the right bolt to move the belt to the left. Now walk on the belt for a minute or so to fully distribute the lubricant.
  • This concludes today's demonstration of how to lubricate a treadmill using the liquid lube.
How to Lubricate Treadmill Using Liquid Lube Video Video about How to Wax a Treadmill Using Powder Wax
  • Our video demonstrates how to properly wax your treadmill belt and deck. This video will be about applying the powder wax.
  • To properly lubricate or wax your belt and deck you will first need to clean between the deck and belt to remove any contaminants.
  • To do so, begin by loosening the rear roller bolts 10 turns as seen in the video. It is best to loosen each side five turns and then repeat the process.
  • Now that the belt and deck has been cleaned; Open your wax bag and using approximately a teaspoon, place the wax on the deck as seen in the video. Now repeat the process on the opposite side. Be sure to wipe up any excess wax as it is very slick!
  • Use your hand to move the belt around some more to begin spreading the wax out.
  • Now tighten the rear roller bolts back to the exact amount of turns they were loosened previously. Remember to tighten only half way on each side then repeat the process.
  • Power on and start the machine and let it run slowly for a few seconds to make sure the belt is staying aligned in the center of the deck area. If it is not centered correctly, make minor adjustments to correct the issue. Tighten the left bolt to move the belt to the right and tighten the right bolt to move the belt to the left. Now walk on the belt for a minute or so to fully distribute the lubricant.
  • This concludes today's demonstration of how to wax a treadmill using the powder wax.
How to Wax Treadmill Using Powder Wax Video
Posted on Sep 28, 2015
My treadmill turned on but the belt will not run
Dear Sir:
If the treadmill is turned On, you must check the follow:
1) the belt drive motor is faulty. 2) loose tension in walk belt, tight it.
3)Roller bearing from walk belt is faulty(lack of lubrication) both extreme.4) Walk belt is faulty and NEED LUBRICATION.
Please RUN the software calibration, under the Hood of motor and see the steps, for diagnose and troubleshooting.
See the block diagram attached. for help in troubleshooting.
2_16_2012_9_40_01_pm.gifsincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Feb 13, 2012 | Exercise & Fitness
Loud squeaking on my Reebok 9500 ES (three years old) from under the hood when the foot hits the treadmills - at various speeds and inclines.
HI,
Its time to lubricate your treadmill.
You must obtain the proper lubricant for your treadmill. There are several different types. Contact your manufacturer for what type is needed. Using the manufacturer provided allen wrench, loosen the walking belt approximately 10 full turns on each side of the rear roller. Apply approximately 1/2 ounce of lubricant directly in the middle of the walk area underneath the walking belt upon the deck. Retighten the rear roller 10 turns on each side. Run the treadmill at 6.0 mph for 2-3 minutes to spread the lubricant evenly. Wipe excess lube from the sides of the belt. Walk on treadmill to check for proper tension on belt.
for make it easy for you I have added a video. ok
Aug 27, 2011 | Reebok Exercise & Fitness
Need lubrication for proform 785 belt
Some ProForm treadmills require lubrication every six months or so, depending on the usage amount. Lift the walking belt and feel on the underside of the belt. If it is dry, you should lubricate it. ProForm recommends you use 100-percent, non-petroleum silicone spray to lubricate the walking belt. Do not use wax or other lubricants, such as WD-40 or a Teflon-based spray
Aug 24, 2011 | Proform 785 Treadmill
I have a ET-388 threadmill. however when i walk or run on the machine the sound is very heavy. can you tell me what is wrong of is it normal?
hi,
Jul 14, 2011 | Spirit Esprit by ET-8 Folding Treadmill
My treadmill Proform caliber walk... belts keeps
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in2_bing.gif and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes
May 08, 2010 | Proform Crosswalk 500 Treadmill
After walking about 15 seconds the belt slows way down and stops completely.
The walking belt slows when walked on the walking belt maybe overtightened, treadmill performance may decrease and the walking belt may become damaged or the opposite the drive and /or running belt may need tightening. Last thing would be that the belt needs lubrication to be applied between belt and deck.
Apr 26, 2010 | Cadence Weslo 620/630 Treadmill Walking...
Where do i put lubricant in my reebok treadmill t5.1
To lubricate your treadmill, start by lifting the edge of the walking belt and spread the lubricant between the belt and deck. Once you have finished on one side, do the same to the other side. When you finished both sides, start the treadmill at around 3 mph. Then walk on the treadmill to spread the lubricant on the deck for about a minute. Then your done.
Apr 19, 2010 | Exercise & Fitness
Lubricating a treadmill
The only lube required is between the walking belt and the deck. You can get the lube from iconfitness.com. Lift the walking belt and squirt some on the deck from each side, underneath the belt in the area where you usually walk. Walk on it for a few minutes to spread the lube around.
Mar 04, 2010 | Cadence Weslo 825 Treadmill Walking Belt
What should I do if the treadmill walking belt slows while in use?
Sounds like your walking belt is starting to get worn,.or you need to lubricate the walking belt. Try applying a silicon lubricant, or other lubricant called for in your manual, to the bottom side of the walking belt, and the surface it contacts. ( not the drive roller).
Jan 28, 2010 | Exercise & Fitness
Every motorized treadmill must need some regular type of servicing. What is the procedure? What do I need to do to keep my treadmill in good working order?
The main thing to do is keep the walk belt area clean of all shoe rubber and lint,vacuum the tread melt and edges regularly.Most treadmills have a wax lubricant in the walk belt,youcan purchase this lubricant at store that sell treadmills or you can do an on line search for treadmill lubricant.If you lift the belt and feel under the platform you should feel a slight waxy film, if not you should add wax as needed,some wax kits come with instructions, but if you just apply it to the platform area underneath the walk belt where you feet normally land when to step forward that should be fine,walk on the treadmill for a few minutes to spread the wax evenly on the underside of the belt, other than that there is no other maintenance needed.
Jul 10, 2009 | Exercise & Fitness
Exercise & Fitness Logo
244 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
