Hi have this problem with my kyocera km 3050 - Office Equipment & Supplies
5 Suggested Answers
sir fixalot
  • 146 Answers
SOURCE: Kyocera KM 3050 - error C3300
Error C3300 is a CCD Automatic Gain Control issue.
It could be poor contact in the connector terminals from the SHD PWB to the CCD PWB.
It is more likely a defective exposure lamp or inverter board that powers the lamp.
Try lifting up the Document feeder so you can see the optics frame through the platen glass and turning off and then on, the main power switch to see if the green exposure lamp illuminates.
A better, but more complicated way to check the lamp is to enter the service mode and run the exposure lamp test simulation. I will outline this procedure below. BE SURE NOT TO MESS WITH OTHER THINGS IN SERVICE MODE OR YOU COULD RENDER YOUR UNIT COMPLETELY UNUSABLE.
To Enter Service Mode:
Hit the "Status" button
Hit the following sequence on the numerical keypad:
1 0 8 7 1 0 8 7
You should be in service mode.
Use U601 by typing 6 0 1 and then "Start"
U601: Turning the exposure lamps on
Description: Turns the exposure lamp on.
Purpose: To check the exposure lamp.
Display:
CCD: Main Exposure Lamp
CID: Document Processor Exposure Lamp (inside the feeder)
Method
1. Press the start key.
2. Select the item.
3. Press the start key. The selected lamp lights.
4. To turn the exposure lamp off, press the stop key.
Completion
Press the stop key. The screen for selecting a maintenance item No. is displayed.
After checking the lamp(s) operation hit "reset" a few times to back out where you can type 0 0 1 "Start" to Exit Service Mode.
Posted on Jun 03, 2008
SOURCE: Have error: C6000 on Kyocera
Have Kyocera FS-1118MFPF that is coming up with Error C6000. Can we fix this ourselves
Posted on Sep 25, 2008
FixinFax
  • 3085 Answers
SOURCE: Where can I find the current firmware for a
Only an authorized technician can help you.
You might try www.smarka.com and ask about it.
Posted on Nov 11, 2009
Testimonial: "Yes, you confirm what I learned elsewhere just an hour ago. Thanks for the response!"
  • 62 Answers
SOURCE: C6000 on Kyocera KM-3050
you can try to reset the error code by going into
simulation mode
at the machine punch in 10871087
once in simulation mode.. go to sim 163
that's a fuser reset
execute that..
if problem persists you need to replace fuser
Posted on Mar 10, 2010
How to get print history of kyocera km-3050
you cannot print but you can view it only.
click on the panel the STATUS button
under printing you can view the print logs.
Good Luck!
Apr 13, 2016 | Kyocera Office Equipment & Supplies
HOW CAN I CLEAR ERROR CODE CFB 30 ON KM 3050
Abort Code recommended you have a tech come and re-flash the copier firmware. Firmware is the copiers Operating system not a driver. Firmware is only available thru secure server available to dealerships and KMBS
Jan 30, 2016 | Kyocera Mita KM-3050 4050 Toner Black...
How to set system to print in color
KM-3050/4050/505 is a pure Black & White MFP
Oct 18, 2014 | Kyocera Tk-717Km-3050/4050/5050
Kyocera repair
press status button enter 1087 1087 then 201 start press flashing crosshairs with pen point then enter 01 start
Sep 02, 2014 | Kyocera Copystar Fax System M Km-5050...
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Mar 08, 2011 | Kyocera Copystar CS-5035 Copier
simulation mode
execute that..
Mar 10, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
SYSTEM ERROR
error 610 machine kyocera km-3035 ????
Nov 05, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Have error: C6000 on Kyocera KM-3050
Aug 02, 2008 | Office Equipment & Supplies
k24674
jasbo
jasbo
