Question about Onkyo TX-SR606 7.1 Channel Home Theater Receiver Black
A replacement for an Onkyo TX-SR605 7.1 receiver speakers power board.
My Onkyo TX-SR605 is a 5-year old 7.1 receiver. Two of the front speaker terminals just ceased to operate. This receiver model has been discontined by Onkyo, hence my difficulty in finding an original (any suitable alternate would also be OK) replacement for the speakers power board. Please advise on the part identification (make, model, number) and the best procedure for purchasing and having it delivered to a US address.
techman
  • 3130 Answers
SOURCE: no surround sound
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Posted on Jun 04, 2006
lynchms
  • 93 Answers
SOURCE: Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Posted on Jan 28, 2009
Gurudristi
  • 98 Answers
SOURCE: Onkyo TX-SR706; Turntable output only from one speaker
Try some troubleshooting to check whether its the turntable or the the receiver.
What happens if you exchange the output cables of the turntable from left to right. Does the problem shift?
Does the sound changes from left to right speaker?
Similarly try on the inputs of the Receiver.. does the problem shift...?
This way you will be able to isolate the problem, whether with the receiver or the turntable....
Let me know, we can trouble shoot it further....
Posted on Mar 08, 2009
  • 5 Answers
SOURCE: I HAVE AN ONKYO TX
The symptom you described can be caused by any number of things. I always start with the output power transistors which are the first things to blow with a speaker output overload condition. Unplug the power cord to your unit, remove the top cover and use an ohmmeter to check resistance from C to E on all 10 of the power transistors (Q6050 thru 54 and Q6060 thru 64) attached to the large heat sink. Blown transistors typically read <1 ohm, compared to good transistors that are >10k ohms. If you find a bad transistor it will need to be replaced.
Posted on May 03, 2009
  • 59 Answers
SOURCE: Describe your Onkyo TX-SR875 7.1 Channels Receiver
Recommend changing your FINAL drive AMP IC most house BOTH right and left channels, your drivers right channel input is good cuz it is used to make the left channel signal
Posted on Nov 22, 2009
MY REMOTE IS NOT WORKING FOR MY ONKYO TX-SV525,
Hello, I am sorry for your issue. Please go to replacementremotes.com and search txsv525. They do sell a replacement. If you email me at askonkyo@us.onkyo.com and I will send you a copy of the manual. Thank you. Onkyo USA
Mar 14, 2017 | Onkyo TX-SV545 Receiver
I HAVE AN ONKYO TX SR500 AV RECEIVER WITH A 5.1 BOSE SURROUND SOUND SYSTEM WITH SONY TV. MOST RECENTLY ONLY ONE OF MY SPEAKERS IS WORKING ON MY SURROUND SOUND. ALL WIRES ARE CONNECTED. I CHECKED ALL...
Jan 25, 2009 | Onkyo TX-SR500 Receiver
Onkyo receiver audio problem
Called Onkyo and here is the solution they gave me.
1. Turn on unit.
2. Press and hold VIDEO 1 button.
3. While pressing VIDEO 1 button, press Speaker A.
4. You should see "CLEAR" on the display for a second and the unit will go on stand-by mode.
5. Turn on the unit again and check if sound is back.
Hope this helps.
Mar 23, 2008 | Onkyo TX-DS575 Receiver
Onkyo Tx-SR55
did you swap the left from speaker with the left front?
if still crackels after that them you have bad left output.
Jan 09, 2008 | Onkyo TX-SR500 Receiver
ONKYO AV RECEIVER TX-SR603X
When I initially bough mine, I had the same problem. It wouldn't shut down, but occasional popping sound on the center speaker. Turns out the impedance on the speaker was 4 ohms, not not 8. Replaced center with an o 8ohm speaker. This receiver is not reated to run 4 ohm speakers. If I had problems with 1, I can only imagine what kind of problems could happen if all the speakers were 4-ohms.
Oct 14, 2007 | Onkyo TX-SR603X Receiver
Onkyo TX-SR500 Dolby Digital problem
I just read over the problem you were having with your Onkyo TX-SR500 receiver. It sound like the unit needs to be setup for all five channels.Sence your symptom says the diplay shows Dolby D3/2.1. According to the owners manual with the remote control look for speaker setup whin the button is pressed the current speaker setup will be shown in the display. Press the preset/adjustment<> to change the current setting to five speakers. the listening mode will automatically change according to the number of channels you selected. Hope this helps. Radiotech
Aug 14, 2007 | Onkyo TX-SR500 Receiver
Onkyo TX-DS484 Receiver
Did you set all your parameters (see manual, page 15)? After that, you can then also change the levels of each speaker (page 16) also.
Feb 12, 2007 | Onkyo TX-DS484 Receiver
Onkyo TX-SR606 7.1 Channel Home Theater Receiver Black Logo
44 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
