Beko wm7120w spins twice fast then stops checked the pcb board new motor everything seems fine but still nothing please help
  • 686 Answers
SOURCE: fwt449GFS1 wont spin does everything else fine replaced motor and speed control board
replace lid switch
Posted on May 03, 2009
SOURCE: beko wma 510 w washing
new pump washing machine will not spin or empty. what could be the problem
Posted on May 20, 2009
  • 53 Answers
SOURCE: Hello-My Beko washing machine (WMA 1512 W)does not
recheck the brushes & pump/filter/outlet hose (make sure all cleaned out and impeller free to turn) your problem lies in there somewhere.
Posted on Oct 21, 2009
Testimonial: "Hello -The brushes have about 10mm left but will re-check ,the pump works well, I suspect the speed module board Regards Andyrooshous"
  • 884 Answers
SOURCE: Beko washing machine does everything correct,drain cycles but no spin checked motor brushes all ok looking for wiring diagram
There is a capacitor in the top of the machine to check/ replace and connections from the timer to check.
Posted on Apr 21, 2012
SOURCE: my beko washing machine wont spin ive replaced pcb board but to no avail if anyone can help much appriciated
You replaced PCB on your own or with the help of professional technician?
PCB Cleaning
Posted on Apr 09, 2013
Beko washing machine seems to go straight into a spin cycle,bangs around too.I did the test program, it didn't turn clockwise gently or anticlockwise gently it just spun really fast then blew the fuse
Hello!
It sounds like the triac, which drives the motor is in short, you can recognize from the heatsink, on Beko usually is riveted, not fixed with screw, but you can drill'em off, its an BTB12 ( or 16 ) Triac, replace, thermal grease under and back.
Rarely this problem could be caused by tacho circuit error, but ususally Beko just stops and do nothing when tacho error
Aug 31, 2016 | Beko Washing Machines
Why wont it spin fast
Hi if your Beko washing machine has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below. At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
Aug 08, 2014 | Beko WME7247W Washing Machine
My beko washing machine wont spin ive replaced pcb board but to no avail if anyone can help much appriciated
Hi christophe if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
you might find this test video helpful but only do it if you have checked the motor
Oct 30, 2012 | Washing Machines
Washer not spinning
It's either the motor,the condensator that stores electricity which then starts the motor or finally the pcb being faulty here.It might be the door switch even but you can't tell unless it's checked
Aug 03, 2009 | Washing Machines
Beko wma 510 washing machien leaving clothes un rinsed and wet.
Find out where your filter is & clean it out thoroughly, refit.
May 10, 2008 | Washing Machines
Zanussi Aquacycle 1000 f1045 spin dry fault
test the machine empty without clothes in it, if all is well then i think your problem may be the motor carbons, take them off and check for damage, make sure one of them has not spit down the middle, also look at the armature for signs of sparking,a worn armature or carbons will work fine at slow speeds
you haven't mentioned the carbons, its trying to spin so may not be the pcb
Oct 14, 2007 | Zanussi FJD1666W Front Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
