Question about Home
How do I replace the bulbs in my fire - Home
  • 28 Answers
Their is a panel on the back of the tv,remove screw and
remove the housing by pulling the handle,get the part no.off
the bulb,order a new one and put in in,before you try it make
sure you close the panel it has a switch that wont allow power to
bulb unless panel is in place,hope this helps
Posted on Dec 08, 2014
  • wadey194 Dec 08, 2014
    their is a panel on the back of the tv,remove screw and
Bright went out after replacing the headlight
Replace with new bulb you must not touch the glass part of the bulb.oils from fingers will cause it to burn out, also make sure that there is no condensation inside of the bulb housing as this will cause the bulb to short out and possibly cause a fire
Apr 07, 2014 | 1999 GMC Sierra 3500
Lamp not firing but sound works
If all other parts of the projector seem to be working, but no light come from your projector. It may be time to replace the bulb in your machine. There may be other issues with your projector but more often than not, it is time to replace the bulb.
Here's a helpful guide : http://www.ebay.com/gds/A-Step-by-Step-Guide-to-Replacing-Projector-Lamps-/10000000177628964/g.html
Mar 12, 2014 | ViewSonic Pro8200 Projector
New lamp worked for 2 weeks, last night would not turn in so removed lamp thinking it was burnt to send back under warranty. Lamp appeared fine so reinserted and tv surprisinly turned on. this morning...
Edwin, sounds like you might be having a problem with your Ballast. The Ballast is what fires up lamp. Typically if this is an older unit, when you replace the bulb, you will have to replace your ballast as well. It is harder to fire up a new bulb, then it is to fire up an old bulb. That's why you wouldn't notice the problem until you changed your bulb.
Mar 01, 2014 | Panasonic Televison & Video
Replace bulb in hyundai curved glass fire
Two people required for this
Remove fire from wall
Lay fire on its back
Gently slide glass panel towards top of fire and remove. Store glass safely
At the bottom of the fire there is a lamp cover fixed by 8 Philips head screws.
Remove screws and lift off the lamp cover
Slide the flexible rotisserie to one side ensuring you don't lose the rubber grommet
Remove bulb by pulling it out of the holder (force may be required)
Replace with 40 watt G9 halogen bulb. Take care not to touch the bulb with your bare hands
Push the bulb fully home
Refit the rotisserie making sure the rubber grommet is carefully pushed into the slotted hole in the axial bracket
Refit the lamp cover
Lift the fire back onto the wall and replace glass front by lifting onto the lugs either side of the fire.
Oct 22, 2011 | Hyundai Heating & Cooling
We have a Dimplex Danesbury Dan 20 fire and need to change a bulb! How?
1.Remove the coals .
2.Remove the two screws in the front of the brass grate second bar down.
3.pull the grate assembly away from the fire.
4. The bulbs are now exposed.
Replace with 60 Watt SES clear candle bulbs. Reassemble in reverse order.
Oct 25, 2010 | Heating & Cooling
Replaced bulb in unit. However it will not fire
Make sure that the lamp enclosure did slide all the way in.Also ensure that the lamp door is closed.Resetting the lamp timer after a lamp is installed is also necessary.If after this your still having issues its possible your ballast could be malfunctioning
May 06, 2010 | JVC Televison & Video
Infocus LP130, Bulb fires then goes out
there is a problem with the power to the front fan from the main board. there are 3 wires going to the fans: one power, one return, and one signal. if the main board reads no signal from the fan's speed, it'll shut down. check the power going to the fans and the signal. you may need to replace the main board.
Mar 03, 2010 | InFocus Office Equipment & Supplies
How to replace fire bulb for Dimplex HTN20
I wanted an answer to this too. It was hard to find, but here we go.
Get hold of a torch, and look closely at the decorative surround at the bottom of the fire. There are two screws hidden in there, on each side! See below:
Unscrew these, and you can take the front off, and get at the bulbs.
For information, the fire takes two screw in bulbs, described as 240V – 60W E14 SES Clear Candle Lamps.
Hope this helps.
Feb 07, 2009 | Dimplex DS5598 Mid-Size Heater
Infocus IN72 powers up but no image, replaced the bulb but still no image...
Hi there
This is most probably a Ballast ( lamp's powersupply ) problem.
Make 100% sure that this unit is out of warranty because InFocus Projectors come out standard with a 2 year warranty.
Apr 09, 2008 | InFocus IN72 Multimedia Projector
Home Logo
29 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
