Question about Sony Audio Players & Recorders
My sony dvd hi-fi system mhc-gn1200d power on not functioning remain red ligth blinking
SOURCE: Sony Mini Hi-Fi Component System (MHC-RG660)
I understand the problem. It should be the relay which is not responding, technically not able to connect the system power supply, you will have to replace the relay. The STK chip should be working fine.
Posted on Oct 24, 2008
SOURCE: my sony MHC-GX450 has power but does not function,
Mine did the same thing. I unpluged , and carfully took top off where I found a CD stuck. I carefully rermoved CD and put back together. When I plugged it back in I heard a click and the display lit up and I was good to go. I might have just lucked out.
Posted on Jun 18, 2009
Zlobomir
  • 225 Answers
SOURCE: my sony mini hi fi system.model mhc-nx1.reads ;
Lucky guess: you have an auto-fuse somewhere on the back of the unit.
Posted on Nov 08, 2009
SOURCE: i have a SONY HI FI 'MHC-RG66' mechanical error
kiero saber donde vienen las salidas del estrereo sony mhc rg66
Posted on Feb 20, 2010
tbreeze47
  • 3083 Answers
SOURCE: why do my sony mhc-gx450 cd shelf system power
This usually indicates faulty wiring, or miswiring. Disconnect the wires, one set and turn the unit off and on to see if that elimates your problem. If it does, the wiring or component is at fault. If you disconnect everything and have the same problem, it's an internal fault with the unit and will have to be troubleshot. Get and estimate first, to evaluate whether or not it's economical to keep, or replace with a new one. Good luck, hope this helps.
Posted on Mar 25, 2010
Sony mini hi-fi system MHC-VX33 Audio-VCD to DVD
Sony mini hi-fi system MHC-VX33 Audio-VCD to DVD is doing what?
Feb 02, 2015 | Sony Audio Players & Recorders
I can not able to open the dvd tray in sony music system mhc-rv777d
If your system was not used for a long time , then there are more possibilities for failure of belt . I have also faced the same problem. Better get the belts replaced in SONY Service Centres
Dec 25, 2013 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
MHC-GN1300D Video
I need to unlock a Sony mhc 1300D mini hi fi component , make it to play all the region
Oct 24, 2012 | Sony Mhc-gn1300d 3 Dvd/vcd/cd Changer...
Sony music hi fi system mhc-gzr88d show only demo not started
If only demo mode is playing,it's mean set is in standby mode.Normally
in standby mode it can't be operated.You have to power on the set by pressing power botton during demo mode.Once it gets power on,it will
start to work according to user required function.If the set not get power on after pressing power botton,then it's an electrical problem
and need to visit your nearby repairing centre.
Oct 17, 2012 | Sony MHC-GZR88D USB MINI DVD HI-FI SYSTEM...
Sony MHC GNZ8D Region unlock
Need to unlock the MHC-GNZ8D. Please help.-
Jan 06, 2008 | Audio Players & Recorders
Original DVD plays black and white
It seems that you have get the color system setting of your Tv wrong. Sony uses the Pal(it's a format for the transmission of signals) color system , so check into your TV's color system settings and change it to pal , if that doesnt work then change it to Ntsc.
Aug 18, 2007 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
120 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
