Question about Columbia Mfg Mens columbia singletrak watch ct004-001
How do a set my Columbia CT004 to display Date and month instead of Temperature?
How doI set the clock
Setting the Time (Without Date Display) If your vehicle has an AM/FM base radio with a single CD player and preset buttons numbered one through six, the radio will have a clock button for setting the time. You can set the time by following these steps: 1. Press the clock button until the hour numbers begin flashing on the display. Press the clock button a second time and the minute numbers will begin flashing on the display. 2. While either the hour or the minute numbers are flashing, turn the tune knob, located on the upper right side of the radio, clockwise or counterclockwise to increase or decrease the time. Instead of using the tune knob, you can also press the SEEK, FWD (forward), or REV (reverse) buttons to adjust the time. 3. Press the clock button again until the clock display stops flashing to set the currently displayed time; otherwise, the flashing will stop after five seconds and the current time displayed will be automatically set. To change the time default setting from 12 hour to 24 hour, press the clock button and then the pushbutton located under the forward arrow label. Once the time 12H and 24H are displayed, press the pushbutton located under the desired option to select the default. Press the clock button again to apply the selected default, or let the screen time out. Setting the Time (With Date Display) If your vehicle has a radio with a single CD player or a CD with DVD player, the radio will have a clock button for setting the time and date. To set the time and date, follow these instructions: 1. Turn the radio on. 2. Press the clock button and the HR, MIN, MM, DD, YYYY (hour, minute, month, day, and year) will appear on the display. 220 3. Press the pushbutton located under any one of the labels that you want to change. Every time the pushbutton is pressed again, the time or the date if selected, will increase by one. • Another way to increase the time or date, is to press the right SEEK arrow or FWD (forward) button. • To decrease, press the left SEEK arrow or REV (reverse) button. You can also turn the tune knob, located on the upper right side of the radio, to adjust the selected setting. The date will not automatically display. The only way to see the date is by pressing the clock button when the radio is on. The date with display will time out after a few seconds and go back to the normal radio and time display. If your vehicle has a radio with a six-disc CD player, the radio will have a MENU button instead of the clock button to set the time and date. To set the time and date, follow these instructions: 1. Turn the radio on. 2. Press the MENU button. Once the clock option is displayed. 3. Press the pushbutton located under that label. The HR, MIN, MM, DD, YYYY will appear on the display. 4. Press the pushbutton located under any one of the labels that you want to change. Every time the pushbutton is pressed again, the time or the date if selected, will increase by one. • Another way to increase the time or date, is to press the right SEEK arrow or FWD (forward) button. • To decrease, press the left SEEK arrow or REV (reverse) button. You can also turn the tune knob, located on the upper right side of the radio, to adjust the selected setting. The date will not automatically display. The only way to see the date is by pressing the MENU button and then the clock button when the radio is on. The date with display will time out after a few seconds and go back to the normal radio and time display. 221 To change the time default setting from 12 hour to 24 hour or to change the date default setting from month/day/year to day/month/year, follow these instructions: 1. Press the clock button and then the pushbutton located under the forward arrow label. Once the time 12H and 24H, and the date MM/DD/YYYY (month, day, and year) and DD/MM/YYYY (day, month, and year) are displayed. 2. Press the pushbutton located under the desired option. 3. Press the clock or MENU button again to apply the selected default, or let the screen time out
Nov 10, 2016 | 2007 Pontiac Torrent
How do you set time and date on Columbia CL5037 watch?
no online manuals for these
mode is the starting place
till time and and date start flashing
not a good idea to push reset while setting this watch
leave you two other buttons to push
Nov 08, 2010 | Columbia All Sport Digi Watch - Men's
How do you change the time setting to 24 hours?
  • Press the "MODE" button---usually on the lower left side of the watch, but sometimes on the right center side---to cycle through to the time display.
  • Step 2 Press and hold the "SET" button---usually on the right lower side of the watch---until the seconds flash.
  • Step 3 Press "MODE" repeatedly to cycle through the displays that flash: from hours to minutes to month to date and day. At the end of the cycle is the hour display option. Make this option flash.
  • Step 4 Press the "SPLIT/RESET" button below the face of the watch to change the hour display option to "24-hour display." This is the same as military time. If there is a "NEXT" button on the upper-right side of the watch, use this to advance to the 24-hour option instead of using the "SPLIT/RESET" button. You may need to press a "START/SPLIT" button instead a "SPLIT/RESET" button to cycle between 12- and 24-hour display. The "START/SPLIT" button could be located below the watch face or on the upper-right side of the watch, depending on the model.
  • Step 5 Press the "SET" button again. You are now done. All PM hours should be displaying hours between 12 and 23.
  • Aug 17, 2010 | Columbia All Sport Digi Watch l
    My watch is 8 months old and just stopped..the screen still displays the exact time and date that it died..but because it's digital if it was the battery the screen should have gone blank?!!
    Best bet is to start by replacing the battery. At 8 months it'll be due for one soon anyway and a new battery may "reboot" it so it runs again. As a battery wears out it doesn't just stop, it may still maintain the display even though it stops keeping time. Also, new "e-ink" displays require no power to maintain the display 0 only to change it.
    Apr 28, 2010 | Columbia Digital eBook Watch for Women
    Can't set the time on the CL5008.
    To set your Columbia-
    Hold down the set button until the display flashes. You can then use the mode button to cycle through the display features and set them. Use the strt/stp and reset to adjust fields.
    For owners manual you will need to contact Columbia.
    Contact Columbia
    Customer service (800) MA-Boyle cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif(800) 622-6953cb_transparent_r.gif
    Mon - Fri, 6:00 a.m. - 6:00 p.m. PST
    Customer service Canada cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif(800) 265-7067cb_transparent_r.gif
    Sep 20, 2009 | Columbia All Sport Digital watch
    How do i set alarm on a gap sport watch?
    For setting Time & Date...
    1. Push "MODE" button three times (change Mode to TimeSet)
    Time -> StopWatch -> AlarmTimeSet -> TimeSet -> Time ->...
    2. Flashing Second Number Digits
    3. Push "RESET" to select...
    Second -> Minute -> Hour(12hr<->24hr) ->...
    Date -> Month -> Day of Week -> Second -> ....(repeat)
    4. Use "START" to set each item...
    For setting Alarm ON/OFF
    1. Push "RESET" button then Push "START" same time...
    Alarm ON -> Alarm OFF -> ... (repeat)
    Jan 09, 2009 | Columbia All Sport Digi Watch l
    Mitsubishi HS-U500
    Just set it to record"today" choose the correct day and month,the year will be unimportant.
    Sep 24, 2008 | Mitsubishi HS-1280U VHS VCR
    Need to know how to set the time and date on a Columbia CL5008 wristwatch.
    CLick mode until you get to time
    Hold set button until chime is displayed
    Clcik mode again until 12 hr is displayed mode agiain to hr St/sp to to incresse time Reset to Decrease
    mode to cycle thru
    set to finish
    Aug 14, 2008 | Timex Sports Ironman Triathlon 100-Lap...
    Manual Information/Owner Guide
    Please check the following website for all the info and faq.
    http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
    Also,
    If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
    1. Make sure you have good batteries installed in the remote transmitter
    2. Remove the batteries from the main clock and keep them out until the clock display disappers.
    3. Re-install the batteries in the clock.
    4. Wait until the display returns and includes the outside temperature display as well.
    5. Set the clock again for current time/date etc.
    6. Bingo. You are in business.
    FixerUpper
    Feb 02, 2008 | SkyScan 86709 Atomic Wall Clock
    Unable to set time and date on a vestal G5 global traveler watch
    Not sure if you found your answer or not but I managed to locate the manual on the Columbia website. Here it is in case you haven't found yours yet:
    http://www.columbia.com/images/PDFs/customer_service/ColumbiaLeaflet_7-05.pdf
    Jan 23, 2008 | Columbia All Sport Digital watch
    Columbia Mfg Mens columbia singletrak watch ct004-001 Logo
    60 people viewed this question
    Top Columbia Mfg Toys Experts
    ray gallant
    Are you a Columbia Mfg Toy Expert? Answer questions, earn points and help others
