How can i change my dlink model dir 615-4 to simple access point to use with truecafe softwrae
I have changed in the internet network settings dhcp selection off.
    Sergeant:
  • 399 Answers
I believe you need a router with AOSS capability, i.e. it has to have a button labeled "AOSS" that you can push to make the router act as an access point. I think the D-Link DLR 615 router does not have that capability, but please check.
Hope this helps.
Posted on Dec 17, 2014
  • 10406 Answers
SOURCE: cant get on the settings page on my DLINK dir-615 router
Turn the router off.
Straighten one end of a Norwegian paper-clip,
and insert it into the small hole in the back of the router,
to "reset" the router to the "factory" settings.
Turn the router on, connect to its built-in web-interface,
and the "default" ID/password should now work.
Change the password.
Rerun the "Wireless Network Setup Wizard",
to recreate your wireless network.
Posted on Nov 23, 2009
  • 34 Answers
SOURCE: on what option do i click on to check or change my
DIR 615 (rev A-C)
1. Click on "Wireless Settings"
2. Click on "Manual Wireless Network Setup"
3. Scroll down and look for "WPA or WPE" for WPE you can change the WEP Key 1-4
4. Scroll Up and click on "Save Settings"
Posted on Jan 02, 2010
govinda123
  • 2260 Answers
SOURCE: dlink dir-615 change nat from strict to open
you will need to change some settings on the router.
reduce the MTU. if the MTU settings on the router is 1500 then change 1365 also you will need to open the some ports on the router.
Click Here for more info
Posted on Jan 12, 2010
Geekman
  • 32281 Answers
SOURCE: Dlink DIR 615, network name changed, won't accept password
It appears your brother has changed your wireless router settings.
You can reset the Dlink back to the default settings by -
Power off the Dlink and press and hold the RESET button on the back of the Dlink and the power on the Dlink. Hold the RESET button for 5 secs. until the LEDs flash at the same time.
Connect a LAN cable from the computer to the Dlink. Open a browser and enter the Dlink's configuration URL
http://192.168.0.1
Default login = admin
PW = blank (just press Enter)
You can now change the admin password and set up a new passphrase (ie encryption)
For details on how to secure your wireless from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Posted on May 19, 2010
  • 105 Answers
SOURCE: How do I secure the router so that no one else can
You should follow the next steps:
1. Log in via http://192.168.0.1
default username: Admin (use admin if it doesn't work) password: (leave it blank with no password) ----- 2. Go to setup tab ----> internet ----> internet connection wizard 2.1 CHANGE PASSWORD ! click next 2.2 choose time zone. 2.3 Configure your Internet Connection DHCP Connection (Dynamic IP Address) Choose this if your Internet connection automatically provides you with an IP Address.
2.4. press "clone your computer's MAC address" ; hostname: 'your computer name'
3. Go to setup tab ----> wireless settings ----> Wireless Network Setup Wizard (after this we're gonna do manual settings) 3.1 give your network a name= SSID 3.2.Automatically assign a network key (Recommended) and chose WAP or WAP2 3.3 Write down the network key Or do printscr and save this page.
You can leave it here, but it's better if you continue with the next step: -----
4. Go to setup tab ----> wireless settings ---->Manual Wireless Network Setup 4.1
Wireless Network Settings Enable Wireless : ALWAYS Wireless Network Name : (Also called the SSID) the name you gave in 3.1 802.11 Mode : chose "mixed 802.11n,g and b" Enable Auto Channel Scan : YES Wireless Channel : AUTO Transmission Rate : BEST (Mbit/s) Channel Width : AUTO 20/40 MHz Visibility Status : !!!Invisible!!! (so that no outsiders know your SSID except you)
4.2 Wireless Security Mode : WPA-Personal
4.3 WPA mode: WPA2 only Cipher type: AES Group key update interval : 3600 seconds
4.4 Pre-Shared Key : the one that you generated in 3.2.
Now you're all set, but you can't see your network from your PC (as you set it to be invisible in step 4.1). Now you'll have to set it up manually (the specific instructions will depend on your operating system) You'll need to enter the following date when you set it: your SSID name that you entered in 3.1 wireless security: WPA2 personal type: AES enter password that you've generated in 3.2 (or 4.4).
Posted on Oct 19, 2010
Talk talk, technical assistance
How did you connect the computer to the router. If you are using a DSL modem it will have a DHCP server in it that is allocating IP addresses across your network. If you added the router to the computer via a hub or network switch what is the computers ip .
address. Remove the WI FI router - turn off P.C and then Go to cmd or dos prompt if windows based system and type in ipconfig and press enter to see if ip addresses are 10.0.0.2 if they are your dlink router uses 192.168.0.1 so you need to make the dlink router ip addressand subnet setting to match the Modem ip addresses of the DHCP server. Change the ip address of the dlink router to be 10.0.0.2 and change the modem to allocate DHCP IP addresses from 10.0.0.10 to 10.0.0.255. Only do this if IP addresses are 10,0,0,1 to 10.0.0.,254 on the desktop p.c with the dsl or cable modem connected.without the router being involved. (you may need to ask the ISP what the user name and password is of the modem and it should be ip address xx.xx.xx.1 so type this into a browser to change the modem settings. 10.0.0.1 or 192.168.0.1 just remember if the modem is 192.168.0.1 so is the Wi router from d-link and you will have an ip clash problem)
. How do you do this by ethernet connection from only the desktop directly with only the Wi FI . router. Go to a internet browser and type in the URL 192.168.0.1 and then change the router ip address to match what the DSL modem DHCP issues..
Page 14 of Router instructions see http://files.dlink.com.au/Products/DIR-615/Manuals/DIR-615_C2_Manual_v3.10.pdf
in the manual it states to use a direct ethernet connection for the setup program but you need to be connected to the internet for it to work but if the IP addresses are wrong or clashing will have no internet. You also want to set the modem as the DCHP server and disable the DHCP server in the set up of the wi fi tand set the WI FI router default gateway as the ip address of the Modem. if any DHCP server options in the WI FI router sert to the modem ip address. .
Sep 08, 2014 | D-Link D Link Dir 615 Wireless Router...
Reset my dlink dir 615 router and now internet light stays flashing orange
Do you have the Internet connected to the Internet port in the back of the DLINK? You will have to configure the DLINK for internet access. Open a web browser to your DLINK and check on the configuration under internet-setup. Select the type of internet connection you have i.e. DHCP, PPPoE, Static, etc. Once that is set up, you should have access to the internet like before.
Feb 13, 2013 | D-Link DIR-615 Wireless Router
I just want to set up an internal network with dlink router
To setup a network just follow the step by step guide that came with the DIR-615 router. When it comes to setting up the internet on the router wizard just select Cable or DHCP and leave the other internet settings as default.
As regards to your printer we need to know the make and model number so we could further assist you. By knowing the make and model of the printer it will help us how to best setup your printer on the network. The model number is usually the name of the printer or near barcodes on the back or bottom of the printer.
Dec 17, 2012 | D-Link DIR-615 Wireless Router
I have a DLink DIR 615 wireless router from my cable/internet provider. It works (mostly), but setting up and securing a wireless network is nearly impossible. How can I create one, secure it, and can I...
I am not sure what you are missing, you should be able to do what you desire, with the unit you specify.
Here is how:
Wireless Router settings:
It is usually easiest to run the install wizard, which you can get from the manufacturers' website, usually for free, but be sure to be ready to set the items listed below:
To get access, start your browser, and put 192.168.1.1 or 192.168.0.1, or other address for your unit, into the ADDRESS bar (not search box) of your Internet Browser. Every unit has unique access login and passwords, some are admin with no password, some are admin and admin...seek access information from the website of the manufacturer of your unit. Look under support, downloads, drivers or similar sounding areas.
Things to set:
(Note: Routers are intended to be set by geeks. You have to SAVE EVERY page before you leave it, or the changes will be lost. A geek knows this (apparently). The router gives no protest...just dumps your changes. SAVE OFTEN.)
1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is typically NOT the security issue.
2. Set a recognizable system ID (descriptive name is easier to find when you need to connect wirelessly).
3. Invoke wireless security of at least WEP.
a. Assign your own access code, 10 digit home or cell #. Consider taping this information to bottom of the router. (Physical access is usually not the security issue.)
4. Check that your router is set to broadcast its' presence.
5. Change the channel of the wireless to 11, and avoid conflict with landline cordless phones. (Big issue, even the neighbors can interrupt).
There are more secure settings available, all the way down to only allowing certain MAC addresses to have access. A MAC address is a digit unique to each and every network card. Like a fingerprint. Most users do not set mac address limits.
May 31, 2011 | D-Link DIR-615 Wireless Router
How do I change the name from D-Link to our personal name please?
Log into the router and change the SSID or wireless network name Open a web browser and enter http://192.168.0.1 and press Enter. When the login window appears, set the user name to Admin and leave the password box empty. Click Log In to continue. Go to the setup tab and it's there under configuration seesection 3 of the manual
Here is the manual
ftp://ftp.dlink.co.uk/dir_products/dir-615/DIR-615_Manual.pdf
please vote ta
Feb 03, 2011 | D-Link DIR-615 Wireless Router
http://192.168.0.1
May 19, 2010 | D-Link DIR-615 Wireless Router
Cant connect 3 laptops to the dlink dir 615
reset ur router and remove the dhcp limitations
Dec 26, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
Cant get on the settings page on my DLINK dir-615 router
Nov 23, 2009 | Computers & Internet
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
