Question about Midland Radio Midland 18-258 27MHz Window Mount CB Radio Antenna
Hi chris here im using a gx300 with a 100w linear amp on the 27mhz band i can hear people but still cant seem to get out im using a staion master antenna please help tried everything
    Problem Solver:
  • 20 Answers
Yikes, using a linear on CB is illegal! You could get into real trouble doing that. The radio \'barefoot\' with that antenna should work very well, and will be legal. If you hear stations, but cannot contact them, there is a good possibility that the linear is not working. Or, the radio may not be putting out power. Do you have access to a watt meter or SWR meter? Find someone who has these instruments, and they can help you out. Best of luck to you!
Posted on Dec 28, 2014
How do I increase power output for a cobra 148 gtl the latest Chinese version
best way is to leave the radio in piece and obtain a linear amplifier to do the job a 10 meter ham radio amplifier will do nicely but you must re-tune it for the 27 mhz band 10 meter band is 28 mhz.
RF amps work best using side-band mode.
Oct 14, 2013 | Cobra 148 GTL 120-Channels Base CB Radio
I just resurrected my philips fp 440 electronic linear turntable. i am trying to connect it to sony amp. it came with its own amp in stacked system but that has packed in. im only hearing a faint noise...
The original amp had a built in magnetic cartridge pre-amp. Unless your Sony amp has a dedicated socket for a record player, you will need to purchase one of these magnetic cartridge pre-amps. You can get them just enter those 3 words into Google.
Sep 26, 2013 | Audio Players & Recorders
1994 buick lesabre new master cylinder abs light on
Look for a bleeder on ABS HCU unit- the one with brake tubing
Drive it & then Bleed again
Have to hear the abs pump come on,check fuse for it
If that doesn't work may have to open the
hcu with an obd1 scan tool & bleed
Feb 01, 2013 | 1994 Buick LeSabre
With my cobra 29 wx nw st I can not pick up any weather channels. I have the k30 antenna. Do I need a dual band antenna?
Do you hear static when you turn on weather? If so there are just none in range of you. There are not weather radio stations everywhere. You would not use a dual band antenna on any CB. Only an antenna designed for the 11 meter band. Which is the 27mhz CB radio band.
You can go here and see if you have NOAA All hazards weather radio coverage in your area.
If the CB radio is working otherwise it is most likely that there is just not a NOAA transmitter near you.
Aug 09, 2011 | Cobra 29 WX NW ST 40-Channels Base CB...
Can this radio communicate with cb channels?
hello unfortunetly not as these radios are resonating on the marine band which is vhf high band cb band is resonating on 27mhz ,marine band 157mhz so will not work .
Apr 02, 2011 | Standard Horizon HX471S (824 Channels)...
I just have uninden pro510xl (used), but don't know how to set the channel (progamming) so it can match with my handheld radio (i use motorola GP200). Thanks...
hi The uniden pro510xl operates on 11mtrs or 27mhz (cb band) the gp200 is vhf 136-174mhz so you will not be able to communicate through these radios you can only program within the specified frequencies hope this solves your problem
Dec 09, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
Just want to know if i should use my ll203 amp in am or ssb mode when running with a cobra CB radio?
What radio?? Does it have single side band(SSB)? If not, then don't use SSB.
AM - amplitude modulation
SSB - single side band.
If you have SSB, there would be a switch on it to transmit in SSB. If not, it is AM only.
Second, Has this radio been worked on to be able to run on an amp? If not, you will blow the amp.
A CB radio transmits dead keys with 4 watts of power, and transmits with 4 watts of audio.
a 4 watt dead key is too much for a linear amp. You will smoke the transistors. Also, 4 watts of audio is not enough to drive it properly. You won't get full power.
The dead key needs to be around 2 to 2 -1/2 watts,or what ever makes the linear dead key half its peak wattage., and the modulation (audio) turned up all the way.
It doesn't sound like you know too much about CB radio's. Not a big deal, you can learn. For right now you may want to take it to a cb shop and tell them you want a peak and tune, and set up to run a linear.
You can find CB shops usually at truck stops. Some area's they are other places. Check the internet for local shops.
Oct 31, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Different RAID configuration?
The first point to note is that this unit does not support more than 1.6TB total disk. (4 x 400GB drives) This is stated in the manual which is on the CD that came with the unit. You cannot configure a mix of RAID1 and Linear (JBOD) drives, so you plan will not work.
Jun 18, 2008 | Computers & Internet
Midland Radio Midland 18-258 27MHz Window Mount CB Radio Antenna Logo
60 people viewed this question
Top Midland Radio Radio Communications Experts
eradiostore
eradiostore
John L radiodude365
Tom Chichester
Are you a Midland Radio Radio Communication Expert? Answer questions, earn points and help others
