Question about Sewing Machines
Hello, the thread from the bobbin is not getting out when the needle gets into the metal piece. Is marks stichhes on the fabric, but is does not stitch.
I have tried to sew. I have placed the thread accordingly. The bobbin is OK, but when the needle getis into the meatl piece at the botton, the thread from the bobbin is not coming out
    Scholar:
  • 146 Answers
Make sure that when the bobbin is in place that you can pull the bobbin thread with your hand easily. If not, the bobbin may be in backwards or the bobbin thread is not properly routed. Also, make sure that the foot is down when you try to catch the bobbin thread with the needle.
Posted on Dec 07, 2014
Why is the bobbin thread bunching up?
if your saying that your bobbin thread is balling up under the platen plate , this is a sure sign that your top thread tension is not correct and there isn't enough tension to pull the bobbin thread up from below
Mar 24, 2016 | Sewing Machines
Euro Pro 9105 won't catch bobbin thread
first of all make sure you have the needle in the correct way round, flat side facing back, try a new needle, it only has to be slightly bent or blunt and it will miss stitches, the tension unit is the small piece near the takeup lever and it only has a small spring but that has nothing to do with the threading picking up, if the machine misses stitches after trying the above then you will need to retime the machine either bu a shop or by yourself, if you are sewing on fabric that collects static such as knitted fabric make sure you use an anti-static needle otherwise it will miss stitches.
Goodluck..
May 23, 2008 | Euro-Pro 9105 Computerized Sewing Machine
I have a Elna excellence 7600. Why does thread keep breaking while chain stitching fabric?
Thread breaks
first check to see if there is an actual thread break, then check the threading-both needle and thread
Sometimes the machine will signal a thread break when there really isn't one, at least not technically. For example, a mis-threading can cause the thread break sensor to think there is a problem because it is not sensing the proper thread tension. This can also happen if a loop of thread forms suddenly resulting in slack in the thread.
a thread break signal are really a "thread out" indication most often triggered by an empty or low bobbin or the needle becoming unthreaded.
rethread the machine and correct any low thread conditions.
Actual Thread Breaks
Examine the thread break. Is it a clean snap or is it shredded?
Next, examine the thread path. Did the thread get caught on something
A common problem with embroidery thread is that due to its slippery nature, it can slide down the spool and get hung up underneath causing a sudden jerk on the thread. Rayons will probably just snap at this point but some poly threads may be strong enough to resist breaking and instead flex the needle resulting in a broken needle.
Metallic threads often cause more breaks and shredding because they tend to form loops and kinks as they come off the spool. This is exacerbated by small spools with narrow diameters and short thread paths from the spool to the first thread guide. A simple solution for this is to extend the thread path.
Thread Factors
Lets look a little closer at thread. Embroidery threads are more fragile than those used for garment construction or quilting. Start with quality thread and know how to care for it.
Embroidery threads can dry out when exposed to light, heat, drafts, and air conditioning. They can become "bruised" if dropped or handled roughly. As they age, they become more fragile. Due to dying and other processes, certain colors break more easily than others. Check this for yourself. Try breaking a white thread and then a black. Also notice that the black is slightly thicker than the white.
Rayon tends to break easier than poly. Metallics are more temperamental and finicky
Needle-Related Possibilities
On a single needle machine, if you are getting continuous thread breaks with multiple colors and you are sure you can eliminate the thread, then look at the needle.
Is it the right size? For 40 wt rayon or polyester thread, a 70/10 or 75/11 works well on most fabrics.
Embroidery needles have a slightly larger eye to reduce friction on the thread. High quality needles have a well-polished eye that won't snag, abrade, or shred the thread. The thread can pass through the eye of the needle 50 to 60 times before it is laid down on the fabric. Any rough spot on the needle or thread path can literally saw the thread in half
The broken needle is the least of your problem! If your machine doesn't stop the instant the needle breaks, it may severely damage your fabric. Needle breaks can cause scratches and rough spots on the throat plate and in the hook area that can shred thread. Until these problems are smoothed out, thread breaks will be your reality.
It is possible for the fabric and/or stabilizer to the source of thread problems. For example, heavy, stiff fabrics can easily strip some metallic threads
If the lower thread keeps breaking, open out the bobbin hatch and check that there is no lint buildup that is hindering the smooth flow of the thread. If there is any lint, remove the bobbin and clean the area thoroughly with a brush. Also check that the bobbin is wound correctly and that the tension of bobbin thread is even. Poor maintenance and incorrectly wound bobbins are the culprit more often..
Mar 22, 2016 | Sewing Machines
My Thread bunching up on needle plate
1. Clean the needle plate and all the moving parts underneath. Also, check the hook (under bobbin carrier) for small metal, rough spots. File them off until metal is smooth. Check the needle plate for rough, metal spots and file them off.
2. Check your bobbin. It has to be a lower level than the bobbin carrier.
3. Replace thread and needle.
4. Adjust lower bobbin tension. (How to included).
Nov 02, 2015 | Sewing Machines
Why does needles keep breaking
The tension between bobbin thread and top thread might be off, pulling the needle off center and snapping it. Are you getting a bottom thread that's even? See if you can adjust the tension.
Another possibility is a dull needle through a dense fabric, or a bobbin that's not staying where it's supposed to, meaning you have metal on metal.
Nov 19, 2014 | Singer Sewing Machines
Thread jams in bobbin case
Open the bobbin area and make sure it is clean.
Change to a new needle.
Thread the machine with the presser foot up.
Make sure the bobbin thread is feeding in the correct direction from the bobbin spool and through the guide on the bobbin case.
Take hold of the end of the top thread and lower, then raise the needle to pull the bobbin thread up.
Take hold of both thead ends and pull them under the presser foot and to the back of the machine.
Place fabric under the presser foot. Lower and hand walk the first couple of stitches.
When sewing, and you need to stop to adjust the fabric, make sure the needle is down into the fabric. This will keep the stitch from malformation and causing a possible tangle.
If you need a manual, you can download one free at the Brother website.
Mar 20, 2010 | Singer 3116 Simple
Missed stitches noise when it happens
Firstly, turn machine off then turn back on. Change needle. Re-thread the top and bobbin threads. Make sure you have not set the machine for a sideways stitch but you have been using a single stitch foot (recipe for Disaster!). BEFORE trying to sew, wind the machine by hand through a stitch or two (take the thread out of the needle's eye first) and look closely to see if the needle is in fact hitting something. If it is, then the needle needs re-centering and you will have to take the machine for repair to get this done.
Make sure the top thread is going into the tension disks. The presser foot MUST be up while you are threading. Hold onto the thread just as it comes off the spool and when you get down to the needle give a tug to be sure the thread is seated in the tensions before threading the needle. When you insert the bobbin, be sure the thread "clicks" into the tension slot on the bobbin case. Check the Sewing Advisor to be sure you are set for the correct fabric and stitch for what you are sewing. Have you cleaned out the bobbin area? Remove the clear or smoke bobbin cover, either use the tool provided or just press down firmly and slide forwards the metal feed dog cover (feed dogs down first), lift out the light grey plastic bit that half covers the bobbin case, remove bobbin case. Use the brush and clean out all the fluff from the bobbin area. Then check the bobbin case and clean it too. You can use a piece of strong thread or UNWAXED dental floss to clean out between the tension springs (the bit where the bobbin thread 'clicks' into). Reassemble the bobbin pieces in reverse order, making sure that when you replace the metal feed dog cover you push it all the way to the back and it too will 'click' into place. Hope something in the above works for you.
Dec 23, 2009 | Husqvarna Designer I
There is a small metal 'thingamajig' that the bobbin thread goes by when it sew and every so often the plastic piece goes by that metal thing and cause loops on the underside. why is it doing this?
Be sure that your bobbin thread is correctly placed, is the correct thread for the fabric, usually the same as the top thread, the needle is correct size for fabric. Correct tension - balance your tension, use new needle for each project and correct pressure. Have the machine cleaned-lint build up. Use new thread, sometimes old thread breaks down and creates skip stitches.
Jul 19, 2009 | Elna Heirloom Edition 6005
JANOME RX18S
If it was sewing correctly BEFORE the needle break...why did the needle break in the first place?...and what fixes did you make?
If it sewed properly...what changed?
Cut your upper thread close to the spool...make sure the presser foot is raised and pull the cut off thread section through/out of the machine from the needle area (sewing direction...do not pull the thread backwards!)
Clean out the bobbin area...remove any traces of lint or pieces of thread...look for any broken off needle pieces... brush the bobbin area out....then add a drop of sewing machine oil (but only if your manual says to oil that area).
Remove the needle plate to expose the feed dogs...brush/clean out that area too and add a drop of sewing machine oil...then secure the needle plate back on.
Replace the needle...do it again...yup...some needles arrive bad from the factory. Make sure the needle is inserted and positioned properly. Then thread the machine WITH the presser foot in raised position. (The thread needs to get seated into the upper tensions.)
..with the.presser foot down...thread the new needle.
Oh...and use the correct needle for the thread. (a universal 80/12 is standard).
Thread can cause issues too. Try a different bobbin, or maybe a different spool of thread to see if that makes a difference.
Mar 25, 2017 | Janome Memory Craft 9500 Computerized...
Underthread Going Crazy
Hi PixelPup....Although I am unaware of what types of fabrics/needle size/project (ie does it have batting or metallic/special threads) your issue involves a fault located above your needle plate with 2 points of interest in particular. 1) Appropriate Needle Size, Type and Insertion. 2) Absence of upper tension. When replacing needles, ensure that the groove along the length of the needle is facing you. For every day medium weight cottons, a universal size 70 or 80 needle is fine. However, ALL OTHER fabrics, especially knits, denims, stretch and very lightweight or sheer fabrics should be sewn with the specified needle types. Your local sewing retailer can help you with exactness if you bring along a swatch/sample when you shop for your needles. Please purchase your sewing machine supplies from a sewing oriented retailer. Needles AND Thread quality matter a great deal in the quality and longevity of your stitches. As for needles, I recommend Schmetz, and Viking for threads. Keep in mind that needles to get dull, and can easily acquire brays which may not only cut your thread, but damage your fabrics as well, and should be changed "regularly". I would guess that misthreading accounts for 95% of all sewing machine problems including lockups, needle breakage, and instant jams. The dial for your upper tension may have a "colored zone" for the universal tensioning starting point usually between 3.5 & 5.5, with the lower number for lighter fabrics, and increasing with weight. If you don't have a colored zone, begin with #4. Completely remove the thread spool from your machine. Ensure that your presser foot is in the up position, and begin methodically threading your machine, paying special attention when you reach the tension area. There are usually 3 or 4 'plates' that provide the tension, and rushed threading by experts regularly causes the thread to miss the discs altogether. The presser foot must be in the raised position, which releases the pressure on the tension discs enabling your thread to slide in. Why not be proactive and remove and rethread your bobbin as well, ensuring that your bobbin thread receives tension from the flat spring on your bobbin case. Unless I have misunderstood your issue, your problems should now be solved......good luck my friend.
Jul 31, 2007 | Bernina Activa 140
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
