Question about Frigidaire Kitchen Ranges
How do I lock my Frigidaire stove model 37BAW*5 door
  • Official Brand Answer
  • 2,267 Answers
Thank you for your inquiry, longbowshoot!
I see that you would like to lock the door on your Frigidaire range. Normally, the oven door will lock once the self-clean cycle has been started. The model number you have provided 37BAW*5 is not pulling up as a valid model number. Are you attempting to lock your control panel? If so I need your model number to further review steps on locking your door. You can locate the serial tag (which lists your model number) behind the lower drawer of your range. I look forward to assisting you. -Matt
Posted on Dec 10, 2014
Power surge made my Frigidaire stove show a F9 code
F9 is a door lock error. Sometimes when the power surges the door locks then unlocks. It is possible your door lock could actually be broken, however many times when the EOC fails, it will show an F9 when it should show F1. I would guess that your EOC (main computer board) is fried. Try unplugging it for 24 hours then press the door lock button once you plug it back in. If there is no error code when you plug it in but the error code comes back when you lock the door, you probably have a problem with the lock.
Jun 25, 2014 | Frigidaire PLEF398AC Electric Kitchen...
I have a Frigidaire Professional Series Stove. My red lock light will not go off. When I came down stairs it was on. I locked it & unlocked it and it's still on and my stove will not come on.
I looked up your model number and I would suspect a faulty door lock latch motor switch, part # 316464301.
It can be located my removing the back panel of the stove.
Aug 02, 2011 | Frigidaire PLEF398AC Electric Kitchen...
I have a frigidaire self cleaning oven and range top. while i was baking the temp just suddenly went off and the door was locked. tried pushin lots of buttons, nothing happened. so i unplugged it for a...
Hi, try opening the door and looking for a little black switch on the right or left side, that the door actuates this is the door switch, while the stove is plugged in, hold this switch in and see if the lock moves.
Sean
Mar 26, 2011 | Frigidaire Ovens
Door lock engaged with door open
push the clear/off button for about 3-5 seconds this should release the latch
Jan 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire stove continuosly locks then unlocks
there is a small switch on the lock mech thats probly not making this is comon
Dec 25, 2009 | Frigidaire FEF336BC Electric Kitchen Range
The ESEC lockout feature is on. The slide in stove is brand new and just turned on and we can't get it out of the locked mode.
you can unplug the stove and plug it back in that will take the looking position. and in other models, set the oven to clean the oven for 5 minotes, and it will go of and will relace the oven door.
Dec 03, 2008 | Frigidaire FEF376 Electric Kitchen Range
Frigidaire stove model gles388dsb
sounds as if there is a problem with the latch assy, there are 2 switches mounted on the latch mechanism for monitoring positon of hte switches, seems as if one has gone bad, not recognizing the door lock positon therfore continues to rotate without stop.part number for the motor latch assy w/switch and bracket 318095957 . located behind rear panel
Nov 24, 2008 | Frigidaire FEF336BC Electric Kitchen Range
The door on my frigidaire stove model # FEF389WJCC locked and we are unable to get it open. We werent self cleaning the oven so I'm not sure what happened. Any suggestions how to fix it? We did try...
Hello kmgtsg,
Welcome
You said, The door on my frigidaire stove model # FEF389WJCC locked and we are unable to get it open. We weren't self cleaning the oven so I'm not sure what happened. Any suggestions how to fix it? We did try turning the breaker off and that didn't help.
Did you leave the breaker off for 5 minutes or just flicked it off and on?
It may be a faulty door Latch
The door latch consist of a micro switch and solenoid. Once the door is closed and the latch handle.
But first try to deactivate the door lock
Oven Lockout
To activate the Oven Lockout feature:
1. Press and hold for 3 seconds
2. After 3 seconds a beep will sound, LOC will appear & "DOOR
LOCKED" will flash in the display. Once the oven door is locked
the "DOOR LOCKED" indicator will stop flashing.
To reactivate normal oven operation:
1. Press and hold for 3 seconds. A beep will sound. LOC will
clear. The "DOOR LOCKED" will continue to flash until the oven
door has completely unlocked
2. The oven is again fully operational.
Let me know if these procedures work for you!!
Huuum,
Please remember to leave a rating!
Oct 14, 2008 | Frigidaire Kitchen Ranges
My 1992 Frigidaire Elite stove has locked itself, how do unlock it?
1-turn oven control to lock
2-push in and turn the stop dial knob to set a cleaning time of aprox. 1 hour
3-push the start dial knob in . this will make the locking mechanism to operate (wait 15 seconds)
4- turn the stop knob back to the"0" setting on the cleaning dial. the knob will pop out waight 15 seconds to allow the mechanism to unlatch the door
5-open the door
6 push the stop dial in to return it to the manual position
7- turn the oven control knob to off
8- close door.
basically your just repeating a cleaning cycle to reset the lock mechanism
Sep 01, 2008 | Frigidaire Kitchen Ranges
Kitchen Ranges Logo
67 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
