Question about Miele Washing Machines
How to change a drum bearing on a w806 - Miele Washing Machines
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
Go on you tube and type it in. I have found many there that help me step by step video
Posted on Dec 07, 2014
Why won't it agitate or move drum?
Screeching noise is typical to drum's broken bearing issue.
See some infor about issue:
How to Diagnose Drum Problems in Washing Machine
How to change drum bearings on washing machine
How to Change the Bearings in LG Washing Machine
How to replace washing machine bearings on Bosch Neff Siemens and some...
Some more video there... explore
Now, if you don't find it so easy to replace those bearings or you are not sure if this is your problem, call a repair service
Aug 18, 2015 | Washing Machines
1999 plymouth breeze. step on brakes and the front brakes have a bad pulsing to them. previous owner hab brakes done rotars turned and pads replaced. any suggestions on how to address this problem
Symptom: Brake Pedal Pulsates Change When: Braking Change Where: Passenger Compartment Change -->lg-bl.jpg lg-br.jpg
Priority Action Part Type Cause 1 Inspect Brake Drum Specs Brake Drum Out of Adjustment, Out of Round, or Cracked. 2 Inspect Brake Drum Unevenly Worn or Out of Round Brake Drum(s). 3 Inspect Brake Rotor Incorrectly Machined Brake Rotor. 4 Inspect Wheel Bearing-Front Incorrectly Tightened or Installed Wheel Bearing. 5 Inspect Wheel Bearing-Rear Incorrectly Tightened or Installed Wheel Bearing. 6 Inspect Wheel Nut Loose, Worn, or Damaged Wheel Nut(s). 7 Inspect Rear Axle Bent Rear Axle.
Apr 13, 2013 | Plymouth Breeze Cars & Trucks
Change hotpoint wmd 962 g uk drum bearing
Hotpoint dont sell the bearing for WMD962 seperately. You have to replace the whole drum unit.
Dec 01, 2012 | Washing Machines
Hi I have a W806 Novatronic Premier Plus washing machine. Seriel Number N121/34031023. It has been a great machine, but sounds like the bearings are on the way out as the noise levels are increasing...
Hi Neal
I had similar problems with W806 - first, it is worth fixing and doing yourself as build quality (eg. st.steel parts) is excellent.
Second, the most likely cause of bearing failure is that water has entered into the bearings through failure of the seal. This will have been caused by either unbalanced loads which destroys the dampers which will also need replacing. You may as well clean the motor and replace the bushes whilst you have machine apart.
So, if you are up for it ... turn cold water feed tap to off and disconnect cold water feed hose and the drain hose
Investigating stage:
Open the door. Turn power off and unplug.
Remove top cover (two small screws under small white domed plastic bits on each side. Once you can see inside; if there are signs of brown rusty leaks in and around the rear and possibly all over the belt and motor then that's bearing seal & thus bearings already failed or to to follow - failure for sure ... you can also see if there is any brown water stains on the floor if you move the washing machine as this model does not have a floor pan.
Dismantling:
Remove soap dispenser panel (pull out all the way and depress red clip at the rear)
There are three T9 (?) screws seen at the front panel now that the soap dispenser is out - two are recessed quite deep. Remove the 3 screws and remove the soap dispenser and hoses (TIP worth taking digital pix and making notes as you disassemble - especially electric cables!)
Remove the 3 x 10mm hex bolts behind the door and open the flap at front lower left and unclip the small drain t-piece hose - you should be able to see a spring clip which can be push opened with a large screwdriver. The door panel should then swing open - it will be stiff - as the electric cables behind and the hinge itself have been sitting in their positions for years.
Then, the advantage of taking the whole door panel off is that you can get to all of the things that need dismantling.easier and make moving the whole machine about wherever you are working easier
You will need some sort of padding - an old rug or piece of carpet is excellent - it will be placed between the drum and the side of the washing machine cabinet so that when all of the parts and bolts etc are removed from the drum, you will be able to put the w/machine on its side and then slide the drum out and get to the bearing!
if you take photos and put aside parts and label them - it is an easy job.
I have 3D explosions/general arrangement drawings and tons more details, photos and web pages/prices from suppliers (plenty to choose from - especially German) for the Miele W806 - let me know and I will assemble copies of them all for you - in a PDF or a document of some kind
Disassembly and reassembly of the bearings is tricky but well within your capabilities I'm sure.
Trgards
Tim
Feb 13, 2011 | Miele Novotronic Premier 500 Front Load...
Hotpoint WMA66 Drum Bearings gone. Drum will not ...
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our site http://www.apart4u.co.uk
This first video shows you how to diagnose the problem
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
May 20, 2010 | Hotpoint WMA66 Front Load Washer
Need to change bearings
May 07, 2010 | Hotpoint WMA64 Front Load Washer
Hotpoint WMA54 - in middle of attempting to replace the drum bearings. I've split the drum apart and am attempting to remove the existing bearings and spider; however, I'm unable to separate/unscrew the...
Jan 09, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Zanussi IZ12 bearings gone & plastic fragments in drum
Probably all parts inside drum is ok.Heating element is the only damageable item and a sensor.Changing bearings you must separate the drum, all screws in middle of drum must out and then bearing and zimmerring can be changed.Jan
Feb 15, 2009 | Zanussi IZ12 Front Load Washer
How do I change the drum bearings?
The only 100% solution is to replace the whole rear tub half complete with bearings, you may also need to replace the drum shaft as well, because any slight wear on it will lead to premature falure of the bearings.
Nov 21, 2008 | Zanussi F1045W Front Load Washer
How to change bearings
how can i remove the drum or bearing
Oct 25, 2008 | Washing Machines
Washing Machines Logo
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
